How many if you using ball bearing turbos also use an oil restrictor?
Eric
-CP
2008 2.0t S-Line Ti 6MT Avant
2017 Q7 3.0t
Former USP CLUB MEMBER #136
Epy
17 R8 V10 Plus Dynamite Red
24 RS e-tron GT Suzuka
Epy
05.5 B7 A4 longest running with no motor issues at 373whp
Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
-Shane Drake-
2006 A4 Avant Dolphin Grey
2007 GT3071R A4 Moro Blue-RIP
>DRAKLOREs Build<
Formerly DRAKES-PERFORMANCE
Epy
-Shane Drake-
>DRAKLOREs Build<
Epy
Epy
Epy
EFR | 7163
268/260 cams
I.E. Intake Manifold / 70mm
BoostManager+
Meth Head
Borg Warner EFR6758 B7 A4
EFR | 7163
268/260 cams
BoostManager+
Meth Head
Epy
Epy
-CP
2017 Q7 3.0t
Liquor in the front Poker in the rear - Reverand Horton Heat
Epy
Epy
EFR | 7163
268/260 cams
BoostManager+
Meth Head
Epy
