Results 1 to 25 of 25
    Senior Member Two Rings Corrado's Avatar
    Apr 07 2010
    MidAtlantic
    Headlight bulb replacement procedure & where to get replacement HID bulb
    Changed the oil yesterday and washed the car....go to drive it and "bam!" got a funny warning message on the dash. It's my Audi so I now by now after owning the car for 4 years that when you do one thing, something else completely unrelated happens (washing car and oil change should have nothing to do with a headlight problem I know.)
    Ok, here is the noob question of the day - how do I replace the driver's side headlight bulb? Do I have to take out the entire headlight, or just reach through the back?
    I've searched and searched and can't find anything about just a bulb replacement. Most threads are about DDM tuning ballasts and such. Or about the clear corner mod. Or something else.
    I didn't have any warning signs (pink bulb) or anything else...so does this mean I need a bulb and not a ballast? Headlights always fire up right away until last night.
    I've seen D2S bulbs go from $15 to $90. I want a stock color so perhaps 4300k, 4500k, or 5000k probably. Where is the best place to get bulbs from? Do you really get what you pay for with a bulb?
    Amazon? (MaxLux seems to be popular brand for about $30)
    HIDconcept?
    ECS tuning?
    DDM Tuning? ($15 for a pair???)
    Aug 13 2008
    Indiana
    Quote Originally Posted by Corrado View Post
    HIDconcept?
    ECS tuning?
    In before everyone tries to tell you to go DDM, I'll be one of the few to say just stick to the Phillips 85122+ that you can get at any parts store. They run a little pricey but they will last longer, brighter, and run cooler then the cheaper options. You can opt to go to the new Phillips CBI (Cool Blue Intense) to get a little color but still have white light they are basically a 5000k bulb compared to the OEM 4300k
    -Nic
    Apr 07 2010
    MidAtlantic
    Thanks Nic. I want to keep it stock!
    No DDM ballasts or that stuff. Just want to get a new bulb.
    Theretrofitsource.com has a pair of the Phillips 85122+ for $95. Seems like a good price over Ziza or other questionable brands.
    Aug 13 2008
    Indiana
    If you order from Amazon you can sometimes snag the Phillips bulbs for a great price.
    http://www.amazon.com/Philips-Xenon-...words=85122%2B
    Not a "great" price but it's still pretty decent.
    -Nic
    Sep 11 2009
    NE
    Quote Originally Posted by somebody5788 View Post
    That a very good price. These will last as long as the orginal set which would be the rest of life of most of S4s on this forum.
    Apr 07 2010
    MidAtlantic
    When researching bulbs more, I found this:
    Note: There is no such a thing as PHILLIPS 85122+ anymore. PHILLIPS 85122+ has been replaced by 85122wx.
    Can anyone confirm this:
    85112 = "standard" = 4300k
    85112+ = 85112wx = Ultinon = 6000k
    Aug 13 2008
    Indiana
    Is this correct?
    I've not heard of that. I honestly don't think it's true but I could be wrong.
    Also if you don't mind buying a pair here's a little better price http://www.theretrofitsource.com/pro...roducts_id=148
    Pairs always match better BTW.
    -Nic
    Apr 07 2010
    MidAtlantic
    To replace - do I have to take out the entire headlight, or just reach through the back?
    May 16 2008
    WA
    I was just looking this info up as well, and essentially what I found was:
    The 85112+ was the same as the 85112 (both are 4300k) however the "+" resisted "color shifting" after so many hours of use where the regular bulb's color would eventually change.
    The 85112CM is slightly 'whiter' at 4800k vs 4300k, but retains the ~3100 lumens rating
    The 85112WX is the 6000k blue bulb, has a much lower lumen rating, therefore worse output, and is often called the 'ultinon'
    Check out this site for all kinds of useful HID Bulb/Ballast/Projector info and comparisons:
    http://www.hidplanet.com/forums/show...M-and-85122-WX
    Also be warned, there are plenty of fake Phillips bulbs on Amazon and Ebay, TheRetrofitSource.com deals with Phillips directly (as you can see by the post i linked)
    May 16 2008
    WA
    Here is a better breakdown of each and every bulb and its specs:
    http://www.hidplanet.com/forums/show...bout-HID-bulbs
    Sep 11 2009
    NE
    I run Xenarc 66240CBI and boy are they so much brighter than normal stuff on standard 35w ballast but I also bought TRS 50w ballasts.
    May 16 2008
    WA
    Quote Originally Posted by julex View Post
    i have been looking at those to replace my current stock 12 year old bulbs, do you have any pics you can post up or PM me?
    May 13 2011
    2015 BMW F30
    Quote Originally Posted by getslideways View Post
    Good info, thanks for sharing.
    | Autospeed | JHM | Pure MS
    Veteran Member Three Rings PearlS4's Avatar
    Mar 16 2007
    2001.5 S4 Pearl White, 04 B6 A4 Avant, 99 Mercedes 300E Turbo diesel, 89 Toyota 4 x 4
    Bellingham, WA
    I've always just pulled the housing out from the car, makes it easier for me. Not a lot of room in there to screw around the other way.
    Tial 770 and lots of other stuff, by AMD/EPL
    "Official member of the anti-stance movement"
    Aug 13 2008
    Indiana
    I would do it in the car so you don't have to re aim the headlight when you're done. Just be very sure that you have the alignment tab lined up.
    -Nic
    Active Member Two Rings pharkwar's Avatar
    Oct 24 2012
    2001 S4 Avant, 2001 TT 225 rdstr, 2001 Golf TDI
    Kitchener
    I've run across these guys recommended on a few forums - hidbulbzrus.com
    Not the most confidence-inspiring name I've ever heard, but I will be buying from them for a full headlamp refresh when my E-codes arrive.
    Apr 07 2010
    MidAtlantic
    I guess I'm a headlight noob, but I'm really suprised I can't find a DIY or Tech article about how to replace the bulb. And yes, I don't want to fart around with aiming or a VAG-com (don't have one) or breaking a tab or any of that stuff. I'll try reaching through the back once I get the new bulbs.
    Veteran Member Four Rings BlazinB5's Avatar
    Nov 12 2010
    Stillwater, MN
    i paid $35 (includes the bulbs and shipping) for my 5000K bulbs from DDM Tuning, and i'm still using the factory ballasts
    2001 Allroad 2.7T
    2000 A6 4.2 (parted out)
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Apr 07 2010
    MidAtlantic
    I just ordered a set of Morimoto 5000k bulbs from The Retrofit Source. These seem to have most of the qualities I'm looking for (a 5000k color) at a great price.
    Going to try to replace them without removing the entire headlight housing. Seems the driver's side will be tough, and the passenger's side will have more room since I have a cone intake.
    Once they are in I'll try to get a few comparison pictures.
    Veteran Member Three Rings HomeSlice's Avatar
    My headlights suck compared to my B8 I can't see anything. Will swapping out the bulbs help at all or do I need some new lenses?
    Sep 11 2009
    NE
    Quote Originally Posted by HomeSlice View Post
    Fidn a thread in this forum about TRS clean lens swap, it makes the headlights much brighter.
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    6000k for me look great with 55W ballast
    Good looking out!
    May 16 2008
    WA
    Could have dirty lenses, but bulbs dont maintain consistent lumen output after hours (let alone years) of use:
    http://www.hidplanet.com/forums/show...put-Comparison
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    The reflectors burn up on our cars. At least that is the prob on most I have seen with dim/weird light output.
    Has anybody mentioned swap bulbs side to side to make sure it isnt the ballast first?
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
