Hi, guys,
When the steering is at full lock (either right or left) and start moving, I hear some sort of low groaning noise and feel as if the front wheels are grinding a bit.
FYI, my car is 100% stock.
For example, you're trying to get your car out from a tight parking spot - first you start the car, put the gear in R or D, turn the steering wheel to the full lock position (either side, left or right doesn't matter), then press the gas pedal to move out of the spot fast (as if you're in a hurry).
I've heard some sorta hissing noise in the past from different cars, i.e. Accord, but my 2008 A4 Quattro or 2004 G35 didn't make any noise when this was performed.
I'm wondering if this is a common behavior on A5/S5/RS5, especially 2013 S5, and trying to see whether or not I should have it checked by the dealer.
Would you guys please try this and respond here with the result?
Thank you very much!
