Results 1 to 6 of 6
    Jan 10 2012
    Mira Loma CA
    Weird 2nd gear question: sluggish
    Hello all,
    I have a question, when i throw my car in 2nd (6 spd mt) to turn, it accelerates really slow and seems sluggish, anyone else have this problem?
    Could it be the life of my clutch? it doesnt seem to be slipping. My car also seems very slow. no power, what test should i do?
    Jan 10 2012
    Mira Loma CA
    do you guys think im possibly on limp mode?
    Veteran Member Four Rings vhstejskal's Avatar
    Feb 01 2011
    UT
    What tune do you have if any and have you scanned it for any codes? You have to also realize it depends on the exit speed in your turn could you be the wrong gear; moreover I wouldn't expect much in 2nd gear but that is just my 2 cents.
    -Vic
    May 01 2012
    I had that experience before when I had a plugged/clogged cat that I was not getting much power. I could not accelerate much when around 2k or below.. I had to wait till I got to 2200-2400 rmp to accelerate. After replacing my cat. It had a huge improvement.
    Jan 10 2012
    Mira Loma CA
    Quote Originally Posted by AlS6 View Post
    how did you know you had to replace your cat?
    May 01 2012
    Quote Originally Posted by pmgoce View Post
    I brought it into a shop to find out why car was sluggish. They pulled code and it pointed to a clogged CAT. Maybe you can have your codes checked.
