Results 1 to 23 of 23
    Senior Member Two Rings holywater's Avatar
    Dec 13 2010
    Madison Park, WA
    2013 front and rear facelift on 2009-2012 US A4's?
    Guys, looking at my 2009 and the new 2013 front and rear.
    Can we just bolt on the new 2013 front bumper cover, grille and head lamp assemblies onto a 2009-2012? I was also looking at the updated rear trunk and trunk connected tail lights. Can we just take a 2013 rear trunk and bolt it to our 2009-2012?
    Mar 02 2004
    Phoenix, AZ
    Would need new front fenders and hood as well. Only time it would probably be worth doing if is you got in an accident and had to replace all those parts anyway, otherwise it would literally be thousands of dollars.
    2011 Audi A4 • Premium Plus • Navigation+ • Sport Package • Bang & Olufsen
    www.DIYAudi.com: Audi Wheel Spacers Install • Audi MFSW Install • Audi Cargo Mat and more...
    Veteran Member Three Rings TheHeiko's Avatar
    May 24 2012
    I was thinking about this recently. I agree that it would require the front wings, hood, and bumper. I was thinking that if one were in an front end accident and wanted to make lemonade out of the situation, it should be a direct bolt on. I certainly don't want to crash my car but I could have a 2013 front end on my Avant and be super special.
    Apr 08 2012
    South OC, SoCal
    ^+1
    Veteran Member Four Rings OmaHahn's Avatar
    Apr 07 2011
    1st owner '64 1/2 Ford Mustang convertible D-Code (dads)
    Nebraska
    Alex at Europrice assured me that the rear is easy to do! I already have the Euro/ROW 2013 LED tail lights and waiting on a 2013 S4 trunk (more aggressive integrated spoiler). Alex said all the parts such as inner trunk lining, weather trim, etc are the same part numbers as the 2009-2012. I'll make sure to post a thread when I get my rear conversion done.
    2009 A4 3.2 V6 - sold
    2014 Ford SHO, 3.5 twin turbo with mods, 490WHP/545WTQ - sold
    2021 Dodge Durango SRT
    1964 1/2 Ford Mustang convertible, D-Code (original owner, Dad's ride I'm storing)
    Sep 30 2009
    b
    I still haven't heard any conformation about the fenders actually needing to be swamped.
    Established Member Two Rings winreboot's Avatar
    Jan 06 2010
    A6 TDI, Q7 4M
    NE PA
    +1
    For most of us it would cost too much but it would be interesting to find out what it would take for this to be done. If radiator support have same holes drilled for the new 2013 lights and if all is just bolt on, if new wiring harness is needed, if new engine under cover is needed etc.. From what it looks like it would need new big parts like:
    *Headlights
    *Fenders
    *Full bumper (fogs, brackets etc..)
    *Hood
    *Coding to take new headlights
    True, if someone gets in front fender bender it would make sense to get with new 2013 front end but if only it's doable...
    May 02 2011
    Part numbers are different for the B8.5...
    Fenders B8
    8k0 941 191 & 192
    Fenders B8.5
    8k0 821 105j & 106j
    Hood B8
    8k0 823 029 D
    Hood B8.5
    8k0 823 029 H
    I didn't check the mounting HW, but could be some differences there as well. I almost pulled the trigger on B8.5 rear conversion ... Decent price on the bumper and diffuser, but could not get confirmation on compatibility of the rest of the mounting hardware, maybe it would have all worked out but I decided against spending the time to play around with it.
    -Spaghettipie
    Oct 27 2009
    Miami, FL | Boone, NC
    Re: 2013 front and rear facelift on 2009-2012 US A4's?
    You guys are forgetting about the fog light assemblies which have changed. You may also have to modify the bulb harness considering 2013 uses a different sized bulb.
    Sent from my Galaxy Nexus using Tapatalk 2
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    This doesn't make sense to me personally. The couple of thousand you would drop on this could get you a much newer car with a much better interior and most likely more efficient engine.
    Euro Tails Crew
    Established Member Two Rings c3A4's Avatar
    Aug 04 2012
    Toronto, ON, Canada
    I got the 2013 non-S line A4, but now I really wish I got the S line front end. I asked my dealer and they said something around $1500 for a S line front bumper swap. Could I do better than that at an independent shop? or would there be quality and sourcing issues?
    Dec 01 2011
    yeah the rear is a direct swap, but the front looks to me like it would need at least at the hood as well. try to get into a complete front end accident :P haha
    Quote Originally Posted by c3A4
    yes you can always do better than the dealer price-wise lol. you can always get the bumpers from one of the vendors on here, probably Alex@EuroPrice and then just get it installed at a local shop
    IG @theshawon
    Veteran Member Four Rings MilesM's Avatar
    Jan 17 2011
    RSQ8
    LA / SF
    Quote Originally Posted by Pared View Post
    +1
    May 24 2012
    I would only contemplate this if my original front end had been damaged to the point of having to replace the panels involved. Agreed that just doing it for the sake of doing it would not make sense.
    Veteran Member Three Rings Sin_city_Rings's Avatar
    May 09 2009
    Washington, DC
    Quote Originally Posted by OmaHahn View Post
    BUMP
    Did you complete this OmaHahn?
    2008 Deep Sea Blue S5 6MT
    PAST: '12 A4, '08 A5, '09 Sline A4, '07 Sline A4
    Dec 13 2010
    Madison Park, WA
    It still looks like to me that the lines on a 2009-2012 A4 hood and front fenders are the same as the 2013? Am I the only one seeing this?
    Dec 01 2011
    Quote Originally Posted by holywater View Post
    well to me it looks the same up until it gets to the part right above the grille, the grille shape and the bumper part that comes up to the hood is shaped different so im gonna say theres a slight difference in those curves/corners there.
    IG @theshawon
    Oct 27 2009
    Quote Originally Posted by Liquid Smoke View Post
    Yes - hood is definitely different where it meets the bumper/grille...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Senior Member Two Rings tgofsweden's Avatar
    Nov 03 2012
    ///M3
    GBG, SWE
    anyone got part no. for the 2013 s-line bumper with park assist support?
    thx
    May 02 2011
    Quote Originally Posted by tgofsweden View Post
    thx
    Sedan/Avant front 8K0 807 065 F
    Sedan rear 8K5 807 067 C
    Avant rear 8K9 807 067 C
    You may need other parts, but these are the bumpers themselves.
    -Spaghettipie
    In, Out and Around...
    Quote Originally Posted by HX_Guy View Post
    at that point you're better off doing an rs4 conversion. (imo)
    Apr 07 2011
    Nebraska
    Quote Originally Posted by Sin_city_Rings View Post
    BUMP
    No and I'm not sure what to do. We're moving into a new house and the new 2013 tails are in a box somewhere! Not sure if I just might sell them - this could turn into a big head ache that I don't need right now.
    Nov 03 2012
    ///M3
    GBG, SWE
    Quote Originally Posted by iconoclast View Post
    how much wider is the RS4 Avant at the rear, possible to fit RS4 bumper on a regular?
