Results 1 to 11 of 11
Thread: Allroad towing
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    Allroad towing
    Looking to get an allroad.
    4.2 vs 2.7T. My choice would be the 2.7T...but the 4.2 Version has a decently higher towing capacity? Why is this? The power of the engine?
    Whats with the bags? If i swap to coilovers, will my tow capacity drop?
    Simple stage 2 tune and some straights to resolve that issue?
    Would be buying it to mainly tow my A6 to the track and such...
    Jun 27 2010
    2002 Audi allroad 2.7T - GIAC Stage1
    Palm Desert, CA
    The 4.2L V8 has tractor-like torque. As mentioned in a previous thread - I saw German-spec allroad 4.2 barrel past my rental VW Golf, on the Autobahn pulling a 20ft sailboat @110mph( I was doing 97mph)....I thought to myself, "that's nuts!"
    Veteran Member Four Rings MYDWAGON's Avatar
    Jul 08 2007
    Ohio
    The 4.2 has superior brakes and a better tip.I think the difference in tow ratings only has to do with government specs and the fact that euro trailers are balanced differently
    04 4.2 Allroad w/H-Sports-Full Tint-Armorcoat- RS6 Exhaust/Gutted Kitty-Flaps-Michelin Pilot Sport A/S Plus-Thule Box-OEM Trailer Hitch-226k
    Veteran Member Four Rings audifirst's Avatar
    Feb 08 2005
    C5 A6 Avant, VW Golf TDI
    Ontario, Canada
    Problem here is that no one sells original equipment hitches for Audi dealer doesn't sell like they do in Europe you have to go aftermarket which limits the towing capacity because the way it aftermarket mounts and they are for Class 1 or you are lucky if you find one for Class 2 type hitches..
    If you place to tow large trailers, get OEM hitch it will cost you from 800-1000 if you buy from companies that import them or 400-500 if you buy directly from Europe , but exchange will cost you
    Oem hitches can handle large loads, do search there are several post in this forum about this one
    like this one
    Difference in Audi B5 A4 Clusters Click Here
    Difference in Audi C5 A6 Clusters Click Here
    Replace ABS module in A6 Click Here
    DIY-Rear-Differential-Seal-replacement in A6 Click Here
    Veteran Member Three Rings G0to60's Avatar
    Oct 25 2011
    90 Corrado, 02 allroad
    Milwaukie, OR
    The 4.2 and the 2.7 have the same tow rating in the US. It is 3300 lb according to the US testing. In Europe the allroad is rated at 5000lb but I'm not sure why they would be different aside from different testing procedures.
    As far as tow hitches I would only get the Euro version (like what Bosal sells at ~$800 or user JustMtnB44 makes one for ~$600) since it bolts into the correct location in the rear frame rails and is hidden when not in use.
    If you are going to change the suspension to coils make sure you get the correct spring rate for what you are towing. Too soft and you'll bottom out but you don't want them too stiff or it will be a rough ride. I would consider keeping the air suspension because it will self level when you tow which is a nice feature.
    Later allroads are said to have an improved torque converter if you are going for a TIP but if an early one has had theirs changed it will work just as well.
    Feb 06 2012
    Lake Lanier, GA
    Yea, deff wouldnt want a 6 speed for towing. Looking into 4.2L Allroads 03 and up at the moment.
    Jul 08 2007
    Ohio
    V8's are only 04/05
    Feb 08 2005
    Ontario, Canada
    if you have tiptronic ,if you plan to tow a lot you need to change transmission fluid before you start doing towing and then at least once a year fluid change keep the transmission in good shape.. if you tow once a while then you be ok but still need to change at least every two years..
    Senior Member Two Rings JustMtnB44's Avatar
    Nov 22 2009
    Pittsburgh, PA
    Quote Originally Posted by aysix View Post
    There was another thread talking about this just the other day...here it is http://www.audizine.com/forum/showth...d-over-my-Baja
    Towing capacity of the two engines is the same.
    Coilovers instead of air springs will mean you lose the load leveling feature of the rear suspension, so tongue weight combined with stuff in the cargo area means the rear of the car will sag quite a bit. It won't reduce the capacity but might make the car handle poorly.
    If you are going to be towing an A6, which is not a light car, I would be looking for a truck not an allroad.
    Quote Originally Posted by MYDWAGON View Post
    Some 2.7T's have the same front brakes, although I believe only the 4.2's have the vented rear brakes. Transmission for all intents and purposes is the same, although since V8's are later model years they get the updated torque converter.
    Current: 2016 Golf R
    Past: 2004 allroad 4.2, Ebony Pearl Effect FBP, H-sport sway bars, Phatbox MP3 player, stock 18" wheels with Continental DWS tires, stock 17" wheels with Yokohama Geolandar tires, custom tow hitch
    Feb 06 2012
    Lake Lanier, GA
    I hate trucks, which is why i'm looking at an Allroad. Would be looking at a Toureg although the price is still pretty high up there...
    Still keeping options open though, I suppose.
    What would you guys tow a car with...?
    Oct 25 2011
    Milwaukie, OR
    If you want to tow your A6 you are looking at ~4000lb for just the car. Then you add in ~1500lb for a lite weight trailer and you're already over the allroad's limit. That doesn't even count any spares, tires, tools, fuel, food, etc (assuming you're going to the track). You're best bet will be to get something with at least a 7000lb limit which is going to be the trucks and large SUVs (Land Rover, Tahoe, Armada, Toureg, Q7 etc.).
