Results 1 to 23 of 23
    Account Terminated Two Rings
    Sep 22 2012
    Gotham City
    Everytime i hit the brake pedal, my car beeps once
    Tailight bulb went out the other day,
    i replaced it today and all of a sudden the ABS light turns on and the car beeps once, everytime i hit the brake pedal.
    And all my lights work, tailights, brake lights, all headlight bulbs, interior lights.
    Whats going on here..vag coming tomorrow
    Registered User Three Rings GWerks's Avatar
    Sep 11 2010
    Grand Rapids, MI
    You put a single filament bulb in, replace with double.
    Jun 01 2012
    Check it
    Veteran Member Four Rings topquarkpc's Avatar
    Aug 03 2009
    PNW
    this reminds me of the new Nissan Altima tv commercial...lol
    '01 Imola Yellow Avant Sport Package 6-Speed (stage 3 w/Frankenturbo F4H)
    Active Member Four Rings martin0079's Avatar
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    You need to check your brake fluid or replace brake pads
    Account Terminated Four Rings
    Feb 26 2011
    las vegas
    your car doesn't like slowing down, press the accelerator instead
    Veteran Member Four Rings juntsky's Avatar
    Mar 04 2011
    Charlotte
    stop sitting so close to the steering wheel then
    Veteran Member Three Rings alm001's Avatar
    Dec 29 2010
    Quote Originally Posted by topquarkpc View Post
    Yes, your tires are full of air.
    -Andrew
    Veteran Member Three Rings noob5's Avatar
    Dec 09 2007
    Quote Originally Posted by martin0079 View Post
    ^^^This. My bet is on low brake fluid level.
    '13 allroad Monsoon | APR K04/hfc/downpipe/FMIC | H&R | 034
    '07 RS4 Imola | JHM 93/Stg4 clutch/Shifter trio/Intake spacers | KW HAS | 034 t-mount/linkage arms | Stoptech rotors/pads | Milltek DP's | ECS H-Pipe/motor mounts/rear diff mount
    '12 VW T-Reg
    Gone:
    95 90 SportQ Laser
    99.5 A4 2.8Q Volcano Mica
    02 S4 Santorin
    04 allroad 2.7T Alpaka
    10 Q5 Brllnt Blk
    Sep 22 2012
    Gotham City
    Well i just had the pads and brake fluid replaced so i know thats not it...
    Sep 22 2012
    Gotham City
    your guys are trippin, everytime i press the gas pedal and then when i release off of the pedal thats when it goes "BEEEEEEEEEEEEEEP" just once until i do it over again
    Veteran Member Four Rings Oompous's Avatar
    Feb 07 2010
    2001 S4, 2006 C320 Sport
    Los Gatos, California
    Quote Originally Posted by CrucialMoments View Post
    you guys are not understanding, everytime i press the gas pedal and then when i release off of the pedal that's when it goes "BEEEEEEEEEEEEEEP" just once until i do it over again
    fixed.
    Jonathan
    Santorin 2001 S4
    TiAL 605.2 | 034 | Apikol | ABD | AWE | MTechnica Turbo 18x9.5 et18
    Sep 22 2012
    Gotham City
    Quote Originally Posted by Oompous View Post
    fixed.
    oh good god lol sorry mybad...i mean my mistake lol
    i actually meant that in another way, referring to that altima commercial...cuz im sure they understood my question they were just getting a little off subject so i said "trippin" instead
    Dec 09 2007
    Did you do the job yourself? If not, then double check the brake fluid level just to be sure you can rule that out. I had this issue with my S4 back in the day and it ended up being low on brake fluid.
    Of course, if you already double checked, then ignore everything I just stated.
    Btw, are there any indicator lights flashing?
    '12 VW T-Reg
    Gone:
    95 90 SportQ Laser
    02 S4 Santorin
    10 Q5 Brllnt Blk
    Dec 09 2007
    Quote Originally Posted by GWerks View Post
    Wow, I don't know how I missed this one.
    Anyway, OP, Gwerks brings up a good point as well. In fact, this might be the more likely Rx.
    '12 VW T-Reg
    Gone:
    95 90 SportQ Laser
    02 S4 Santorin
    10 Q5 Brllnt Blk
    Sep 22 2012
    Gotham City
    its the lcd brake light in the middle of the cluster, all the little pixels are almost gone but i can still see it says brake lights.
    and i replaced the bulb with the same part number bulb that i pulled out 7528 or somethign like that
    Jul 28 2008
    01.5 S4, 09 Touareg, 88 Cabriolet 16vT
    Pittsburgh PA
    so I am having this problem too? But mine is intermittent... it's telling you a brake light is out... when it happens and the BRAKE LIGHT warning is up there ( i guess my LCD center screen is better than yours, it does say light) I can put a brick on my brake pedal and see that my rear drivers light is OUT... however, my shit just all of a sudden works... then it goes away. I'm kind of at a loss, as I have replaced all bulbs and have no issues until randomly i hit the brakes and it beeps and I have the "brake light" warning... but then it typically goes away.
    so i'm guessing that i have a wiring issue between the brake pedal and rear drivers brake light? almost one of the worst wiring situations to track down in my opinion...
    anyone else hear of this or have this happen? I may make a new thread after i do some troubleshooting.
    Latest mod - JHM rebuild kit :swoll:
    Sep 22 2012
    Gotham City
    Engine says
    Address 01: Engine Labels: 078-907-551-AZA.lbl
    Control Module Part Number: 8D0 907 551 M
    Component and/or Version: 550CC 91N75 G R6.43
    Software Coding: 06711
    Work Shop Code: WSC 78901
    VCID: 3467A7E50482EEB8F5D
    1 Faults Found:
    16955 - Brake Switch (F)
    P0571 - 35-00 - Implausible Signal
    ABS says
    Address 03: ABS Brakes Labels: 8D0-907-389.lbl
    Control Module Part Number: 8D0 907 389 E
    Component and/or Version: ABS/ESP allrad D56
    Software Coding: 04395
    Work Shop Code: WSC 00008
    VCID: 35619AE10FF8F7B0C23
    2 Faults Found:
    01422 - Hydraulic Pump for Electronic Stability Program (V156)
    35-00 - -
    00526 - Brake Light Switch-F
    36-10 - Open Circuit - Intermittent
    May 28 2012
    Boston
    i think you need new bulbs.. i have this issue now.. turn the lights on.. hit the brake.. brake light occasionally comes on in the dash (only when you first turn lights on) but goes away after a few minutes..
    Sep 22 2012
    Gotham City
    HA i wish it went away after a few minutes, I drive around town and each time i oress the brake "beeeeeeeeeeeeeeeep" annoying as F***
    Sep 22 2012
    Gotham City
    THE STUPID PERSON...ME...FORGOT TO SCREW IN THE BULB..i guess it was just sitting in there ready to fall out...Still dont know why the ABS light turned on tho?
    Jul 28 2008
    Pittsburgh PA
    haha, so my bulbs are not falling out and are new, however i didn't change both sides, but only one side is experiencing the issue. It is intermittent... which makes me think it's a grounding issue along the way somewhere or within the brake light assembly itself... (first is more plausible than the latter). Blows.
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    I read your original post out loud and immediately laughed because I envisioned the horn beeping.
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
