Results 1 to 28 of 28
    Sep 14 2006
    White exhaust smoke
    I'm having a lot of white smoke coming from my exhaust. I'm thinking it could possibly be a blown head gasket, but I don't know what causes it. Overboosting perhaps?
    I don't think it's the turbo, but I haven't tried boosting because I'm afraid of progressing any damage.
    My coolant level is still at max with no evidence of any leaking and I'm not overheating. I did however find some oil around my valve cover and another part of the engine. Checked my spark plugs and there's no oil on them. A leaking valve cover gasket won't cause white smoke right?
    valve cover gasket
    another leak (pic taken from underneath the car)
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Jul 07 2009
    Lebanon
    Damn, I wish I could help you out Tommy but I'm not sure what to tell you.
    Good luck. I'll definitely be following this thread closely....
    SOLD: 2010 A5
    Veteran Member Four Rings osideaudi's Avatar
    Jan 30 2012
    Maine
    When was the last time you changed the oil? excessive oil can cause it. It's a mess especially if it gets into the air filter. I was going to say the coolant too, but since you said the levels are fine then it would have to be a REALLY slow leak.
    Vic
    Future:
    '17 Audi S3 - Nano Grey
    Current:
    '16 BMW F83 M4 - Alpine White
    Previous:
    '16 Audi SQ5
    '11 Audi B8 S4
    '08 Audi TT
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    do you notice it only on startup or is it all the time? is there any tint of blue in the smoke?
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Sep 14 2006
    Quote Originally Posted by osideaudi View Post
    I change it every 5k and it happened to be yesterday before I changed the oil
    Quote Originally Posted by jlaudio View Post
    All the time, it's just completely white. Not black/gray, or blue....kinda worried, especially because warranty probably won't cover it
    -Thomas
    Current: /S3
    Mar 28 2009
    Minneapolis, MN
    White smoke means you're burning water or coolant. Blue smoke means you're burning oil.
    Jun 23 2012
    San Diego, Ca
    My guess would be that the head gasket is damaged and is leaking under boost. This will absolutely cause white smoke due to coolant leaking into the cylinders and burning. Hard to say how much coolant it would take to produce the smoke you are seeing. Cracked head/block are the other alternatives, but that would likely be more obvious.
    Maybe it is just normal water vapor condensing from the exhaust due to low temps and high humidity?
    Veteran Member Three Rings eyrah's Avatar
    Dec 17 2011
    Southern NJ
    i wouldn't worry about it, its probably just moisture leaving your exhaust, i had this yesterday too in the middle of the day when it was 75* out after a short trip, my thoughts were i didn't let the engine/exhaust fully warm up from the trip when i parked and shut it off.
    - Pauly
    2009 Audi A4 Quattro BB/B
    AprTuned, Apr quad tip, CTS Testpipe, Eurocode HFIP, LED interior pkg, 15%/35% tint, Bi-xenon, VAG, AWE Custom valance, Customized Grill, RS6 Shift Knob, Aluminum Pedals, ST Coilovers, VMR 713
    Build Thread
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    i noticed the same thing when i drive off after starting the car
    2010 A4 quattro, Tiptronic, Ibis White
    Sep 14 2006
    No, this isn't smoke from condensation. That'll happen to any car that starts up in the cold. The smoke is white and it's a lot kinda like this, but not as much smoke:
    -Thomas
    Current: /S3
    May 01 2011
    Ottawa, ON, Canada
    If your oil and coolant levels are fine and you do not see any evidence of oil in your coolant or coolant in your oil, could you have inadvertently put diesel into your tank?when did you last put fuel in your vehicle? was it just before the smoking started?
    Larry
    2010 A4 2.0TFSI Premium+ S-Line with: APR S3 K04, APR TBE, Q5 (Brembo) front/S5 rear calipers & rotors, APS+, Podi Boost Gauge, FMIC (3.0TDI), Hill Hold Assist, Auto High-Beam Assist, AFS Headlight, TTRS flat-bottom multi-function steering wheel, GFB DV+, Bilstein B8 Struts/Shocks, Alu Kreuz, Apikol diff mount, folding exterior mirrors
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    Quote Originally Posted by larrylam646 View Post
    Larry
    He would have a lot more problems had this happened, it will usually stop it all together.
    Veteran Member Four Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    It isn't just because of a test pipe is it? Or is it a new issue?
    2010 A6 3.0T Prestige, Quartz/Black
    35% Tint, VCDS, Hardwired V1, LED Interior/License Plate, Chipwerke Pro, WeatherTech
    Previous: 2011 A4 P+, APR Stage 2, 35% Tint, Eibach Pro-Kit, VCDS, Gloss Black Grille, Fogs,
    LED Interior/License Plate Lights, Short Shifter, BFI Catch Can, V1, Rieger Lip Replica, FRT's FMIC, aFe Filter
    Sep 14 2006
    New issue and no, I've never put anything other than 91 octane in my car (we don't even have 93 here)
    -Thomas
    Current: /S3
    Senior Member Three Rings audinepa's Avatar
    Jul 29 2010
    2009 Audi A4 B8, 2007 GMC Envoy XL
    NEPA
    From Answers.com maybe this will help you:
    •It often means that you are burning antifreeze. You asked if it needs antifreeze, have you noticed any leaking out of the reservoir tank while you are running it? Sometimes when the head gasket goes it will produce a passage for the antifreeze to pass from the capillaries into the combustion chamber. It is easy to check if you have an air compressor. Remove one of the rear sparkplugs and the radiator cap. Fill the radiator and then push some air into the sparkplug hole (get a good seal in case a valve is open). Repeat with all the cylinders and watch for air bubbles coming up into the radiator. If bubbles come up or fluid is pumped out, the head gasket is blown and must be replaced. It is more likely to happen at the back of the engine because it is farthest away from the fan and therefore gets less cooling. Also check your oil for discoloration. If it is a brownish color it could mean your oil and antifreeze are mixing and has the potential to damage your bearings.
    •If the exhaust billows white smoke for a few seconds when first starting the engine after it has been sitting for a while, such as overnight, and then runs normally, it could mean that the rubber valve stem seals have perished - especially if the vehicle is a few years old and has done over 60/70,000 miles. Another clue is: does the exhaust smoke smell like fresh, rather than burnt oil.
    •After going nuts trying to figure out sporadic tailpipe smoke on my Nissan Maxima, with no other negative engine symptoms, I eventually stumbled upon a malfunctioning PCV valve. The ball-check wasn't fully seating, allowing small amounts of oil to sneak past and into the combustion chamber. A cheap and easy fix.
    •White smoke or semi white can be produced in several ways. One way is oil this is normally a whitish blue to blue smoke and has the apparent smell of oil being burned. Next could be antifreeze when it is being burned it has a sweet type of smell and tends to dissipate in the air rather quickly. Next is automatic transmission fluid which is normally found on automatic transmissions and its normally drawn into an engine thru a vacuum line via a defective transmission modulator valve or some other defective part. Transmission fluid is very apparent and billows out so bad that you can't see anything behind you. Last but not least another type of smoke that is not white but black is the presents of to much gas/fuel being burned in the engine. PS the one good thing about transmission fluid being burned is it is an excellent way to clean the carbon out of an engine.
    •Black smoke is burning oil. Blue smoke is usually transmission fluid due to a leaking modulator valve in the older auto transmission. White smoke is due to water getting in to a cylinder from a bad gasket, cracked block or a cracked head. cracked heads. Mine started misfiring, with new plugs. Smoke came out the exhaust. Result, low compression in the cracked head. When car was cold it ran fine. After it got hot, the crack in the head would open up, hence, sputtering. I've had to replace 3 heads. Everytime I've had to have this done, I had to buy a whole new head gasket.
    •After extensive research I came to the conclusion that TOO much oil is also a main culprit for white smoke out of the exaust.
    •I changed the PVC valve, the breather and the air filter and it's good as new.
    •There are a lot of incorrect answers here... but for the most part, you can hold true to these: Blue smoke is primarily from internal engine wear. If it's constant when the engine is on, then the rings etc are worn and need to be replaced. If it only is blue when the engine is cold or first started, the rings are worn but not gone completely. You get the oil seeping during the night and it burns off when the car is started in the morning. Black smoke is a fuel/air mixture suggestion problems with injection or carburation. Cause of black smoke is due to running rich in the fuel air mix. White smoke can and DOES come from coolant burn off in the oil due to a leaking or blown head gasket, cracked head etc. If you aren't sure or you don't know what you're talking about, don't advise. Wrong advice can be more damaging than the actual problem.
    •White smoke is caused by engine coolant/Antifreeze being processed in the combustion chamber(s) of the engine.....ie burning, melting, frying, whatever....Period....I'll explain further.... This is automotive chemistry 101....Oil of any automotive type burns blue.....too much fuel issues burn black not enough fuel issues burn grey on a cold day you may see what appears to be white smoke from the exhaust that will disappear after the vehicles engine has warmed up to it's normal operating temp.. This is a normal reaction called condensation... condensation is the result of a small amount of water/dew being drawn into the exhaust usually collecting in the muffler and/or the catalytic converter and is caused by our friend mother nature..... like when you see your breath on a cold day...
    •I am a highly experienced ASE certified automotive repair tech. I have over 16 years of diagnostics and repairs to my credit..I have made a very good living in the automotive business by being precise with my diagnostic procedures....I have worked for 3 of the largest rental vehicle companies in the country.... I have diagnosed and repaired an estimated 200 vehicles to date with the white smoke issue... every vehicle that i mentioned had engine coolant/antifreeze entering one of the combustion chambers in the engine... Most of these vehicles had a damaged head gasket(s).. the most common causes of this issue that i have detected over the years are due to improper maintenance of the engine cooling system, severe overheating of the engine, improper tightening of the cylinder head(s) during an engine overhaul,or some other type of repairs that required the head to be removed and also defects in manufacturing of the gasket or the engine... i have seen evidence of careless repair techs that have scratched or cut the surface of a replacement head gasket with either a tool or the cylinder head during the install process.. sometimes it will never cause an issue but it can... i am very careful when dealing with any gaskets but especially head gaskets due to the amount of work involved in replacing one on some vehicles.. bottom line, I'm not fond of doing the job twice so I'm careful the first time... I have seen improper cylinder head or engine block servicing techniques cause failure of the gasket(s) these types of failures are generally caused by improper cleaning of the gasket surface of the engine block and/or the gasket surface of the head.. i have also repaired or replaced cracked heads and in extreme scenarios i have replaced cracked blocks and severely overheated engines with a new or re-manufactured engine due to such severe damage to the internal engine components or block .. There are a mix of correct and incorrect answers to your concerns by the participants that have replied.. I can assure you that almost every well trained tech will answer your questions as i have.. I'm not saying I'm an automotive god, I am just proud of the priceless knowledge that i have acquired...FYI, I'm a graduate of Denver Automotive and Diesel College in Denver Colorado.... DADC is one of only two Automotive Technology colleges in the country with the intense hands-on and classroom teaching practices to properly train a truly, highly skilled automotive/diesel tech who can easily handle any diagnosis and proper repairs of yesteryears and today's automobile technology....
    •White smoke CAN be caused from oil....I have fast-road engined 1987 Golf Mk II. If I boot it hard on tight corners, roundabouts, etc, it can cause oil surge in the engine and some oil can 'slop' into a cylinder. The James Bond style smokescreen it produces can be very exciting for drivers behind me!
    •Lots of good answers; I just want to see if I can clarify from my experience. SMELL!! Good mechanics without great diagnostic tools learn to SMELL. "Burning" (yes, technically it's boiling, not burning) Antifreeze smells 100% different than burning OIL. Let your nose be your guide. The Antifreeze will have a sweet sort of smell--hey--kinda like antifreeze smells, and it will make your eyes tear up and your throat lungs will tell you to get out of that toxic fog right away. Also--the timing. Yes, when forming a good question, you need to give GOOD DETAILS. Does it ALWAYS burn white? Just at startup? Only when hot? Etc. DESCRIBE, DESCRIBE, DESCRIBE!!! A head gasket problem is ALWAYS there and it only gets worse under pressure/acceleration/load. It will go from a little cloud to it's own weather system when you stomp on the gas.
    •OVERFILLING THE OIL will produce this white burned smoke too. Yes, it will SMELL different. IT will also usually go away after some driving. CHECK THE DIPSTICK, it's obvious, but do it--do it right. Flat surface; cold engine. Pull--Wipe it off--put it in--now you are getting the real level. Oil burning will be at startup from worn valve rings/seals and during driving from overfilling at first a lot, then only at heavy acceleration/g forces when demand is high. Again--smell, check all your fluid levels (OIL, WATER, TRANS) of course, whatever is low is what you are BURINING (or for the one gent that gets particular, boiling). ALWAYS Start w the simplest thing or the cheapest. Did you just change the oil and it started--overfilling, etc. Yes, it won't hurt to check the PCV valve and tubing. Really, check all you can check.
    •My problem with white smoke was whenever I would be going down the road at high RPM and let off the trottle. Then it was like a smoke bomb went off. Bottom Line.......... My Vacuum Modulator went bad on my transmission whenever high vacuum was created it was sucking transmission fluid into my intake manifold and thus into my combustion chamber creating white smoke. Replaced the modulator for $12 and everything is right with the world
    •i had the exact problem with my Mazda down to a T. All we had to do was buy a bottle of engine sealant... it takes a full day to run thru so follow directions exactly. Now the car has no problems... full power is bacl no more "smoke bombs" and no more dying at strange times.
    •Steam or smoke is the question here. If its steam some considerations are what year is the vehicle newer catalytic converted cars emit steam and water from the exhaust and you should be cautious about the blown head gasket or cracked head syndrome, if you suspect a blown head gasket or cracked head go to a reputable shop that can confirm exhaust gasses in the coolant. You will notice a low coolant level and a peanut butter looking substance on the oil cap (possible traces of water and coolant in the oil but generally engine pressures will prevent this. Be prepared for the worst and hope for the best. If it is smoke a thick white smoke it could be transmission fluid being pulled up through a vacuum line to the intake manifold and being burned, this was quite common on older Ford and Chrysler vehicles that had a vacuum shift solenoid and an automatic transmission.
    •Has your car severely overheated recently? Does the smoke smell like antifreeze? If it does, you probably have a blown head gasket. The "smoke" in this case is actually steam from water leaking into the cylinders. Also check for yellow or white goo on the oil cap and dipstick, indicating water leaks to the oil.
    •Your symptoms are indicating a possible head gasket problem. You have water going into the combustion chamber and coming out the back tailpipe as steam. You may also have exhaust gas in the water which can also be checked by a mechanic. Be prepared for the expense of a head gasket or possible engine replacement.
    •If it is not happening all of the time at operating temperature (head gasket as mentioned before) and it occurs just at startup. It may be that due to heavy moisture in the air, dew, a heavy rain, will build up moisture in your exhaust system. At initial startup until the vehicle is warmed up and run for a bit, you may see thick white smoke.
    •I had an old engine that sucked oil through an intake valve when the engine went fast enough. If you burn enough oil it looks white. Especially in Michigan on a cold morning.
    •I had this problem with my '96 Ram after an overheat. A cracked head gasket was allowing antifreeze to get into the combustion chamber and creating all kinds of white 'sweet smelling' smoke.
    •White "smoke" in cold weather is just steam. When gasoline ignites it produces quite a bit of heat and expands to several times the original size, creating high pressure on the piston. That pressure causes the piston to move down, turning the crankshaft which makes the car go. When the fuel ignites it causes a sudden and violent chemical reaction between the the oxygen in the air and gasoline (which is a long chemical molecular chain of carbon and hydrogen) resulting in carbon dioxide and water vapor. As the water vapor cools in the exhaust pipe it starts to form small droplets that are visible in the form of steam vapor. That's the white smoke. Once the exhaust pipe warms up sufficiently, the exhaust leaving the pipe is still hot enough that the water vapor hasn't formed the droplets and dissipates quickly enough that you don't see the vapor. On the other hand, if it's light blue or blue-grey smoke and it doesn't stop when the exhaust pipe warms up, that's oil vapor and a sign of bad rings and/or valve stem seals.
    •white smoke is usually caused by condensation in the combustion chambers. This will usually dissipate once the car has warmed up. If it persists there could be difficulties with: Problem: Solution: Moisture in fuel Apply one cap full of Methylated spirits to fuel tank (This is quiter safe by the way, it dissipates water) Head gasket leak Replace head gasket, approx $500 AUS (other symptoms such high temperature will also be prevailent.) Failing these two suggestions, there is a slight chance of moisture in the oil sump. this is rare if the head gasket is ok. Simply check your oil level, if the oil looks milky, there's the problem. Also if it is milky, replace the head gasket.
    APR stage II, 034 Motorsports HFC, AWE dual quad tip (diamond black) exhaust, plasti dip grille, splitter and rims , all weather floor and trunk mats, vw oil dipstick, mirror covers sprayed alum/matte, red acrylic painted calipers, Vortex tuning spacers 15MM front, 20MM rear spacers, Rieger style roof and trunk lip spoiler, tinted windows 35% sides and back, 20% strip top front.
    Veteran Member Four Rings jbradle7's Avatar
    Jan 09 2010
    GX460; MK7.5 GTI; WK2 Grand Cherokee; 73 Triumph TR5T
    St. Louis
    Quote Originally Posted by audinepa View Post
    You can try this also
    http://www.youtube.com/watch?v=qIgOg9HSEow
    or
    http://www.youtube.com/watch?v=QA7KV...feature=fvwrel
    Jan 14 2010
    Georgia
    How is your car doing?
    Senior Member Three Rings Bonger's Avatar
    Nov 18 2009
    2004 4Runner Limited, Look 586, Salsa Big Mama 29
    Torrance, CA
    Holy crap that Scotty guy is annoying. Good info though.
    Isn't your car still covered under warranty? If so choose a mod friendly dealer and get it looked at under warranty. I met with the guys from DCH Audi in Oxnard during the 10/28 SCS GTG and they were great and told me to stop by anytime. Call in advance and they may even set you up with a new S4 loaner...
    2010 Audi A4 Avant APR Stage 3
    Sep 14 2006
    Hey guys, so I found a kink in a hose going to my catch can so I removed the entire thing altogether. White smoke is gone! I think the blockage was causing pressure to build up in the PCV system. Anyways, I also installed the eurocode silicone hoses and the throttle response feels great paired with my FMIC. My car is exactly where I want it now....it's rare, but I'm satisfied with her lol
    -Thomas
    Current: /S3
    Nov 18 2009
    Torrance, CA
    Excellent. You didn't make it to the 10/28 SCS event. Are you going to the San Diego Euro Car event? We still need to compare setups. Looking forward to it bud. Glad your ride is back to normal!
    Sep 14 2006
    Ya with my school schedule, San Diego and SCS is a little too far for me right now. I definitely want to meet up with you to check out your ride!
    -Thomas
    Current: /S3
    Senior Member Two Rings jaysen's Avatar
    Oct 30 2009
    woo-hoo! glad to hear she's back ;) very glad it wasn't anything major... you ever get your fumoto (sp?) oil valve installed... I'm gonna be changing my oil again shortly, wanted to see what your thoughts were on it if you had installed.
    Veteran Member Three Rings STA4's Avatar
    Jan 12 2012
    Mississauga, ON, Canada
    Just wanted to share my story to help the community. It's been pretty cold lately (Polar Vortex...haha) and yesterday morning soon after I left the house I was sitting at a light when:
    - Idle started going rough
    - Smoke came from engine bay
    - Smoke out of exhaust
    - Oil buildup near oil cap
    - Oil spray near front passenger side of engine (onto intake pipe, etc.)
    I shut the car down immediately and had it flat bedded to a shop.
    I did some reading and found this thread along with this one: http://www.audizine.com/forum/showth...-2-0TFSI-gurus!
    I have a Black Forest Industry oil catch can (BFI OCC), but I had just emptied it last week. I suspected that one of the lines to the OCC may have been building up ice during the cold weather (there's a dip in the line forming a U) and gotten clogged causing a build up of pressure. I told the guys at the shop to try firing it up this morning after the car had sat in their heated garage over night and sure enough the engine is no longer burning oil. It seems that my suspicion was correct.
    I'm going to try see if I can raise the line from the oil separator so that it empties into the OCC. I may also flush it with alcohol during our next polar vortex. Not sure where the oil squirted out, but will monitor that closely for the next while.
    Peter
    2009 A4 2.0T Quattro Premium 6MT
    Meteor Grey/Black | B&O | STaSIS Tune/Exhaust/Springs/RSB/Wheels | K&N Filter | Eurocode TIH/HFIP/IHK/HFC/Alu Kreuz | GFB DV+ | R8 Coilpacks | Strat O2 Spacer | BFI OCC | Podi Boost Gauge | Rieger Rep Spoiler | RS4 Rep Grille | A4L Foglight Grilles | LED Interior/Puddle/Plate/Signals | Morimoto 5500K HID Foglights
    Oct 02 2006
    Wadsworth,OH
    Blocked up PCV will definitely cause a vehicle to smoke more at idle and push clouds through the exhaust. As long as your fluid levels check out it would be safe to say it's majority of the time related to PCV.
    Jason
    Established Member Two Rings zzDuality's Avatar
    Jul 24 2013
    Audi a4 b8
    Miami
    valve cover gasket
    Does the white smoke persist after the car has sat idle ? or does it stop shortly after turning on the car? Does the exhaust smell like fresh or burnt oil?
    This kind of sounds like an oil issue, did you check to see if the PCV valve is fine?
    White smoke usually happens when there's water getting in to a cylinder from a bad gasket or cracked block or a cracked head
    Jan 12 2012
    Quote Originally Posted by zzDuality View Post
    His problem was solved. Kink in OCC line.
    Peter
    Jul 24 2013
    Audi a4 b8
    Miami
    Awesome :)
    Jun 03 2015
    kauai hawaii
    you are awesome. so. long and the short. bought the audi ten days ago. Did not get a chance to change the oil etc. It has had all the regular maintenance and had the water pump and a few valves replaced last year less than 3k miles ago.was sched to do the oil change tomorrow. Two days ago, my check oil light came on. It needed two quarts(takes 7) of full synthetic oil and a lot of coolant. of which I accidently added regular coolant instead of specialized audi coolant.. Drove great for 100 miles. Then I noticed the heat gauge was a bit past the mid line and my oil light came on again. Pulled over, added oil and noticed the a small crack in the plastic coolant resevoir at the very top was streaming coolant out. Added a bit of coolant and everything seemed fine. Then today, my oil light came on again. Added oil without checking the dipstick. just assumed it needed it.(i feel like a dipstick for maybe overfilling it).Within two minutes of driving a puff of white smoke came out. And again randomly in 3rd going uphill, made a little slight grinding noise when shifting into 2nd.the sudden dissapaiting puff happened in third gear four times in a 20 mile span. Did not overheat according to the gauge but my engine seemed a bit too hot to me and the coolant is way down. Taking it in to check the head gasket Friday but any ideas I could arm myself with? I checked the cap, seems on right, no milky stuff in oil. seems maybe overfilled but not sure. I'm learning. Don't judge me! haha. My last car was a beast subi. know this car needs to be treated waayyyy gentler.
