Originally Posted by
BlazinB5
well there ya go.. more displacement it is - assuming you want low end torque/power
That I do.
FlyboyS4
This is the route I'd go if I were building a motor, but stick with my F4H's for now. More grinning in the rpm range that I spend my time driving.
Haha, we'll see after I sort my problem it out. Maybe I'll be content again and talk myself out of investing a down payment on a house's worth of money into an engine.
julex
The reason why smallest size is 81.5 is so that 0.5mm overbore is forced to even our old blocks that see wear, tear and ovalization
Ah... yeah I guess that'd make sense.
'00nogaros4
I am looking to do basically this same build with rs6x turbos over the winter. I will be curious as to what you decide on. Subscribed!
Right now it's kind of a fantasy build. After I sort out my current engine I want to finish the car up with suspension and a few other small what-nots. But we'll see...
kbjy11
hp to $ ratio is very bad if you decide to stroke it.. esp if you goal is acceleration and decide to stick to ko4 size turbos... also you are opening yourself to all the potential problems that come with building a block..
I would go meth and e85 and a retune to satisfy your need for speed.. enjoy the car.. and save your money for another platform or when things go wrong with the s4.
my 2 cents
I would not be sticking to K04s... probably RS6-Rs or TiAL 605s. I understand it's a lot of money, but it's the potential problems that I do indeed worry about, as it is quite a bit of money to abandon ship on. Appreciate your opinion sir.
sektor M7
Mmm... LOBA. Out of my range though.
[QUOTE=UkuRiSh;8187164]This pistons over price $ 2000 JE Pistons is good price and quality .[QUOTE]
I'd be happy with JE pistons if I could fine a stroked 2.7T build utilizing JE pistons without burning oil. Not blaming this on the quality, just the ring spacing.
Matador
Just 'bout shit myself, Cap'n.
$2100 (before shipping) on pistons, rings, and wrist pins? You could get JE pistons and send them to Swain Tech for a full coat treatment and still have at least $500 left over.
http://www.ctsturbo.com/cart/product...-2566-265.html
Overbuilding is one thing, overspending is just a bad move.
I got a quote from Integrated Engineering for custom pistons with both coatings and upgrade wrist pins... regardless of specifications, they'd be $1424.94 ($1424.99 self-calculated using formula he gave me).
julex
Lowering compression is a mixed bag of goodies:
Pros:
- lowered temps and less knock at the same boost level and timing between low CR and high CR engine
- due to the above, you can cram more charge than on high CR engine and have the same timing. Ofc that's not the goal so you just cram as much as the engine can take with knock being limiting factor.
- Now, here is the kicker granted you tune your car properly: overall higher timing possible ANYWHERE before knock is detectable, not only in boost!!!, so you can extract lost torque with higher timing in normal "Economy" mode. Fuel dependent ofc as I am not sure if this tactic would work all that well with E85 and higher as they already allow for crazy timing. No low CR needed for that fuel.
Cons:
- lowered thermal efficiency, economy suffers, but might be regained with adjusting timing for low-med load conditions.
- due to the above, lowered torque. 9.3 to 9.0 would be almost not perceivable, we are talking 1-2% loss of torque.
I have 8.5 on my 2.9L but I can't really tell you what the difference between 2.7 and 2.9 is, since in the process I also changed transmission on my AR from super short POS one to TDI and my gear ratios completely changed. FWIW with my much longer 2-3 gears and 2.9L stroker it feels about the same as pre-changes so it tells me that I indeed have much more torque than before. But I will be only able to tell in about 2-3 weeks once the engine is broken in.
If you're not looking for all out build, stick with stock block, but if you're already in there.... why not. Perhaps a set of rods and stock pistons are sure fire way to go with lessened risk of issues.
Hmm... at say 605s on straight 93 octane, would you say there is much to gain with small offset dropping all the way down to 8.5:1?
martin0079
I am willing to bet that CTSturbo could get you those pistons without the LOBA tax. A standard Mahle piston set is just shy of 900 I doubt these pistons cost too much more than that. Having said the mahle or wiseco are the only pistons I would use have used wiseco more than once before with good results.
Another confirmation of success with Wiseco... think I've chosen my piston.
Max@034
To the OP, you mentioned wanting a specific powerband, and you suggested 605's, but say you don't want to deal with 770s? I'm confused by this statement considering 770s spool the same as 605s. A 3.0L with high compression and good gas on 770s will spool below 4000rpm.
I think you are expecting beyond the capability of your setup. 3.0L adds a LOT of money and while it will add +50ft/lbs of torque under the curve and help spool, if you are running K04 or RS6 based turbos you are losing out on a lot of powerband with such limited exhaust flow.
Shifting the powerband over doesn't make you any slower, it just requires be conscious of the powerband. If you love to floor it from 2000rpm, then you should be in a V8.
For example, why would you spend all that money on a 3.0L to gain a small amount of power early in the powerband, when all the money you spent on a 3.0L can support a huge amount more power in the higher rpms? RPM's don't have anything to do with high speeds.
3.0L RS6 cars are an absolute blast. The Giggles B5 S4 race car runs a 3.0L built by us with genuine RS6 turbos and the powerband is huge. But 3.0L on 770's isn't far off and has a lot more peak potential. If you have never been in a 770 car, I recommend it. Even with 2.8L, the car has a lot of power under the curve and down low.
Keep in mind I will only be going 2.9L, as I do not want to take that much material away from the block. I won't lose sleep over .1L of displacement knowing there is a HUGE safety net while the engine sustains a beating over the course of an extended drive (track).
Maybe I should clarify, I'm not expecting there to be no lag with this potential build. I know the lag will be more than that of the FTs on my 2.7T. Also, I'm more focused on RS6-Rs at this point, and for two reasons. JHM's 10 second pass, and 034's 'Giggles' S4. (Yes, I know Jay has the advantage of being a fantastic driver, and 'Giggles' is a tuned, race car). However, I want more power, on AND off-boost without adding a lot of lag. I guess I'd have to take a ride in a 770 car to justify my arguments against it. Just trying to stay from a highway warrior... think backroads with lots of turns, if that paints a canvas.
Issam@INA
...and the can got opened.
Ahhh shiiit...
britishturbo
To the OP, I'm not sure how to answer your question because I'm really not sure what your goals are.
What I do see though is opposing goals...
You mention that your current turbos are "laggy"... well unless you go with larger "more laggy" turbos you aren't going to get more power unless you do one of the following:
1) Increase displacement
2) Rev higher
3) Increase engine VE - i.e. Intake / Heads / Cams
Also how much power are you really shooting for?
Just trying to get a feel for what you really want before I throw you mya dvice...
No, I didn't mean I wanted or had the intention of reducing the lag. I know stepping up a size, even with the specifications outlined, isn't gonna reduce the lag. What I meant I was I already notice the lag around town. I am rarely on the highway, and rarely at speeds above 70 unless I'm doing a quick pull, which even then I don't stay up there long. So I'm building more for lower speed with acceleration in mind that I can still romp on the highway and get joy out of it... all while knowing that if I beat the shit out of it's gonna hold up.
