Results 1 to 13 of 13
    Sep 20 2012
    HI
    How to get into locked trunk - Battery is unplugged
    I was doing some work on my car (A4 - 2011) and had to disconnect the battery. I closed the trunk and now am unable to open it as there is no power to anything. I can't get in through the backseat because they dont fold down (at least dont know of a way). Anyone got any solutions or been in a situation like this?
    Thanks,
    Established Member Two Rings r8ders's Avatar
    Feb 15 2004
    2011 B8 A4, 01 Yamaha R1, 95 M3, 98 Ford F150
    SF Bay Area
    Your seat should fold. There is a lever on the top back of the seat between the headrest and c-pillar. Just fold the seat and crawl into the trunk and then pull the manual release lever on the trunk.
    Sep 20 2012
    HI
    Quote Originally Posted by r8ders View Post
    I dont have a lever between the backseat headrest and the C-Pillar.
    Veteran Member Four Rings seanj130's Avatar
    Sep 05 2008
    Pittsford, NY
    Just re-connect your battery, open the trunk then disconnect it?
    Best regards,
    Sean.
    Paying someone to install parts and bragging about it being fast, is like watching someone
    bang your wife and being proud to raise their kids.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    look on the inside of your driver's door should be a switch to open the trunk. Keep in mind if you disconnecy your battery your remote will not work so you will need to resync it.
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    Quote Originally Posted by seanj130 View Post
    how to reconnect the battery when it is locked in the trunk?
    base models dont get split folding rear seats
    2010 A4 quattro, Tiptronic, Ibis White
    Sep 05 2008
    Pittsford, NY
    Ohh shit, didn't realize that. Are there any jumping posts in the engine bay? just hook some cables up to them if there are.
    Best regards,
    Sean.
    Feb 15 2004
    SF Bay Area
    Quote Originally Posted by Holidaze View Post
    Okay, just looked at my sales brochure and the split rear seat was a option on the A4. There may be a lever in the center of the rear seats to possibly fold the seat down as a complete piece. Wow, guess I was lucky w/ our A4 because it has the split fold seats and didn't realize it was a option.
    Next thing you can do if the door switch doesn't work is to pop your hood and connect a charger/jumper cables to the posts under the hood. The positive post is in the center of firewall under a cover and the negative post would be on you left shock tower. Just connect a charger/jumper cables there and see if it will give you enough power to pop the trunk
    Sep 20 2012
    HI
    Got it figured out. Had to lift the rear seats off and underneath is a emergency pully that pops the trunk. Thanks for the help everyone, it was much appreciated.
    Feb 15 2004
    SF Bay Area
    Glad you got it figured out. I was thinking about suggesting that but I figured that way would be a bit more difficult and most people would be afraid to do it that way if they haven't done something like that before.
    Sep 26 2015
    Atlanta, Ga
    How did u lift them?im stuck with the same problem��
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    its on valet mod on OP is trying to get in it lol. you need keys bro
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Jun 25 2014
    Los Angeles, CA
    You can also pop the hood since thats not electronic, jump the car via the jump start points in the engine bay and then pop the trunk once the car is on.
