Originally Posted by
westwest888
To the OP, the parking brake does not use the regular brakes, the regular calipers, or the quattro system. It uses a drum brake on the rear wheels, which is out of plain sight. Essentially the electronic part pulls a cable which causes two pads to move outward and press against the inside of a drum. Apparently, it can also release the cable in conjunction with the wheel speed sensors in the hub to ensure the rear brakes aren't locking up.
So it is rear biased, which is safer (straightens the car out even if you are turning). I don't know that it would help you if had a brake failure on the track, which usually happens at a castrostrophic point like the start of a turn. Essentially your best bet at that point is just to focus on steering safely off track (you're going off anyway), and avoiding immovable objects once you're 4 wheels on the dirt.
West,
I think you have Audi confused with BMW. Our Audis definitely use the rear disc caliper for the emergency/parking brake, hence why it has to be opened with VCDS to do any work. One of the incidents we had at the track was an off at the end of the straight. Lots of runoff room, but not much use with no brakes. I think cranking on the EPB *may* have helped in that particular situation or at least minimized the impact at the end.
So the question remains: is there any braking action at the front wheels due to the mechanical braking of the rear wheels? I don't think it uses any of the hydraulics which is a good thing. If you've had a hydraulic failure such as a broken line, boiled fluid, etc then any braking system trying to use the hydraulics would also fail.
We are taught on the track that, if we go off, both feet in. Don't try to correct, don' try to power through the slide, just bring the car to a halt as quickly as possible. Hopefully the EPB is a good backup in case of hydraulic failure. The drum parking brake in my BMW was truly useless whereas the EPB seems to have quite a bit of power.
I guess someone is going to have to test this out on a snowy lot. Get up to speed, pull the EPB while going in a straight line and have an outside observer see if only the rear or all four wheels lock. Anybody driving a service loaner right now, lol?
