Results 1 to 21 of 21
    May 07 2012
    2000 accord coupe, jdm f20b, t3/t4 turbo
    Hudson Valley NY
    B8 S4 supercharger on 3.2 v6 A5???
    Hey guys, so this is what Im interested in. Is it possible? I've seen some site that sells the kit but its like 10 grand and I havent heard good things about them. I found the actual supercharger for 2 grand... so if I can pull this off for like 3500 with the tune I'd like to get it done. From what I have heard, the a5 v6 3.2 motor is pretty much the same as the b8 s4 motor. Same size bore, but the stroke is 3.8mm longer. The s4 has 10.3:1 compression and the 3.2 a5 motor has 12.5:1 compression. Would that bolt on just how to stock intake manifold bolts on? Any helkp or knowledge on the topic is appreciated!
    Edit: Found a thread on an audi forum where a guy was selling the s4 supercharegr with map sesnsor and throttle body and he says its for 09+ and also fits the 3.2. I need some more information than that though lol, before I shell out two grand for the supercharger. Posted this in the a5 thread as well.
    DONT TELL ME TO GO BUY AN S5! lol
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    as long as you stay away from motodyne, this could be a really cool project
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    May 07 2012
    Hudson Valley NY
    Quote Originally Posted by richib86 View Post
    I've heard lol. And yea I dont need to deal with any company, just get the hardware. I'll have my buddies shop tune it if I can actually make this happen.
    Veteran Member Four Rings PaperishPlastic's Avatar
    May 13 2007
    Rats
    San Fernando Valley
    Quote Originally Posted by nicksena View Post
    what kind of tuning does your buddy do?
    B8 Signal Green
    Veteran Member Four Rings OmaHahn's Avatar
    Apr 07 2011
    1st owner '64 1/2 Ford Mustang convertible D-Code (dads)
    Nebraska
    Even though the compression ratios sound close 10.3 for S4 and 12.5 for 3.2 it's a huge difference! I've heard numerous times that the compression is too high in our 3.2 for forced induction unfortunately! I wanted to do this also!!!
    2009 A4 3.2 V6 - sold
    2014 Ford SHO, 3.5 twin turbo with mods, 490WHP/545WTQ - sold
    2021 Dodge Durango SRT
    1964 1/2 Ford Mustang convertible, D-Code (original owner, Dad's ride I'm storing)
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Good luck! I think you will need it.
    Veteran Member Three Rings Kem's Avatar
    Aug 30 2004
    Colfax, CA
    Compression can be reduced, you also need to make sure the internals of the 3.2 can handle the boost. But to lower the compression you're going to be adding aftermarket internals so you can get ones that will handle the added power.
    Not an easy project though, bolt on it will be.
    2005 6MT ur-Allroad
    May 07 2012
    Hudson Valley NY
    My buddy is a dealer for OEtuning, and he is owns a local performance shop in here in New York called LoMotion. They specialize in Corvettes and BMW/Audi. I only plan on 5-7 pounds, nothing crazy.
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Thicker headgasket will lower to appropriate levels. Have your volume measured first.
    Jan 10 2007
    VA
    A. I don't think the project can be completed for $3500. (Unless you get free work/tuning by that shop.)
    B. A low boost tune, required on the high compression motor, probably won't make 3.0T power.
    C. High risk of engine damage. SC kits with tunes on the old 3.0 V6 blew a few motors.
    D. BUY AN S5
    Veteran Member Four Rings oc cc's Avatar
    Oct 14 2011
    OC
    Not worth it dude, you have to do a lot of work, and at the end of the day you are supercharging an engine that wasn't designed for the application. Your $3500 expectation is really off. Even without labor, it might be around $5000 total.
    Current: 2019 S5 Sportback Quantum Gray
    Previous: 2012 A4 Avant Glacier White
    Veteran Member Three Rings brainpan's Avatar
    Apr 11 2010
    sk8 banana
    ontario
    I've been looking into this for about a year now, IMO not worth it, I was in the same boat as you using 5-7 psi, I read that 7psi would get roughly 100hp gains, but with stock cr you're looking at a cr of like 18:1.. Thicker gasket will not lower enough, a gasket hardly helps and with a thicker gasket you're more likely to blow it out.
    So lowering the stroke is the best way, and pulling the engine and rebuild can cost a lot, also unknown of the construction of the head, no clue if they're the same as the 3.0 and if they could handle the psi.
    You'd also need a custom tune for the lower boost, I've contacted a few companies that work in the custom tune market and none could give me an answer with the tune. If you have someone that can tune, I'd say forget the s/c get the eurocode headers and look into custom hfc, you'll probly get some good gains on that and it would cost less.
    /2cents
    Bryan
    Veteran Member Four Rings Deckdout2's Avatar
    Sep 13 2010
    2010 Audi B8S4 Ibis Prestige (SOLD), 2016 Audi C7.5 A6 Prestige (SOLD), 2004 Audi C5 A6 4.2 - 6spd
    Charlotte, NC
    I still don't know of any full stand alone units that can manipulate these ECU's where you can just pick up off the market. Piggybacks won't do what you want it to do, and seems like our ECU's need to be flashed either way. The tool and know how cost boat loads, and that's just for the tune. You'll need to actual get lower compression pistons to drop it down that low. Head gasket will only lower it by tenths. Too bad you're not raising compression, then you could have just decked the heads a little more. lol I'm not sure of any company that currently offers aftermarket pistons for these motors, but it can always be built upon request. That in itself would be a dime. It's def doable, you would just need pretty deep pockets.
    I've already fully built my Maxima, so I know a little info here and there. :)
    http://forums.maxima.org/all-motor/6...5-5gen-na.html
    APR Stage II+ | APR TCU | APR Ultracharger | APR Dual Pulley | APR CPS | APR Open Intake | AWE Non-Res DP & Touring | H&R Coilovers | Hotchkis F/R Sways | Alu Kreuz Stabilizer Bar | USS F/R Endlinks | SPC Adj Arms | 034 Arms Kit | 20 x 9 +35 Rotor Reps | 255/30/20 V12 evo2 | RS6 Pedals Shifter | RS6 Shift Knob | Audison/Hertz Amp & Sub | RS4 Grill | Deval CF Splitter | Facelift Flat-Bottom | S6 Start/Stop Button | oCarbon Red CF | Relak v2.0 Paddles | ECS Stage 1 Brake Kit
    Jun 05 2009
    Scottsdale Arizona
    Just swap the engine then from a wrecked S4:http://www.salvage-cars-for-sale.info/
    Shees.
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    What do you have against buying an S5? I know you said not to say it, but there it is anyway, lol.
    For all the time and money you will invest, not to mention being a guinea pig for a project with an unknown outcome, an S5 will give you everything including a warranty. All the gain without any of the pain. Just sayin'.
    Veteran Member Four Rings madmadS4's Avatar
    Jul 21 2010
    Westchester, NY
    Quote Originally Posted by A4 Centaur View Post
    Shees.
    cool. never seen this site before. here is a 2010 s4 which is pretty f'd up. engine it probably good.
    http://www.salvage-cars-for-sale.inf...10-MjI5MjAyMDA
    Sprint Blue 2011 S4/S-Tronic/Alu-Optic/CF Inlays/Sport Diff
    VAG-COM Mods/Tinted/Front Plate Filler/BFI Spacers/H&R Sport Springs/RS5 Pedals/Ceramic Pads/AWE Intake/GIAC Tune/RS4 Grill
    Shoot me a PM if you need VAG-COM mods done...
    May 07 2012
    Hudson Valley NY
    Quote Originally Posted by Leor604 View Post
    I test drove 4 different s5's before I bought my car and didn't like them. Way too dissapointed. Thought it would have alot more power, be a lot faster than it actually was. Broke my heart..... maybe I'll just have to wait a few years and buy a 13 RS5.
    Nov 05 2006
    Fair Lawn
    you never drove a tuned one... different car
    Senior Member Three Rings FrankO's Avatar
    Jul 21 2012
    GMC Yukon Denali
    New Jersey
    Quote Originally Posted by madmadS4 View Post
    the wheels could be nice
    2016 //A6 3.0T || Black on Black
    19" Black Optic||Full LED||Cold Weather||Warm Weather
    Prior Ride:
    2013 //S4 Premium Plus || 6MT
    Glacier White Metallic||Black Alcantara||Navi||Bang & Olufsen||Sports Diff||
    Advanced Key||Carbon Atlas||19" Ti Reps for warm days||18" VMR V710 for snow time||
    Mar 04 2017
    Vernon NJ
    3.0 charger on 3.2
    Quote Originally Posted by FrankO View Post
    Im currently doing this as we speak i made my own adaptor plates that the supercharger can bolt to
    May 19 2015
    winnipeg
    I did this few years back. Run the thickest head gasket possible. I had my Cr down to around 11.5 and anything past 6 psi it didn't like it.. Tbh get a 3t motor and just toss it in. Less headache and more power and tuning isn't pain in the ****. I say swap a i5 tt-rs. Best Audi motor right now Imo. Love the pissed off sound.
