Hey Guys,
Need some desperate help here. So about a year ago I purchased a set of audi valve stem caps from amazon (similar to these http://www.amazon.com/Tire-Valve-Cap...alve+stem+caps). The other day my sensor went off indicating I had low pressure. Pulled into the first gas station to fill up on air and I was unable to remove the cap. I left it for later as I had to get to work. Today I attempted to remove them and I realized as I was spinning the actually threads. And then next thing I know, snap. Broke the valve stem in half. I only broke one of them but all 4 were seized in the same manor. I made a quick stop by the local tire shop and they were quoting about $120 per sensor + $25 per tire to install. Did a little research online and discovered that I can get them cheeper myself. My question is it appears there are two different types of sensors and I'm not sure which would fit for mine. The other interesting thing is one of the sensor options appears to be a separate unit from the valve. So perhaps I don't actually need the entire sensor?
My car is a 2008 A4 Quattro 2.0T.
Here are the options I've found.
http://www.europaparts.com/tire-pres...k0907253d.html
http://www.europaparts.com/tire-pres...f0907275d.html
http://www.europaparts.com/valve-ste...4d0601361.html
Any help would be greatly appreciated.
Jamie
