So i just bought a 2000 S4, the car looks and runs great. It has 115k miles and is stock for the most part, turbos replaced at 60k, and it does have an AWE boost gauge installed so i cant help but notice that even when im accelerating hard its only reading about 6lbs of boost and i cant help but think this is too low... also i have noticed that when i really get on it, not even redline but close, the car starts to run rough afterwards. The other day i was heading into work, did a hard run through the gears (not mashing it but still giving it the beans) and it took it fine but when i got to work a few minutes later it was sitting there for a second and started idling really rough. it would run good then cut out and you could watch the rpm gauge jump a couple hundred rpm's. it even stalled when i went to back into my spot (it cutout, i didnt stall it). then when i turned it back on it kept running rough and i even saw some blackish smoke coming from the exhaust for a minute. then after letting it sit at work for 4-5 hours i got back in and it ran fine... Same thing this morning on the way to school, ran great the whole way, did a hard highway run 5 minutes before i got here and it took it fine but when i parked, it started idling rough again so i just shut it off. Any help as to what is going on would be GREATLY appreciated! thanks!!
Oliver
