Running or not running chains on B6 Quattro's has always been clear as mud. With the whole "do not run 4/32nds wheel differential" thing we've all heard, how does that fit in with running chains where link size must not "protrude no more than 1/2 inch" per what the owner manual states?
On the question of whether to run chains on the front or back. My 2002 owners manual states the front. Why? Dunno.
Also, the following is from the Bentley, also implies that chains be run on the front. Why? Dunno.
Audi > A4, S4 (B6, B7) > 2002-2008
Wheels and Tires Guide
44 - General Information.Emergency Wheels, General Information
- It is not permissible to use snow chains on the emergency wheel for technical reasons.
- If vehicle must be driven with snow chains, therefore the emergency wheel must be installed on the rear axle for a breakdown on the front axle. The rear wheel freed up must then be mounted in place of the faulty front wheel.
(Emergency wheel would refer to those skinny temporary wheels, which did not come from the factory. Full-size spares came from the factory.)
For me, there's a lot of good common sense reasoning in some of the thread replies to run chains on the front or the rear. But Audi says the fronts. Why? Dunno.
Now on whether to even be running chains.......
If you're comfortable running chains where they may cause the "4/32nd wheel differential" situation..........are the chain links smaller than what a cable chain layout would be? Does the chain wrap around onto the inside sidewall?
I'd test fit them first with the chains on and with your wheels on the ground. Visually check the clearance between the tire and the upper pinch bolt area where your upper control arms meet, and your brake calipers. Then think/imagine what the chain does when it rotates at speed -- centrifugal force will cause any slack the chain has on the wheel to expand outward. Previous comments and second-hand stories have always said chains/cables get hung up in the suspension, causing them to then wrap up the brake calipers. I test fitted some cables on 235/45-17 on my 2002 sport suspension, and did not feel comfortable that the cables would not get caught up in the suspension -- the available clearance was miniscule. The cables I fit were a low profile cable setup euro-rated for tight wheel to suspension clearances. Running a narrower tire may help mitigate any clearance issue the wider tires gave me.
If suspension clearance is a potential concern, alternative to chains or cables are
AutoSock,
Thule K-Summit Low-Profile Passenger Car Snow Chain, or
Spike-Spiders.
