Results 1 to 28 of 28
    Oct 30 2009
    colorado
    Major Steering Fluid leak after doing donuts....
    Before you say anything, yes I know, it was pretty stupid.
    Anyways, my tires were worn so I thought it would be cool to do some awd donuts before putting the new tires on. I did quiet a bit of drifting and donuts and noticed that my steering wheel would barely move into either direction after about 5 minutes. So I stepped out of the car to see wtf was going on......a huge trail of steering wheel fluid right behind me where I was drifting. I looked under the car and sure enough, the steering wheel fluid was dripping rapidly. After getting the car home I bought power steering fluid and some lucas stop leak fluid....this didn't help at all. The fluid drips right out beneath the car.
    What could I have damaged?
    Veteran Member Four Rings DESPOT D S4's Avatar
    May 09 2010
    8S TTRS
    TriState
    Rack or pressure line.
    Eather way your gonna hate life
    @iruinaudis
    B5 S4 daily
    8S TTRS fun car
    Aug 26 2008
    Minnesota
    Find where it's leaking first. There are two lines that connect to a cooler right next to the oil filter, I'd check those first. Then I'd check the suction hose coming off the drivers side of the power steering pump, it's a really short hose about 3/4in diameter.
    Oct 30 2009
    colorado
    ^^^ I've checked those but no luck. The dripping is coming from somewhere above the downpipes.
    Veteran Member Three Rings zrider91r's Avatar
    Jan 06 2012
    California
    Above the DP= rack. Im sorry.
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    the rack sucks to change in car, I'd pull the motor and go stage 3 and change the rack at the same time. No joke. That will give you lots of room
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Established Member Three Rings s4930's Avatar
    Mar 01 2012
    south florida
    i wish you luck
    034 STK PT6262 BB :)
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    never do full lock donuts. Even in the snow or rain
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Veteran Member Four Rings quattroloco's Avatar
    May 07 2012
    olympic penninsula/WA
    ^yep. never. the variable rate system audi uses does NOT like full lock for more than a second or so... you blew it.
    B6 A4 AVANT swaped 2.7T 6MT S4 Drivetrain still illegal
    Jun 18 2010
    16 Jaguar XF S
    Fort Lauderdale Florida
    Quote Originally Posted by CELison View Post
    I borrowed an old school 95 sl 500 mercedes back in 2002 and just locked the steering wheel parking the car. Blew the power steering line and power steering fluid was everywhere. So the rack on your car was probabally on its way out ands its a 10+ year old car. Just get it pulled and rebuilt.
    Rest In Peace Four Rings
    Oct 14 2012
    Upstate NY
    There are threads about this warning new audi drivers not to rev the engine at full lock. Where you doing this on dry pavement :)
    Mar 27 2011
    00 S4 Epl 3
    mn
    Ouch! sorry to hear that!
    Sep 11 2009
    NE
    Sorry man. I postponed my rack replacement until next engine pull even though it was very loose and ate a set of tires. Reason? Let's say that replacing turbos with engine in the car is the only other equally pita job on these cars. Good luck man.
    Oct 30 2009
    colorado
    ohhhh man. I was really hoping for better news. Really? It's just as bad as replacing turbos? Is there a writup somewhere?
    May 16 2008
    WA
    i hope you at least took some video of this to share. You should have something to show for the price of a steering rack lol
    Established Member Two Rings KaoticS4's Avatar
    May 24 2012
    01 Nogaro S4
    Atlanta, GA
    The outcome sucks but on the bright side...
    ...The thread title made me lol
    Veteran Member Four Rings Meow's Avatar
    Mar 08 2012
    MI
    In the owners manual it says not to stay at lock for more than a few seconds. Being at lock + high revs doing donuts = big power steering leak. I had the same thing happen to me...
    I did do a perfect donut though.
    RIP Daz, you will be missed.
    Aug 13 2008
    Indiana
    I feel like it's not as bad as people make it out to be.
    I had the exact same rack in my old A4 and that only took about 1.5 hours to replace. I managed to install that and coilovers in the same night after work and overall that was around 5 hours.
    The hardest part for me was lining up the threads on the banjo bolts...
    -Nic
    Veteran Member Three Rings dubzackvr6's Avatar
    Oct 18 2010
    Stage 2 C7 A6, Tahoe for the kiddos
    SLC, UT
    Quote Originally Posted by Meow View Post
    LOL. Sometimes, it's worth it.
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Quote Originally Posted by somebody5788 View Post
    if your a4 had a 1.8t.. then this means nothing
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Oct 30 2009
    colorado
    Alright, so how exactly would I be able to tell whether or not the rack is bad? Obiously it will be leaking power steering fluid but which location form exactly?
    Please refer to the picture
    I took my wheel off and noticed that the driver side rack boot was detached from the rack itself as shown below (no clamp was holding it on).
    Does it even matter that the boot was detached? If I re-attach it and clamp it down properly, does it still mean that the rack is shot? The leak is definetly coming from that driver side area because it only leaks down on that side. The passanger side has no visible leaks anywhere.
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    you can change the rack with the motor in. It's not that bad. I have done it. As long as you have a manual car... Tiptronic is a different story. Good luck.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Oct 30 2009
    colorado
    Yup, the car is a manual. I just want to staight this out. There should be no power steering fluid in the rack boot at all (the boot is just there to keep out dush or harsh driving environments) correct ? As I mentioned before, when I took a look my driver side rack boot was not connected to the rack.
    Sep 11 2009
    NE
    you probably blew that side seal and it squirted the fluid out on that end causing the boot to balloon and eventually detach from the rack. you have to take the rack out either way since either some line or the rack itself blew up. good luck. you're in for some extensive name calling when doing this.
    Oct 30 2009
    colorado
    alright, thanks for the encouragment :D
    Dec 05 2009
    New York
    there is a writeup on here somewhere
    Veteran Member Four Rings Smitty2A4's Avatar
    May 30 2007
    Stage 3 B5 S4 6 Speed l B6 A4 3.0 6 Speed (RIP)
    Boston, MA
    I hate the power steering systems in these cars, I went through two pumps in my old A4 in under 40k miles and the rack needed to be replaced. In my current S4 the pump groans if you have the wheel at full lock for even a split second which I am told is normal because the car is lowered and it puts extra stress on the pump. After reading to never go full lock in the owners manual of my old A4 I avoid it at all costs with the S4, I only do it sometimes in tight parking spaces when I don't have another choice. It is pretty annoying tho when every time my car makes that sequel my passengers act as if the motor might blow!
    Looking for a good shop north of Boston, call Eurosport Performance
    Veteran Member Four Rings 00SantorinS4's Avatar
    Oct 02 2006
    So. Maine
    My pump is to the point where if I turn the wheel at idle in any direction it groans and makes a *faint* whine sound.
    Full lock it screams even more than ever.. sigh. I guess I'll be replacing the pump soon and doing a fluid flush.
    Exactly like this lol..
    2017 Audi S3//Navarra Blue//Black Optic//SuperSports//Tech//Dynamic//B&O//Injen Evo CAI//CTS Inlet//APR Coils
