Results 1 to 3 of 3
    Active Member Two Rings Cj1976's Avatar
    Sep 23 2012
    2000 Audi A4 1.8t quattro
    Madison, Wisconsin
    P0113 code Intake air sensor high please help?
    Check engine light came on again, and this time there is a new code, P0113 Intake Air Temp Sensor. Is there a separate sensor for this like one on the intake manifold or does the MAF sensor do this. This code had never came up until I just cleaned my MAF for the first time. I used MAF cleaner, cleaned air filter and reassembled. Could this just be coincidence that it failed or maybe I sprayed a little to much oil on my filter and it got on my MAF? Could the air temp coming past the MAF have ant effect on this? Any suggestions? Clean MAF again and clear code? How can I tell if my MAF sensor is bad?
    Jul 27 2011
    IN
    In 1.8t's the IAT sensor is located on the intake manifold, right next to the throttle body.
    You need a 5mm allenhead/hex to remove the sensor.
    Sep 23 2012
    Madison, Wisconsin
    great Im going to pull it and clean it and try and see if that works.
