Results 1 to 6 of 6
    Mar 30 2012
    VA
    AUX Input for B7
    hey guys,
    i have a 2008 Audi A4 2.0t S-Line with the rns-e/bose audio package. i have the ipod adapter thats located inside the glove compartment but no more ipod. im trying to hook up and 3.5mm headphone jack input. is there a way to connect directly to the aux-in wire so that i can play my music. i tried using an adapter that has RCA on one side and the other side is positive and negative wires to connect directly but no luck. i tried splicing into the blue harness behind the radio which has the aux in L and aux in R wire as well as the common ground wire. is there a "turn on" wire that needs a signal/power first so that the radio will recognize that theres an outside source plugged in. i hope this description is somewhat clear and understandable. thanks guys
    Jun 27 2011
    Theres a DIY in the tech section for doing this to a Symphony2+. I believe the RNS-E is the same:
    http://www.audizine.com/forum/showth...or-Symphony-II
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Mar 30 2012
    VA
    its almost similar to this write up but the rnse has much more wire on the blue harness. and i believe the input on the rnse is the "CDC" wire? i guess cd changer? theres also a 32 pin harness input thats behind the radio the has an "AUX" wire but i dont have that harness connected i guess my car didnt come with it
    Mar 30 2012
    VA
    this is more like it. but i need VAG-COM for it? damn. i guess i should get that too. but atleast now i know, thanks guys. great help. much appreciated
    Veteran Member Four Rings fordyoz's Avatar
    Apr 20 2011
    Philadelphia
    there are like 4 DIY's for this on here...
    Borg Warner EFR6758 B7 A4
