For a long time I have said that applying too much load and/or going WOT before the oil is warmed up is a good way to increase engine wear. While I won't go as far as saying this is the sole reason why some people have suffered scored cylinder walls, it is certainly a contributing factor. My advice has always been to avoid heavy load and WOT until 10-15 minutes AFTER the coolant gauge stabilizes -- because the oil will take longer to warm up.
My B8 S4 was just VAGCOM'd to show oil temp in the DIS so I thought I'd share my findings. The B6/B7 S4 is obviously a different motor but the principles are the same. If anything, the B6/B7 S4 is an even more extreme example since it has an even larger oil sump (7 versus 9 qt) and is just a bigger motor.
Ambient temperature this evening was around 30 F. My car was parked in the open so the oil was basically the same temperature -- the viscosity would be about 687cSt at this point. The oil is whatever the dealer uses (I have AudiCare), so it's likely Castrol Syntec EDGE 5w40.
I drove slowly and avoided heavy load. Within about 5-7 minutes of around-town driving, the coolant temperature stabilized. But the oil temperature wasn't even registering in the DIS, meaning it was under 140 F -- so the viscosity was over 40cSt. So yes, the [coolant] temp gauge showed the motor as warm but the oil was still far away from normal temperature!
After about 12 more minutes the oil temperature finally leveled out at 220 F, meaning it had a viscosity of about 14cSt.
So going WOT when the coolant is warm and the oil is not means that oil you're forcing through is at least three times thicker than it ideally should be! The oil pump is working extra hard to do this, and you're not going to force as much oil into the places it is needed.
When it's the dead of winter, it will take a lot longer for the oil temps to stabilize. And picking an oil that's too thick only slows that process down too. And if anyone is wondering, letting the car idle for a bit before driving it won't help much. It just dilutes the oil with fuel. Engine load will warm up the oil, not idling. If anyone with an oil temp gauge, or even a B7 owner wants to post how long it takes for oil temp to stabilize, feel free. I just wanted to give some context to the advice I had provided people with for so long.
