Results 1 to 19 of 19
    Aug 18 2011
    18" wheels: 8" vs 8.5" width
    What are some pros and cons?
    Senior Member Three Rings yObOyGeo's Avatar
    Mar 13 2012
    Prius
    Boston, MA
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Narrower is better for wet/snow.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Jan 15 2012
    MA
    Pros
    Marginally/negligibly more concavity depending on the wheel.
    Ability to put a 255 width tire without it looking puffy or improper load balance.
    Cons
    Possibly more weight
    Possibly more cost
    2015 S4 - Premium + | Sepang Blue | DSG | MMI Nav | Sports Diff | B&O sound | Carbon Atlas trim | All weather mats and trunk liner | Technology Package | Black Optic package
    Mods: Winter - OEM 19-inch Titanium V-spoke-design with Blizzak LM32 Snow tires | Expel Ultimate PPF full frontal wrap
    Jan 15 2012
    MA
    Quote Originally Posted by dparm View Post
    Wouldn't the tire be the only thing that matters for the wet/snow? You can run a 8.5" wheel with the same size tire that was on an 8" wheel. The road patch width and diameter shouldn't change in a steel belted radial...just the appearance of puffy vs stretched.
    Veteran Member Four Rings oc cc's Avatar
    Oct 14 2011
    OC
    Pros: They both suck
    Cons: 19x9.5 is a better fitment
    Current: 2019 S5 Sportback Quantum Gray
    Previous: 2012 A4 Avant Glacier White
    Mar 13 2012
    Prius
    Boston, MA
    Quote Originally Posted by oc cc View Post
    This guy know whats up
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by handruin View Post
    Wouldn't the tire be the only thing that matters for the wet/snow? You can run a 8.5" wheel with the same size tire that was on an 8" wheel. The road patch width and diameter shouldn't change in a steal belted radial...just the appearance of puffy vs stretched.
    No. With a narrower wheel you exert more force per square inch -- that helps bite through the snow and helps evacuate water/prevent hydroplaning.
    Veteran Member Four Rings Toecutter's Avatar
    Dec 31 2007
    Oregon
    Okay...help explain this to me please.
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by Toecutter View Post
    What is there to explain? You have X weight now being applied over a smaller area, meaning it is applying more force -- that helps it chew through the snow. Tire Rack, Discount Tire, etc. all agree and tell you that if you can go slightly narrower on a snow tire, you should do it. Same thing applies to a street tire; super-wide ones are more prone to hydroplaning.
    Dec 31 2007
    Oregon
    That happens with a narrower tire contact patch. I don't think that using a 0.5" narrower wheel will shrink the contact patch of the same sized tire though. It may bring in the sidewalls a bit but the tread width isn't going to change much, if at all.
    Sep 30 2009
    b
    this guy
    just because tire and wheel were transposed doesn't mean you aren't both talking about the same thing
    Dec 31 2007
    Oregon
    this guy
    I don't think anyone transposed the terms. If you refer back to post #5 by handruin, he talked about using the same sized tire on either an 8" or an 8.5" wheel. dparm then disagreed, stating that a narrower wheel (not tire) exerts more force on the snow.
    I'm seeing this the same as handruin. I can't picture a change of 0.5" in rim width making any appreciable change in the tire width. That's pulling in each sidewall 1/4" and a 1/4" is pretty minor change.
    I think a 245/80R18 tire will have functionally the same contact patch whether you use an 8" rim or an 8.5" rim. When tire merchants say to go narrower in the snow, they're talking about using a 225 tire instead of a 255 tire. They're not talking about using an 8" rim with a 255 tire rather than using an 8.5" rim with a 255 tire.
    Jan 15 2012
    MA
    I agree for a skinnier tire. My example was the same-width tire with a different width rim (which many have done on these forums). The amount of tire surface area contacting with the ground won't change in this scenario.
    I'm glad we're on the same page because I wasn't sure how to even ask why the force load on the road changes when the rim size changes but not the tire. The contact patch and weight distribution should stay the same unless I'm missing something?
    Veteran Member Four Rings well_armed's Avatar
    Sep 19 2012
    I think what he was trying to say is that with the 8" tire you can get away with a 245? tire, versus a 255 on a 8.5" tire
    Dec 31 2007
    Oregon
    One factor that could change the tire contact patch in this scenario would be a change in tire pressure. Increase the tire pressure enough and some of the rubber lifts off the road. Decrease the tire pressure enough and more rubber contacts the road.
    Dec 31 2007
    Oregon
    Quote Originally Posted by well_armed View Post
    Okay guys, it would be helpful for this conversation if everyone carefully picked his words. Wheel = metal round thing. Tire = rubber round thing.
    Jan 15 2012
    MA
    I'm aware of that situation. I've read threads here where people describe tire pressures when racing vs not racing for similar reasons. I've also seen the air pumps near sand pits so trucks can adjust their tires for more traction in the sand, etc. Anyway, I was mainly generalizing that adjusting the rim size wouldn't appreciably change the width of the tire that contacts the road.
    Dec 31 2007
    Oregon
    I agree.
