I have the same sound symptoms as ttuned audi in thread Strange Noise from engine,
BUT, i do not follow the same visual symptoms of low Power steering fluid...I indicate over MAX. Steering is still strong, the noise is just terrible though. I did read in the book with the car pg236 "When engine is running, never hold the steering wheel turned all the way for more than 15 seconds. The power steering pump will overheat hydraulic fluid.likely to damage p/s system.
I little to never park with the wheels cocked, certainly not to the stops. Does this actually happen to people? Did it just happen to me?
Most replies to the previous mentioned thread suggested low P/S fluid causes this sound, so since my levels are okay, is mine cooked/soon to be cooked?
Like I said, I have a little over MAX level P/S fluid, The coolant level is just bordering MIN. Oil is on point.
Also discovered leak, dripped out drain hole front left, plastic "protective plate".-- POWER STEERING FLUID
Please, help before I have to sell my soul to pay off the Dealership Fatcat'$ maintenance garage.
