Results 1 to 30 of 30
    Registered User Three Rings
    Oct 08 2005
    New Jersey
    Recently Completed 2011 Audi Q5 2.0T project at EuroTech MS......
    This 2011 Audi Q5 2.0T was scheduled for a stage 1 APR flash, which then jumped to a APR stage 2+ flash with the addition of a Eurocode tuning high flow cat and front mount intercooler. The customer drove it and loved the added power. We then went to the next step which was the APR K04 setup, Audi OEM B8 RS4 Avant brakes front/rear, KW V1 coilovers, Audi OEM titanium package 20's with Michelin Pilot Super Sports, Audi OEM paddle shift steering wheel, and a few other adjustment specs. After driving this vehicle all I can say is WOW, it handles amazing, stops amazing and has insane power. I would also like to thank Alex at Europrice for sourcing and getting the parts and Ryan at APR for the parts and getting the files made. Here are the project pictures.....
    Mar 05 2008
    1999 EuroVan, 2012 Suzuka TT-RS, 2014 CC R-Line
    Missio Viejo, Ca
    This thing is sick! Great job!!
    Veteran Member Three Rings D_Frost's Avatar
    Oct 03 2011
    WA
    Very nice :)
    Hmmm... wonder how much weight do those brakes save...
    Veteran Member Four Rings ThunderDent's Avatar
    Mar 14 2012
    2010 Ibis R8 Coupe 6MT V10 // 2015 Sepang (Stage I) SQ5 // 2018 Galaxy Q7 (Wifey’s)
    Ona, WV
    Very nice indeed ... someone is giving me a run for my money ;)
    My K04 is also on and you're right about the power! And I'm adding the 250 cell HFC, and AWE catback exhaust/downpipe this spring, and updating the APR map to include the high-flow exhaust (gaining another 40-45 hp).
    Also my ST v1 Coilovers by KW will be going on at the same time. I just installed the exact same wheels 3 days ago (good choice), only I went with Conti Extreme Contact DWS high-performance all-seasons instead. Michelin PSS were my second option.
    Couple of questions since you have done the coilovers. How much drop did you do from stock? Any issues with the control arm clearance with your drop? How much negative camber issue are you having, and how are you addressing that?
    My plan is adding a stiffer rear sway bar (STaSIS already ordered), adjustable control arms (ACHTuning) and adjustable sway bar end-links (034 MotorSport).
    Any fitment issues with the Eurocode tuning HFC? I was going to order the 034 MotorSport HFC.
    http://www.034motorsport.com/engine-...i-p-19952.html
    Current Stable:
    •2010 Audi R8 V10 Ultra Ibis White—Black/White Stitching (6MT)
    [Nemesis/APR/Carbon Fiber/GT/Euro/LMS]
    •2019 Audi RS3 Nardo Gray—Black/Red Stitching (S-Tronic/Daily)
    •2018 Audi Q7 Prestige 3.0T Galaxy Blue—Black (Wife’s Ride)
    •2018 VW Golf S (Daughter’s Ride)
    Past Whips:
    •12 WRX Dark Gray Metallic (6MT) •11 Audi Q5 Ibis White (APR Stg 3) •12 VW GLI Tornado Red (DSG) •16 Audi Q3 Hanian Blue •15 Audi SQ5 Sepang Blue (EPL Stg I) •19 VW GTI SE
    Senior Member Three Rings Boom's Avatar
    Oct 29 2012
    08 Jetta
    VA Beach
    How do these coils ride compared to stock suspension?
    Oct 03 2011
    WA
    Quote Originally Posted by Boom View Post
    I can't comment for the V1, but having the V2 at softest setting, it's actually a slight bit softer than stock (soaks up bumps better) but more planted than stock given the lowered stance. I'd imagine that V1 would be very comparable, minus the ability to adjust damping.
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    Looks awesome guys, glad I could be involved!
    Alexander van Gerbig
    www.europrice.us
    [email protected]
    Mar 14 2012
    Ona, WV
    Thanks for the informative write up. A couple of points I had from my experiences.
    I too had my rep talk with Ryan and Brent from APR, as I was getting the K04 turbo and ECU stage III map on my Q5... Ryan actually used to work with the guys at my custom Audi shop in Cincy before going to APR HQ in Alabama, and talks with the guys there daily.
    What I was presented with when asking about exhaust, intercooler, etc, was that the APR software was specific to stock vs high-flow, and like you, they didn't necessarily rec'd the exhaust and... they also didn't rec'd a new intercooler on the Q5. The exhaust and downpipe, APR doesn't make for our car, so at the time, I just said okay, I'll stick with my stock exhaust. The intercooler, they also don't make for the Q5. They make a 2.0T intercooler upgrade, but it is for the transverse 4-cyl 2.0T (replacing their much smaller intercoolers), not our Longitudinal 2.0T. I wanted to order the intercooler and upon speaking with APR directly, as well as having my tech speak to them, they said no, no upgrade is needed, that the Q5 has a large 3" thick intercooler and it was more than sufficient to handle the K04 upgrade. The APR tech, upon seeing the car, was actually surprised how large an intercooler the Q5 had.
    The only FMIC I have seen specifically marketed for the Q5 is the one that AWE Tuning makes, and it is the same thickness, just a bit bigger in dimension.
    Now whether or not APR didn't rec'd the upgrades because they didn't make them, I don't know. That doesn't make much sense as they wouldn't be making that money anyway.
    My theory on the intercooler, from everything I have researched on it, is that you have to match the size of the turbo/impeller unit with the proper size intercooler. The Q5 (stock) has a small turbo in correlation to a large stock intercooler. This created lots of turbo lag when the boosted pressure went into the intercooler and expanded into that large space = turbo lag. Not sure what you are feeling with yours, but after upgrading to the S3 turbo and keeping my stock intercooler I have near no turbo lag at all(especially when driving in "M" like you stated), as I think the turbo and intercooler are very evenly matched. Not saying the upgrade is a bad idea, because you probably are experiencing a big decrease in lag as well from the stock turbo, just not sure the FMIC is a needed upgrade. Like I said I was all set to buy the intercooler, but it was APR that suggested I not upgrade it.
    As far as the exhaust goes, I have reconsidered and am going to upgrade. Purely for the sound. The added HP gains are just a bonus, but an increase in +13 is not a huge bonus for the money you pay, I agree. But it is higher flowing than stock helping it breathe better. The stock piping (post-cat) is 2.25". Going to 2.5 with a downpipe of 2.5 or 3 makes a huge difference, IMO. AWE has done studies on this and they have actually shown that at 2.5" the downpipe is at it's most effective, and 3" has no additional gains. Replacing the primary silencer (which is large) with a more efficient resonator or straight pipe also would help with sound and breath-ability.
    I'll have to see what the differences in the 034 HFC vs the Eurocode Tuning HFC. They look similar to me. Not sure the cell count in yours as it doesn't say, but they both should fit as the front side of the B8, A4/A5/S4/S5 exhaust are the same as the Q5. The mid-muffler/primary silencer back is specific to the Q5. I am going to open mine up, add the HFC, add the downpipe and exhaust from AWE, and then have APR remap me for a high-flow exhaust. When APR mapped my Q5 they mapped it for stock exhaust, which is slightly de-tuned from what it could be according to them.
    I am adding a rear sway bar to help with the understeer as well. Thanks to Alex for your helpful advice with this as well. I completely agree with the added weight on the 6 cyl engines. I do think the MLP putting the weight further back is helpful, but the rear sway bar should help with the understeer.
    I know some people are experiencing camber issues after lowering their Q's. I am worried about the internal edge tire wear and am planning on the adjustable control arms, plus adjustable end-links as well. I too have considered the mounting plates, but don't think I'll be going that route. Hopefully any seriously negative camber can be brought back to within spec with the mods I'll be making. Only dropping it 1" all around probably won't throw you too far out of spec. I am hoping for 2" on mine, but we'll see what we can get this spring.
    The brakes, I love 'em. good job man! Big upgrade there.
    Much looking forward to your dyno runs. No one on here has bit the bullet and gone all out to show that on a K04. I am considering it once I get the HFC, exhaust and remap done tho.
    Looking forward to your future posts, you are obviously a pretty knowledgeable poster.
    Current Stable:
    Past Whips:
    Oct 29 2012
    08 Jetta
    VA Beach
    I'd expected a response saying stiffer. lol You like it better the Stock feeling? And random question, how do you like the color Phantom Black? The wife and I are at a toss up between the Black Pearl or Glacier White.
    Quote Originally Posted by D_Frost View Post
    Oct 03 2011
    WA
    Yes, it's better than stock for comfort. With the V2, you can adjust to be much stiffer if necessary. As for the color, it's slightly better than Brilliant Black when dealing with paint imperfections (i.e.: swirls / fine scratches) but like any black car, it's higher maintenance to keep it clean. It's a tough choice...
    Thanks Will... I figured there might be some weight savings due to the 2-piece nature of the rotors and the wave design which eliminates some of the material at the very edge. But I do understand that the rotors (and calipers) themselves are much larger (in diameter) so the difference in weight may be negated. Good find on the brake lines though, do you know if the kevlar lines are part of the RS4 setup or across the Audi lineup?
    In any case, I'd say that's the ultimate sleeper ;)
    Looks like I might have to talk to Alex@Europrice for some brake quotes hehe...
    Oct 29 2012
    08 Jetta
    VA Beach
    Do you have camber issues with the coils? Someone stated that these cars have Camber issues with dropping over 1"? I have been a VW guy for a long time. So learning about Audi as much as I can. Thanks
    Oct 03 2011
    WA
    Lowering about 2" front and back... I was able to get the rears at 0 camber while the fronts run a bit of negative camber. A way to deal with that would be adjustable control arms that ThunderDent is getting. As far as I know, there aren't Q5-specific adjustable control arms but rather for the B8 platform (think A4/A5) out there. ThunderDent will be the guinea pig in this respect... ;)
    Mar 14 2012
    Ona, WV
    A bit of negative camber is perfect really. It will help in cornering for sure. That's where I want to be.
    I'm afraid if I don't do the control arms, that when I get the post drop alignment that it will be waaay off, and then what. Kill my tires in a heartbeat, or raise it
    To the OP, his Q looks like more than 1" drop from stock to my eye at least. Also, to his Carbonio comment. I agree its bling. Its def cool.looking tho. It wasn't for us, so I decided to go aFe Pro Dry S. Easy mod, added hp, better breathability, and no worries about MAF/oil buildup issues.
    Current Stable:
    Past Whips:
    Sep 25 2012
    West Va.
    Very impressive build!
    Veteran Member Four Rings FLYINGLEGGS's Avatar
    May 04 2009
    18 Q3, Chevy Cruze T DD
    Florida
    Looks awesome. Would love to drive it.
    -2019 RS3 DG, BO. APR Plus
    -2014 S4 Misano, BO, Sports Diff, DSG.
    Apr Stage 1 ECU/TCU, Intake
    Stage 1 104 Octane: 11.64
    Stage 1 93 Octane 11.94
    *Sold*
    -2007 A4 2.0T S-Line APR BT Stage III and much more. Sold
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    thumbs up!
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Veteran Member Three Rings Maximum's Avatar
    May 27 2012
    My lounge
    Galt
    I can't show this post to my wife!
    2012 S4 Prestige, Monsoon Grey, STaSIS exhaust/springs, APR Stage II+, RS grill, RS shifter knob, Roc-Euro intake, Ziza LEDs, CREE W16W Reverse LEDs. RS6 flat bottom wheel, MMI 3G+, P3 Cars guage, Passport mirror radar, LI, 034 trans mount & end links
    2012 Q5 2.0T Blaze Orange Matte Metallic, STaSIS Tune, exhaust & 20x10 rims, RS grill, 2013 lights, LED interior, ACCUAIR B8 Sports suspension
    2003 A4 Avant 1.8T silver
    Oct 03 2011
    WA
    Quote Originally Posted by Maximum View Post
    Without cutting into your S4's future mod budget? ;)
    May 27 2012
    My lounge
    Galt
    Exactly!! Although I really don't mind modding her Q! I would like to make it faster for her as she seems to really like getting on it since the Stasis upgrade! But I think she will need better brakes soon ;) So let's talk intakes.... Lol
    Mar 14 2012
    Ona, WV
    I love the new aFe ProDryS filter I just installed
    Didn't want to mess with the oiled filters, but wanted more airflow. It's pretty nice.
    Current Stable:
    Past Whips:
    Oct 29 2012
    08 Jetta
    VA Beach
    Do you enjoy the KW coilovers? You like the ride quality? Have any regrets? Pros and Cons of KW's?
    Nov 04 2012
    New York
    Impressions of My Q5 Build
    Hi All. EuroTech’s the group that just finished my Q5, as described above. I had posted some comments earlier, but took them down for revision. I am not a regular poster. I’m an avid reader here and at AudiWorld and at other Audi and Porsche sites, and a long-term car enthusiast who’s had a very eclectic mix of entertaining vehicles over the years, some very fast, others more suited to attracting the opposite sex.
    This is a long post but I hope informative. For those looking for part numbers or links, just email me and I'll provide them if I can, and can find the time.
    When I met Danek and the guys at EuroTech Motorsports I knew right away they'd do the kind of build I had in mind, and be forthright about providing me good recommendations based on experience of what works and not just what looks "trick" or "blingy." I never go off road with the Q5. That is why there are Jeeps.
    I'll describe what I can about the superb result EuroTech achieved (with expert help from Ryan at APR and Alex at Europrice), but first my thoughts about what is reasonable to expect from a Q5.
    The Q5 is an SUV, albeit a small one. It has and will always have a high center of gravity and fairly front-biased weight distribution. That said the 2.0T has much better weight distribution than the 3.2 V6 as well as the arriving 2013 3.0 supercharged variant. A stock 2011 2.0T Premium Plus weighs 4,090 lbs, a 2011 3.2 V6 PP weighs 4,299 lbs and the 2013 3.0 V6 PP weighs 4,354 lbs. I don't know if these weights are with or without lubricants and gas.
    As such, absolutely no matter what you do to it, the Q5 will never behave like a mid-engine sports car with 1-1/2" of ground clearance, 50%-50% F/R weight distribution, and all kinds of undercarriage and other aero aids. I'm not even sure if the Q5 has an aerodynamic center of pressure although I guess it must.
    But you can have fun with the Q5, and make it better in all performance respects than when it left Ingolstadt, without sacrificing comfort, ride quality, quietness or luxury.
    Power
    Getting extra power is a relatively easy, if not inexpensive proposition with the 2.0T FSI motor. If one does not intend to do track days or race the Q5 (and I'm not sure why anyone would want to race one), no internal beefing-up of con-rods, shaft bearings, valve train, oiling, etc, is needed to safely approach 200 bhp per liter, even without higher-flow injectors, monster fuel pumps or silly coil packs. All you need is good 100-octane gas, some wizardry from APR, and better breathing. There are two version of the ZF 8-speed torque-converter automatic transmission, one good for around 500 LbFt and the other good for nearly 1,000 LbFt. The 2.0T uses the lesser of the two, so there's no reason to be concerned you're going to shatter the tranny. By the way, this is simply the best torque-converter tranny I have ever experienced, despite a lot of nonsense I’ve read about jerky downshifting. In M-mode it’s better than many early-generation PDKs or DSGs. Try back parking with an early PDK in Auto mode if you want to experience herky-jerky shifting and bumper damage.
    To achieve power outputs in the range I’ve mentioned the motor has to breathe cold, dense air very, very well and get rid of combustion gasses equally efficiently after extracting the energy latent in them. On the stock 2.0T the significant restrictions to these two objectives are:
    • The intercooler. It’s small, has relatively-high internal air temperatures, its plumbing is convoluted, it has excessive, restrictive sound attenuation, it has pretty-poor pressure drop and turbulence, and slow-as-molasses temperature recovery.
    • The size and reaction time of the turbo and its fittings.
    • The needlessly-small catalytic converter.
    Believe it or not, from the cat back the stock exhaust is just fine with the kind of output I'm mentioning and it’s stainless steel to boot, so fiddling with it for another $1,200 gets you little added power and just more HNV. Likewise the fresh air intake to the turbo. The stock unit already uses a ram-air design and again, even if Carbonio made one that fit the Q5, your $600 gets you almost nothing. Stick with the stock until something with a better price/performance ratio comes along. The Carbonio unit is a bling item, and if bling’s your thing, be my guest.
    Since EuroTech didn’t include photos of the two first-phase items for the Q5 build, here they are. The quality of both is much superior to the OEM items, and the fitment was perfect without any glitches, including the bungs for the O2 sensors. I would possibly recommend some kind of expanded-wire honeycomb mesh behind the front grille to protect the FMIC since it does hang down much lower that the stock unit and is not particularly well-protected from road debris.
    Eurocode Tuning FMIC (Mandrel bent, 2.5" aluminum hard piping comes in black powder coat too, which is what I got):
    Eurocode Tuning Hi-Flow Cat:
    These two items and the first tune that EuroTech developed with APR totally transformed the power output. With 100-octane gas the Q5 easily sailed past its former artificially-limited top speed (on a closed course). I did not go faster than that because the stock tires are not rated for such speeds. Torque came on at about the same RPM, but rose much faster to a higher, very-flat peak. Power and torque started to diminish at about 5,750 rpm. Definitely much faster to 100 kph, but no objective timing was done.
    Now that motor modifications are complete with the other items that EuroTech described and APR has customized a tune to the equipment specifications, I will be doing a series of dyno tests (over several days and at differing thermal loads) to ascertain objectively the approximate whp and wtq this Q5 makes. I will buy an APR badge for the poster that comes the closest to predicting the average tested values. That said, I’m still “bedding in” the brakes and turbo, so have not really opened it up yet. But I can tell you that it is ferocious starting at about 1,300 rpm in M2, and I was only at three-quarters not WOT. A lot of this has to do with the superb Quattro system being able to get so much of the power to the pavement without wasting it in wheel spin.
    Brakes
    Ettore Bugatti said he made his cars to go and not to stop, hence their reputation for shit-your-pants scary brakes. All of the aftermarket guys like StopTech, Brembo, Movit, AP (which STaSIS rebadges) and others, are hampered in their Audi offerings because of Audi’s current electronic rear e-brake system. None have rear brakes kits to provide a balanced four-wheel system. Movit is supposed to be making a rear system soon with a second e-brake-only caliper for each rotor that is actuated by a remote “master” cylinder pressurized by an electric solenoid operated by the stock Audi electronic e-brake system. Sounds inexpensive, doesn’t it?
    So, in the end, Alex at Europrice had what seemed to me the most elegant, relatively affordable and strictly OEM solution: use the complete front and rear systems from the 2013 Audi RS4 Avant. All parts are direct bolt on including the splash guards. All the hard brake lines on the body are in the right locations, and the new calipers come with stock new flexible lines. A note on flexible brake lines: for Audis at least, save your money and don’t buy stainless-steel flexible lines. The stock Audi lines are Kevlar reinforced and distend less under pressure than stainless lines. Stainless steel lines are just another example of bling that does nothing and costs more. The RS4 Avant system uses Brembo-sourced 8-pot four pad front calipers, with 4-pot two-pad rears. As I said, they’re not bedded in yet, but I bet I’ll be able to remove fillings from my teeth under full deceleration. The Michelin Pilot Super Sport tires also contribute mightily to the better braking. The Q5 originally came with the optional 19" OEM five-spoke wheels (8,0Jx19H2 ET39, P/N 8R0.601.025.J) and these do fit over the RS4 Avant brakes. These will now be my winter wheels with winter tires.
    Handling
    I grew up with cars that tended to oversteer either on purpose or, in the case of some very early 911 Porsches, unintentionally and very dramatically under trailing throttle. So I like an amount of oversteer that I can modulate as needed with the throttle or steering or both. Because it’s what most mass-market manufacturers do today, the Q5 is designed with moderate understeer as it approaches corning limits, and becomes nearly neutral when gently lifting the throttle or braking delicately, or steering more in the direction of travel. It also has fairly pronounced roll due to its suspension height, but is very predictable and confidence-inspiring once it’s done rolling and takes a set. And of course it has all kinds of electronics to keep you out of the weeds.
    My goals for handling were, not necessarily in this order, to add slight oversteer (or reduce inherent understeer) that I could modulate with the throttle, to increase roll stiffness, to improve the crispness of turn-in, and to increase overall cornering limits. All without sacrificing comfort, ride quality and quietness, or adding harshness and roughness on imperfect road surfaces. Piece of cake, right?
    I had been considering varying the size of anti-roll bars, changing bushing types, using Heim joints where possible, and adding adjustable control arm links and camber and caster upper strut mounting plates. Plus using some combination of adjustable coil overs. Here's where Danek looked me in the eye and said what I was thinking is overkill for a road car. He said just go with the Audi OEM 8,5Jx20H2 ET33 titanium-finish triple-five spoke wheels with Michelin Pilot Super Sport 255/45 R 20s along with the KW Coilover Kit V1. The KW shocks in the V1 kit have preset damping, but are height adjustable down from 1.6" to 3.1" at the front and from 1.8" to 3.3" at the back. After letting the suspension settle for two days, EuroTech adjusted height for about 1" down at all four corners and had a full alignment done. On a closed-to-traffic, right-hand high-speed increasing-radius corner with a single well-defined apex that I know well, I find I am very pleased with the results (traction control obviously off). Roll stiffness is much increased and adhesion and turn-in from the Michelins is light years ahead of the all-season Goodyears that came with the car. The KWs and lowering allow very predictable, mild trailing-throttle oversteer if that’s your preferred approach in a particular corner. The much more substantial power available allows for the same oversteer effect using torque and some opposite-yaw steering. I think the Q5 prefers the former trailing-throttle approach, since the higher center of gravity makes for a bit a drama in the power-oversteer scenario. The KW V1s feel taught but not harsh around town: well snubbed. EuroTech met my handling goals perfectly.
    Driver Controls
    Just had to have the paddle-shifter steering wheel. Regular four-spoke so that I could reuse the air bag from my OEM wheel. Much quicker actuation of the 8-speed auto.
    The Overall Exterior Look
    Just want to keep it looking stock, which I think is a remarkably refined form much better realized than the rather obese Q7. The Q5’s design is successful the way the A5 is in respect to the A4. With the exception of the wheels and brakes, which only those in the know would recognize, it’s as it came from the factory on the outside and I intend to keep it that way. It is after all a Q-ship.
    May 27 2012
    My lounge
    Galt
    Excellent write up!
    Established Member Two Rings Yoshimura's Avatar
    Nov 25 2012
    Montreal
    Quote Originally Posted by der große Mann View Post
    Great info!
    However, I was wondering how they could adjust height for about 1" down if height adjustment is limited from 1.6" to 3.1"?
    Also, were they able to do alignment according to Audi specifications?
    Many thanks!!!!
    Nov 04 2012
    New York
    Quote Originally Posted by Yoshimura View Post
    Great info!
    Many thanks!!!!
    That's a typo! It's down about 2" front and rear.
    Nov 04 2012
    New York
    Original Parts For Sale
    Hi All,
    I'm considering listing the OEM parts that came off this Q5 in the classifieds here and at AudiWorld.
    Before I do, does anyone have any specific interest in buying any of the parts? They're in storage in Northern Westchester County, NY, and I'd make great deals for anyone interested in picking stuff up so that I wouldn't have to bother with shipping. Everything's got about 21K miles on it and was working normally before removal. There's the OEM turbo/manifold assembly and plumbing, F/R brakes complete (calipers, rotors, brackets, pads, etc.), F/R springs and shocks, rear hubs and bearings, intercooler and plumbing complete, and the OEM cat.
    Please PM me if interested.
    Haven't dynoed the Q5 yet, but it's pretty well bedded in and it's really a trip to drive. Too bad it's winter.
    Nov 04 2012
    New York
    Original Parts STILL For Sale
    Any interest, folks? There's good life in these here bits.
    Hi All,
    Nov 04 2012
    New York
    Spring's around the corner and men's eyes turn to the plumage of their cars to attract the early migration of the famed brown-breasted bed thrasher. Surely some amongst you can improve your odds with these lightly pre-owned goodies
    Jan 29 2013
    2011 Q5 2.0, 124" HD Dyna Wide Glide
    Philadelphia, PA
    What about those dyno charts you spoke of?
    Junior Member One Ring
    Apr 12 2014
    tacoma, wa
    I'm looking to get a downpipe for my Q5 soon and I tried contacting eurocodetuning about getting the downpipe you are mentioning here. They said that the one for the A4 they have is compatible with the Q5 but it's for a manual transmission only. I'm hoping that they are referring to the A4 on the MT part, since I don't think there are many MT Q5's out there or that it should matter too much for the downpipe. Would like to confirm what transmission you have before purchasing in case there is an issue with installing. thanks in advanace
