Results 1 to 17 of 17
    Established Member Two Rings NODO-GT's Avatar
    Jul 30 2010
    Audi A4 B7 2.0T Quattro 6MT
    Tbilisi
    P2181 - cooling system performance
    simple question, what should I check?
    what i have found on web so far, most suggested is to check thermostat, but I think it's fine because car warms up normally and and reaches middle temps on the gauge.
    I got this error when i was on highway, it was cold outside, 12 Celsius. I don't remeber but I think temp gauge was lower than middle, could it be caused just by low temperature outside and without any load on engine?
    2005.5 Audi A4 B7 2.0TFSI Quattro 6MT
    |Visuals: Lip Spoiler CF / Headlight Blackout + Clear Corner / LED Number Plate / Smoked LED Tail Lights / RS4 Grill / Night Braker Plus / S-line Door Blades / Gunmetal RS4 18" Wheels|
    |Performance: ECU Tune / Test Pipe / K&N Air Filter / Vast Perfromance Stage II Clutch / S-line Suspension|
    |Maitenance: BSH PCV FIX / Diverter Valve Revision D / Fuel Pump Cam Follower / Purge Valve N80 / Seafoam / Coil Packs Revision F / Spark Plugs NGK BKR7EIX|
    Veteran Member Four Rings CleverA4Name's Avatar
    Dec 09 2009
    2006 A4 2.0T Quattro 6MT, 2016 Audi SQ5
    Portland, OR
    Temperature sensor?
    F.T.W.L.T.B.D.W.I.C.T.W.
    -Trent
    Veteran Member Three Rings swaggerwagon's Avatar
    Sep 28 2012
    NC
    Quote Originally Posted by NODO-GT View Post
    The fact that you say you got it on the highway and then temp gauge was lower than middle makes me think thermostat. VAG your car, see what the freeze frame is. Also look at the temperature readings, log your car. That's what I did for mine (bad tstat)
    B8.5 3.0T/ B5.5 1.8T
    Veteran Member Four Rings IKE20VA4's Avatar
    Apr 08 2005
    Portland, OR
    So it had warmed up normally prior to your CEL?
    I'm pretty sure my tstat is bad because I have to be going up a long hill in 45 degree F temps with the heat on to get the gauge to reach middle. That and I have already done the coolant temp sensor. Got the tstat and tbelt/water pump on the way and planning a marathon weekend of some DIY work. It's gonna be not this weekend but next though.
    Jul 30 2010
    Tbilisi
    Will post Freeze data later.
    Today in the morning, when i started car, it started right away at idle revs, as if it didn't need warming up... I guess tstat has failed.
    Jun 27 2011
    ^^ the lower revs is actually normal when its really cold out. Sounds like a t-stat to me. How long does it take to get up to temp? And if it drops at all from the middle under any circumstances, you've got a bad t-stat.
    I put together a somewhat marginal, but possibly useful DIY a while back. Might help you some.
    http://www.audizine.com/forum/showth...ical-Questions
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Senior Member Three Rings pDubs's Avatar
    Jan 12 2012
    2005 Kawasaki ZX6R, 1973 Honda CB350F
    Fairfax, VA
    I've got the same code right now. My car never gets half way to operating temperature and takes forever to even budge warming up at all. I have ruled mine down to replacing the thermostat which is on the way in the mail now. After a bunch of research I think this code pretty much means its your CTS or your T-stat.
    Veteran Member Three Rings CystmX's Avatar
    Feb 04 2010
    Andrews AFB, MD
    Quote Originally Posted by pDubs View Post
    PDubs, what do you say we knock this out together? I have the code also and I think it's my CTS because my gauge never reaches half way anymore and the needle drops when I go up hill.
    Jul 30 2010
    Tbilisi
    I got Freeze Data today.
    Jun 15 2009
    2007 Audi A4
    IL
    Looks like your thermostat got stuck open, I would get that replaced.
    Jul 30 2010
    Tbilisi
    Quote Originally Posted by quickaudi07 View Post
    thanks for the replay.
    I'm interested how did you identify that it stuck open? which value points it out?
    just want to learn more :)
    Jan 12 2012
    Fairfax, VA
    If the car is never heating up to operating temperature then one thing to look at is the thermostat being stuck open. The coolant in cars is always flowing throughout the motor, once the thermostat reads it needs to be cooled down a bit it opens up and allows coolant to flow through and be cooled in the radiator and continue to flow back through the block. Once its cooled enough it will close. If the thermostat gets stuck closed your car will overheat, if it gets stuck open then your car will never really get up to operating temperature and be running too cold.
    Jan 12 2012
    Fairfax, VA
    Quote Originally Posted by CystmX View Post
    Yeah I still haven't done mine. I don't think it's the CTS though I think its the thermostat.
    Jun 27 2011
    Its more likely to be the thermostat, but it could be the CTS. My bet is on the thermostat though. Reference my thread, i had the exact same problem:
    -CP
    2017 Q7 3.0t
    Veteran Member Four Rings bman005's Avatar
    Sep 06 2011
    2015 Silverado, 2012 A4 Avant. Former; 90 Corrado, 97 Golf, 05.5 A4, 2010 Tiguan
    Harrisburg, Pa
    Its the thermostat. Temp should be at least 80C in closed loop while driving. Sensor failures typically will give you a much colder reading (a negative temp) You can easily check your sensor with vagcom (assuming you have or have access to one). When the car is completely cold like after it has sat overnight do a key on temp check. Check coolant temp and ambient air temp in measured values, they should be with 3 or 4 degrees of one another. If not, one of the two sensors is off
    New Build, 2010 Tiguan. Details to com
    Feb 04 2010
    Andrews AFB, MD
    Ok, I'll order the part and some coolant and we can knock this out together sometime. PM me.
    Apr 26 2012
    Oregon
    So, if your temp gauge has suddenly started not reaching the staright-up position BUT you don't have the code, is it still likely that the thermostat is stuck open or would that indicate a sensor? The heater gives off plenty of warmth within a mile of startup.
