Results 1 to 38 of 38
    Veteran Member Three Rings YelloJello's Avatar
    Oct 05 2007
    San Jose, CA, USA
    VAGCOM: disable "Turn off ignition before leaving car"
    I have a 2013 S5 with advanced key and would love to disable the "Turn off ignition before leaving car" message in the cluster and warning chime that I get when opening the driver's door with the car running. I know pressing the button under the wiper stalks shuts it up, but I would rather not have it beep at me at all. Very annoying. I can understand forgetting the headlights on when leaving.
    '13 | 6MT | sepang blue | black silver nappa | cf inlays | sports rear differential | plastidip grill | 20x10 vorsteiner vff-101 - 275/30/20 re760 | matte black window trim tape | kw v1 | alu kreuz | smoked fogs | piaa yellow H8 fogs | eurocode intake | retrofitlab pwy24w signal leds | apikol rear diff mount | eurocode meisterwerk ssk | 034motorsport tranny mount
    RIP '08 S5 6MT H&R springs stasis arb awe track exhaust plastidip grill awe intake filter jhm ssk
    '99 E36 M3
    Senior Member Three Rings drdrewusaf's Avatar
    May 31 2012
    San Antonio Texas
    I've been through the gamut in VAGCOM trying to find this setting (also all of the economy tips...why is my car yelling at me all of the time?) but haven't found it yet in coding or adaptation. So it's either in undocumented bits, or non-existent. Normally I would poke around in the undocumented bits, but the last time I did that I blew a module and had to have it replaced (this was in my A3 when I was trying to get the E-code tailights to work correctly - turned the interior into a dance club with all of the flashing lights).
    Drew
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Re: VAGCOM: disable "Turn off ignition before leaving car"
    That sound drives me nuts too. I would love to disable it.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Veteran Member Three Rings ACowabunga's Avatar
    Feb 24 2010
    OC, CA
    Sorry for the delay, here's the coding that I did to turn off the buzzer when the driver's door is opened and the car is running...
    a. [09 – Cent. Elect.]
    b. [Coding - 07]
    c. [Long Coding Helper] → Byte 05 Bit 3 - Change value from 1 to 0
    d. Note: Default – 00111100 (3C), New – 00110100 (34)
    I hope this helps...
    2010 Audi S5: Meteor Grey || Tuscan Brown
    May 31 2012
    San Antonio Texas
    Didn't work on my 2013. The new module (8K0 907 063 DJ) must be different.
    Drew
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by drdrewusaf View Post
    Drew
    Damn.
    Sent from my HTC One X+
    Feb 04 2010
    Jeddah, Saudi Arabia
    Ahh i need to do this
    Thanks
    Instagram: @TheDapperDriver
    Feb 24 2010
    OC, CA
    Hey Drew, I just checked my module and it ends with a "P" instead of the "DJ". I would think that the bytes would be the same and coding as well. I did confirm the coding though and it is "00110100" for mine at least. I guess this is just another reason why I can't get rid of my car just yet..... Maybe DavidB8 can help you. Have you been to his website?
    Nov 27 2012
    Houston/Texas
    That is already annoying the hell out of me. There has to be a way to turn it off in the 2013
    May 31 2012
    San Antonio Texas
    Quote Originally Posted by ACowabunga View Post
    I don't have much time before I deploy for 6 months to work on this, but I'll give a few more tries...I think VCDS needs an update anyway, so they might have a bit more documentation now.
    Is DavidB8's website the Audi Enthusiasts blog? If so, I've been through his page, but I haven't contacted him.
    Drew
    Veteran Member Three Rings bloodstar57's Avatar
    May 15 2007
    2024 SQ8 E-Tron, 2019 RS5
    LI, NY
    Thanks
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Mine has the same issue, which really drives me crazy!
    Anyone has the right coding to get it done?
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Sep 11 2004
    16 Q5
    Westchester, NY
    I would seriously pay to get that sound disabled
    Oct 17 2012
    NoCal
    Quote Originally Posted by DannyDeez View Post
    Yeah, absolutely ! It's f**king annoying !
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    May 31 2012
    San Antonio Texas
    I never found anything in VCDS, but I haven't checked for a VCDS upgrade since Dec. I won't be able to look at the modules again until Jun. For now, in case you guys don't know, pressing "reset" button on the bottom of the windshield washer stalk will temporarily silence the sound. It's only a temp fix, though. And that blows.
    Drew
    Oct 17 2012
    NoCal
    Drew
    Thanks, good to know !
    But we have to push the reset button every single time it alarms?
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Sep 11 2004
    16 Q5
    Westchester, NY
    Yes you have to push it every time. Ive gotten in the habit of pushing it with my right hand as my left hand it opening the door just so I dont have to hear that sound. It still manages to get 1 beep in though.
    Oct 17 2012
    NoCal
    "Ive gotten in the habit of pushing it with my right hand as my left hand it opening the door"
    Haha, u r sooooooo funny~~
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by xuandatou View Post
    I really do that tho
    Oct 17 2012
    NoCal
    haha, maybe I will develop the same habit as yours in the near future!
    BTW, I used to have a 2013 S5 Premium+, which did not have the same issue. Just I'm curious why the difference?
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    May 31 2012
    San Antonio Texas
    What happened to it? It would have been nice to get VCDS out and read the entire coding of the vehicle...might have been able to find the bit/bits that fix the stupid chime permanently.
    Drew
    Oct 17 2012
    NoCal
    Drew
    The dealer still has the car, how can we read the coding? Feel free to let me know if I could offer any help !
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    May 31 2012
    San Antonio Texas
    Assuming the car comes back still NOT chiming at you, you can find someone with VAG-COM and they can run a full scan on your car and save the output to a txt file. I can compare it to mine and others...and hopefully find the "different" bits that can be used to disable the chime. Then we can send the results to Ross-Tech so they can document the 2013 series controller better. Of course, all I can do is compare codings. I won't be able to poke around in my car's controllers until June.
    Drew
    Oct 17 2012
    NoCal
    Drew
    I will contact my service advisor right now since he's a good buddy of mine. As long as the car is still there, we will definitely get the right coding.
    I would assume my previous 2013 S5 was like a early release version? since it came with the f**king plastic stuff for the dead pedal rather than mental stuff which matched for the other two pedals
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Veteran Member Four Rings 13S4's Avatar
    May 03 2012
    NA
    I have the same stupid beeping sound in my vehicle and know many other 2013 S4 owners that have the same issue. I went through every control module looking for a solution but didn't find anything to turn it off. I've also gotten in the habit of pressing the reset button on the wiper stalk. I don't even notice myself doing it anymore.
    May 31 2012
    San Antonio Texas
    Don't forget to get the part number of the module...apparently there is a difference between the new 8K0 907 063 DJ and others...
    Drew
    Oct 17 2012
    NoCal
    Drew
    Yeah, I will drop by the dealer tomorrow and figure it out !
    Thanks for you kind reminder, Drew !
    Hopefully we could shut it off, its soooooooooooooooooooooooooooooooooooooooooooo annoying
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Oct 05 2007
    San Jose, CA, USA
    *BUMP* Anyone figure this one out yet?
    '99 E36 M3
    Established Member Two Rings elmajiko's Avatar
    Oct 20 2010
    CYPRUS
    Noone yet?
    Veteran Member Four Rings namvar's Avatar
    Jul 10 2014
    2024 SQ8 Prestige, 2018 A4
    SF Bay Area
    The only thing I figured out is that by pressing the button on the bottom side of the wiper controls shuts the chime off.
    2015 RS5: Mythos Black, Tech Package , Dynamic steering, Black Optics, Folding side mirror upgrade, internal LED lights, Eventuri Intake, Akrapovič exhaust, KW DDC ECU, lots of CF
    2013 3.0T Prestige Q7: Sport pedals, LED interior lights
    Veteran Member Three Rings Octothorpe's Avatar
    Aug 25 2013
    Greenwich, CT
    There's another thread about this (I'm too lazy to find it). You can shut it off, but it involves changing the country code of the car to DE or UK. If you change the country code, you'll have to change a bunch of other stuff to go back to US defaults (ie, everything will be in 24h time/metric). Changing to UK is a little more tricky, as there are subtle RHD things that will need to be taken into account. It's enough of a PITA that I didn't bother with it. However, I didn't know about the 'mute' trick. I'll train myself to do that.
    Update http://www.audizine.com/forum/showth...pen-door-chime
    2015 Lava Grey RS5
    Lunar Silver Alu-Optik Aluminium Race Inlay 20x10.5 Modulare B31 H&R OE Sport
    Build Thread
    Oct 17 2012
    NoCal
    Great find, but I'm not sure whether it worths trying due to tons of settings have to be reset...
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Veteran Member Four Rings maty360414's Avatar
    Oct 13 2015
    SoFlo
    Did somebody ever found the answer for this?
    '13 S4 | EPL DP E40 | EPL TCU | AEM W/M | Tampa Ported S/C | 75mm TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | BFI Engine Mounts | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | StopTech SS | Vertini RF 1.3 | Indy 500 | Sport Diff | BFI Shift Knob | Quattro Grill | ECS Spoiler/Diffuser | RS4 Bumper | J-Code | CWA100 |
    Jun 19 2017
    Olympia, WA
    Quote Originally Posted by maty360414 View Post
    Buy another car... sorry, couldn't resist... ;-)
    Veteran Member Three Rings greene08's Avatar
    Mar 29 2008
    2023 Audi SQ5, 2024 Tesla Model S Plaid, 2022 Kymco People S150i
    Costa Mesa, CA
    I too am curious if anyone ever discovered a proper and permanent fix for this.
    Lover of all things motorsport, powersport, sport.
    May 19 2015
    winnipeg
    Has anyone figured this out? It has to be the most annoying thing ever
    Established Member Two Rings RRM707's Avatar
    Dec 09 2017
    Fairfield, CT
    I don't believe so......
    Nov 15 2018
    Camarillo, CA
    I recently got a 2016 Q5 and this beeping is also a bane of my new existence. The cancel trick is very helpful and I'll be employing it. I don't regularly get out after starting the car, but it happens enough to be annoying.
    I do wonder, has anyone sourced the sensor for this? Is it tied to the same door sensor that would tell you the door wasn't closed all the way while driving? Just wondering what the consequence would be to disabling the sensor itself.
    The next option is the speaker, but I haven't investigated enough to know if this is using the cars main sound system or another speaker. If it is another speaker, for what else is that speaker used. Just trying to think of other creative ways around this.
