Page 1 of 41 12311 ... LastLast
Results 1 to 40 of 1623
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    ..::The Official B7 Stance Thread::..
    We are lucky enough to be blessed with the infamous F.T.W.L.T.B.D.W.I.C.T.W. thread... however that thread has become a thread of all makes and models. I thought it would be a great idea to start an official B7 Stance Thread so that fellow ziners can post pictures of their stance. Others will now be able to see the following so that they have an idea of what needs to be done to achieve their perfect stance... remember... stance will make her dance...
    • Wheels and Offset
    • Spacer Size
    • Tire Size and Make
    • Suspension Setup
    • Camber Settings
    • Toe Settings
    and... does it rub!?
    Jul 19 2011
    Northern Minneapolis, MN
    I'm down.
    These pictures weren't made for this thread specifically so bear with me.
    Wheels and Offset: 18x9 et52 (Off of 2009 TTS)
    Spacer Size: 10mm front, 15mm rear
    Tire Size and Make: 255/35-18 Hankook Ventus V12
    Suspension Setup: JOM Coil Overs, 24.75" fender to ground
    Camber Settings: -1.9deg front, -2deg rear
    Toe: -.08deg front, -.1 rear
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Wheels and Offset - 18x8.0 Sonic Tuning ST5, et35
    Spacer Size - 10mm ECS Rear only
    Tire Size and Make - Hankook V12 Ventus Evo's 245/40/18
    Suspension Setup - ST Coilovers, FTG 24 3/4"
    Camber Settings -
    Front
    Camber : 1.5 deg both sides
    Toe: .15 in
    Rear
    Camber: I did -2 deg both sides
    Toe: .2 toe in
    2008 A4 S-line 2.0T
    JHM Stage 2
    Veteran Member Four Rings Dangler's Avatar
    PA
    Wheels and Offset: VMR V705's 19x8.5 et35 & 19x9.5 et45
    Spacer Size: 20mm Front and 25mm Rear Spacers (stud conversions spacers with m12 studs
    Tire Size and Make: Falken FK452's 215-35-19 and 225-35-19
    Suspension Setup: Bilstein PSS9. Set Dampening set to full stiff (1)
    Camber Settings: -1 Front and -2 Rear
    Toe Settings: NA (I believe Factory Spec)
    IMG_3087 by Dangler83, on Flickr
    IMG_3088 by Dangler83, on Flickr
    IMG_3073 by Dangler83, on Flickr
    IMG_0811 by Dangler83, on Flickr
    Rear's
    IMG_0819 by Dangler83, on Flickr
    IMG_0817 by Dangler83, on Flickr
    IMG_0814 by Dangler83, on Flickr
    PA
    My set before the VMR's
    Wheels and Offset: 18x9.5 et 22
    Spacer Size: None
    Tire Size and Make: Sunny SN3800 225-40-18
    5951470232_d2d95b1fe3_o by Dangler83, on Flickr
    PA
    Before that...
    Wheels and Offset: 19x9 et41
    Spacer Size: None
    Tire Size and Make: Falken FK452's 225-35-19
    Untitled by Dangler83, on Flickr
    Jul 19 2011
    I love the lime green. I need to do something fun for my winter wheels. And the gold on the hood bottom is pretty clean. Is that actual heat shield? Did you get a big sheet of it?
    Established Member Two Rings Cappasjr's Avatar
    Aug 28 2011
    Trenton, NJ
    Wouldn't call it stanced but more flush I guess..
    Wheels and Offset:RS4 reps 19x8.5ET35
    Spacer Size: None
    Tire Size and Make: Falken 235/35/19
    Suspension: ST coilovers rears fully lowered
    Camber Setting: no idea whatever th alignment guy set
    on stock 16 spoke 17x7.5 ET unknown
    wheel spacers: 15MM Rear 10MM front
    same suspension settings as above
    euro n00b.. give me a break :)
    Aug 22 2010
    Piscataway, NJ
    this thread is seriously becoming full of win...
    Jul 19 2011
    Quote Originally Posted by Hugh@EuropaParts View Post
    Where is your car?!
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by CorneliusRox View Post
    Where is your car?!
    Will post pictures on Thursday, waiting on bigger spacers!
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    Will post when I'm home
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    oh jesus this will take a while.
    For starts here are 17s
    Wheels and Offset; Cobra Reps 17x9 et 29 front and 17x10.5 et 20 rear
    Spacer Size; NA
    Tire Size and Make, 205/40/17 front (or 45 cant remember) and 215/40/17 rear
    Suspension Setup; Airlift
    Camber Settings; unsure probably -3.5 all around
    Toe Settings; unaligned
    and... does it rub!? didnt drive it.
    Rotiform INDs
    Wheels and Offset 18x10 et19 front 18x11 et26 rear
    Spacer Size NA
    Tire Size and Make Nankang 215/40/18 front falken 245/35/18 rear
    Suspension Setup Customized KWv2
    Camber Settings -2.9 front -3.2 rear
    Toe Settings front set to OE spec, rear set to dead 0
    and... does it rub!? yes.
    Work Meisters
    Wheels and Offset 18x9 et29 front 18x10 et18 rear
    Spacer Size 15mm front (final offset 14) 5mm rear (final et 13)
    Tire Size and Make nankang 205/40 front 215/40 rear
    Camber Settings -2.9 all around
    Toe Settings factory
    and... does it rub!? no with pulled fenders
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Veteran Member Four Rings Vorsprung's Avatar
    Feb 26 2008
    Raptor, FD RX7
    Long_Island/NY
    ^^Forgot the OZ's bruh :P
    I miss your car on the meisters
    -Ian
    Feb 26 2008
    Raptor, FD RX7
    Long_Island/NY
    Wheels and Offset; Enkei NT03+ 18x9.5 +40
    Spacer Size; 5 mil all around
    Tire Size and Make, 235/40/18 Hankook V12
    Suspension Setup; KW V1
    Camber Settings; ~-2?
    Toe Settings; Factory
    IMG_0011de-sat by Ian. S., on Flickr
    IMG_0615_first_edit by Ian. S., on Flickr
    IMG_1197 by Ian. S., on Flickr
    IMG_1082 by Ian. S., on Flickr
    -Ian
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    Quote Originally Posted by Dangler View Post
    Before that...
    Spacer Size: None
    No HRE pics?
    Veteran Member Four Rings TFSI's Avatar
    Dec 16 2009
    Some car
    MD
    Damn, I need to wash my car and take pictures for this thread.
    Veteran Member Four Rings Leo14's Avatar
    Mar 09 2010
    North E. Jerz
    Spacer Size: None
    Love it
    RIP QG TI B7 A4
    Veteran Member Four Rings Checho's Avatar
    Dec 25 2009
    Miami
    Ok i'll play
    Wheel Spec; 18x10 (+26f/+11r)
    Spacers; NOPE
    Tires; 215/40 all around
    Dec 25 2009
    Miami
    One more
    Wheel Spec; 18x10+11 all around
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Quote Originally Posted by Checho View Post
    Ok i'll play
    Spacers; NOPE
    Nice looking wheels, what are they?
    2008 A4 S-line 2.0T
    JHM Stage 2
    Dec 25 2009
    Miami
    Rotiform BLQ
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    I'm really loving them
    2008 A4 S-line 2.0T
    JHM Stage 2
    Established Member Two Rings S14Tan's Avatar
    Jul 24 2012
    Dallas,Tx
    Rotiform BLQ
    Looks like the 3pc concave.
    Edit:
    Beat me to it. lol
    Jul 19 2011
    I havr loved the Roto BLQ's for some time... droooool
    Veteran Member Four Rings ryanworth's Avatar
    Nov 16 2009
    Los Angeles, CA
    Wheels and Offset: BBS e50 - 18x9+13, 18x10+15
    Spacer Size: 25mm front (caliper clearance)
    Tire Size and Make: 205/40/18 F, 215/40/18 R - Nitto Neo Gens
    Suspension Setup: Airlift Suspension
    Camber Settings: -2.8 at ride height
    Toe Settings: Factory
    Ford Focus - 2.0 Gray Four Banger Bad Ass Hatchback - Current
    B7 S4 - 6MT Dolphin Gray Avant - Old
    B7 A4 - 2.0T 6MT Quattro Brilliant Black Titanium S-Line - Old
    -Ryan
    Established Member Two Rings Cakija's Avatar
    Jul 28 2012
    Des Moines, IA
    alot of great cars full of win!
    Mar 26 2007
    Colorado
    can't beat ryanworth.... but here is my old set up
    Koni coils
    19x8.5 Linea corse
    225/35/19 DWS all seasons
    camber -2
    CURRENT:
    2021 Atlas
    Veteran Member Four Rings fatbrembos's Avatar
    Sep 30 2009
    b7 s4 avant/ c6 avant
    Orlando
    Just wanted to share
    Wheels and Offset: OEM Bentley GTC 19x9 et41
    Spacer Size: 12mm front 15mm rear
    Tire Size and Make: falken 225/35
    Suspension Setup: BC Racing
    Camber Settings: -2.2 front -3 rear
    Wheels and Offset: CCW Classics 18x10.5 et38 18x11.5 et38
    Spacer Size: NA
    Tire Size and Make: Dunlop 225/40 265/35
    Camber Settings: -3 all around
    Wheels and Offset: 3sdm 0.05 18x9.5 et40
    Spacer Size: 12mm front 20mm rear
    Camber Settings: -1.9 front -3 rear
    For Sale:
    HRE 943R Wheels
    Full B8.5 S4 Interior (black leather/black alacantara)
    Current Cars:
    B7 RS4 Widebody Avant
    D3 A8L - for sale
    MK5 GLI - for sale
    MK4 GLI
    Feb 26 2008
    Raptor, FD RX7
    Long_Island/NY
    Quote Originally Posted by fatbrembos View Post
    Spacer Size: NA
    WHY HAVE I NEVER SEEN THIS
    -Ian
    Senior Member Three Rings jibatnes's Avatar
    Jul 07 2011
    Norway
    Ill put up the sets i had on my old car. :)
    Wheels/offset: Zito WP 935 19x9,5 ET 30
    Tires: Yokohama S-drive 225x35x19
    Spacers: NA
    Suspension: H&R Monotube coils. 24,5" FTG
    Offset: NA
    Wheels/Offset: 18x8,5 RS6 1 ET40
    Tyres: Nokian 225x40x18
    Spacers: 5mm front, 10mm rear
    Suspension: H&R Monotube 25,5" FTG
    Wheels/Offset: Larson Innovation 20x8,5 ET 35
    Tires: Continental (something) 235x30x20
    Spacers: 5mm front 10mm rear
    Suspension: H&R Monotube 24" FTG
    Wheels/Offset: OZ Ultraleggera 20x8,5 ET35
    Tires: Vredestein Ultrack Sessanta 225x30x20
    Spacers: NA
    Suspension: H&R Monotube 24"FTG
    And finally
    Wheels and offset: 18x8 ET35 OZ Superleggera
    Tires: Michelin PS2 225x40x18
    Spacers: NA
    -2005, 2.0TFSI, Quattro, Avant, S-line, manual.
    -Revo stg 2+, Milltek exhaust with HFC, Autotech HPFP, HPFP 145 bar valve, Garret FMIC, Forge Diverter valve, Okada coilpacks, K&N filter.
    -H&R Monotube coils, Hotchkis swaybars front and rear, 034 diff mount and snubmount.
    -Spec stg 3+ clutch and 034 LWFW.
    -RS4 blacked out grilles, Cupra lip, Votex valence, Votex sideskirt, tinted windows.
    -RS4 pedals, gearknob, handbrake. oCarbon interior.
    -Zitos wp 935 19 x 9,5 ET30
    Senior Member Three Rings chucklando's Avatar
    Jul 23 2012
    Oswego, NY
    Wheels and Offset - 19x9.0 Neuspeed RSe14
    Spacer Size - None
    Tire Size and Make - Michelin Pilot Super Sport 245/35r19
    Suspension Setup - H&R Street Performance Coil Overs
    Camber Settings -
    2007 RS4 Daytona Gray
    Veteran Member Four Rings NightRoller USP's Avatar
    Aug 23 2008
    2008 Rs4
    Spacer Size: None
    Can we please have more pics???
    Jacob
    AWE ll APIKOL ll PODI
    USPCLUBMEMBER#190
    Nov 18 2012
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    Wheels- VMR 18x8.5 et 35
    Tires- Firehawk Wide Oval Indy's
    Suspension- Bilstein Pss9's
    Camber- IDK
    Spacers- none
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    Wheels- Rotiform BLQ 19x9.5 ET35
    Tires- Nitto 555 235/35/19
    Suspension- Ksport kontrol pro
    FTG- 23.75
    Camber- front -2? rear -3
    Spacers- none
    Toe Settings- stock
    Dose it rub?- yes
    Oct 14 2009
    Okinawa Japan
    Some good looking cars in here
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Senior Member Two Rings B7Quattro's Avatar
    Oct 12 2010
    Lake Forest
    Thank you for this thread!
    07 Brilliant Black 6MT Quattro S-Line Titanium
    Revo Stage 2+
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    Keep them comin.. This is the best thread to have a good database of what wheel specs, brand, tire size, offset and look all together.
    suscribed.
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Oct 14 2009
    Okinawa Japan
    Great thread indeed!
    -Shane Drake-
    >DRAKLOREs Build<
