Results 1 to 12 of 12
    Senior Member Two Rings MGuruX's Avatar
    May 20 2012
    Sold: 2009 Audi A5 3.2L S-Line | Sold: 2008 Audi TT FWD - Ice Silver with Magma Red interior
    Regular fuel on 3.2L
    Hi,
    Sorry if this is a repost but read on my A5's users guide that you can get away with regular fuel instead of premium. They still recommend premium but not a problem saving some money
    Can anyone confirm this? I know with turbo engines it is mandatory to put premium but what about 3.2L? or even 4.2L?
    To clarify, I traded in my Audi TT and got a 2009 A5 3.2L S-Line....I know it is used/old but new to me
    2012 Phantom Black TT-RS Plus
    Black Optics Package | 19x9.5 Rohana RC22 Wheels | Sport Exhaust
    Veteran Member Four Rings Not A Good Idea's Avatar
    Apr 26 2012
    Hmmmm...
    Li. Ny
    you can but do not go WOT. if you must atleast use an octane booster.
    Established Member Two Rings tokarsqi's Avatar
    Apr 21 2012
    seaford ny
    Don't do it!! you simply asking for trouble. this engines run on even better gas in europe than premium gas. Premium here is regular in europe, anything below 91 octane rate will damage your engine parts like catalytic converters and they are super expensive. Another issue is premium gas burns cleaner and engine uses less gas, if you use regular gas engine is forced to put more gas to combustion chamber in order to make up the power...conclusion is that at the end of the day you not gonna save any money.
    Oct 30 2012
    Florida
    Get a credit card that gives you good cash back on gas, fill up with premium, end of the month make up your losses...
    Veteran Member Three Rings Audiforumuser's Avatar
    Mar 01 2010
    2010 A4 Avant S-line
    Saskatchewan
    Check this out. They don't test a vehicle designed for higher octane fuel but the other results might be of interest and help you form your own opinion.
    http://www.cbc.ca/marketplace/episod...mpfiction.html
    09 A5 S-line Monza Silver / Incurve IC-S10 20x10.5 / KW H.A.S.
    Veteran Member Four Rings DeMOROlized's Avatar
    Sep 18 2006
    GTA Canada
    Quote Originally Posted by tokarsqi View Post
    No they don't. They just use a different octane rating scale in Europe (RON) than us (AKI). Premium 95 RON in Europe is about the same as Premium 91 AKI in North America.
    Quote Originally Posted by Audiforumuser View Post
    That report is a load of crap. Of course you won't gain any performance by putting premium grade fuel in an engine designed for regular grade. But the reverse is not true.
    1st Ring: 2002 Dolphin Grey B6 A4 1.8TqMS
    2nd Ring: 2006
    Moro Blue B7 A4 2.0TqMS
    3rd Ring: 2010 Phantom Black B8 A5 2.0TqM S Line
    4th Ring: TBD
    Oct 08 2010
    CA
    You're saving maybe $2-3.00 a fill up by using a regular grade instead of premium...I know it's a tough economy, but c'mon now, feed your A5 well!
    Previous
    2009 GT-R | 700HP
    2008 S5 | Ibis White
    2008 A5 | Matte Gray
    May 29 2012
    Palo Alto, CA
    why getting an A5/S5 in the first place if you are not worried about gas price? I wouldn't recommend anything below 93 on either the 2.0T, 3.2 and 4.2.
    95 is Europe's regular gas, 98 is premium so imagine what 91 will do to your engine eventually.
    May 20 2012
    C'mon...
    I used to have a TT which btw had to put premium gas...93-94 octane every time.
    What I was trying to see if you were aware of that option, even included in the user's manual. Still, I will use premium fuel on mine...
    In regards to the report, I agree that it is misleading as they dont present all options with different engines.
    Sep 18 2006
    GTA Canada
    Quote Originally Posted by NYCBOY View Post
    They use a different rating. Their premium is the same as our premium.
    2nd Ring: 2006
    4th Ring: TBD
    May 20 2012
    ^ True
    Veteran Member Four Rings Raser's Avatar
    Jul 28 2012
    Rodents, arachnids, other scurriers and crawlers
    Northern VA
    As well as getting premium fuel, try to limit the amount of ethanol. Ethanol free fuel is the best since ethanol has lower free energy than pure gas and tends to leave residue on valves. My owner's manual states that 10% ethanol is the maximum allowed and I have recently seen stations around with 15%.
    AKA: RS Fünf
