Results 1 to 37 of 37
    Apr 24 2011
    Cape Cod, MA
    Backup Camera Calibration
    Long story short, my camera was calibrated about two months ago, and it took 3 hours. Wanting to save myself that hassle in the future, I recorded the pertinent numbers (info from http://wiki.ross-tech.com/wiki/index...ial_Procedures ). After finally getting my front parking sensors working and associated module installed, I checked the values, and they were off from what I recorded, so I changed them. The problem is, now it's showing that my camera isn't calibrated, and the procedure is not working. When I get to the part about
    Block 130 Field 3 (Calibration Status)
    Specification: 0x0000 (Calibration Successful)
    [Done, Go Back]
    it shows instead 0x0003 [something about unsuccessful, or uncalibrated]
    Field 1 shows that it's not ready to be calibrated. Am I missing something? Is the procedure different because I've got the front sensors?
    I'm bringing it in tomorrow to get protection cleared for my new MMI, anyway so I could try to get them to just tell it it's calibrated, but I don't want it to turn into a 3 hour process again.
    In, Out and Around...
    you're not going to be able to do it unless you have the proper VAS tools or make a fake version of it... long story short, you're going to have to pay to calibrate the camera again. (i've had it done a couple of times through the dealer and they've always charged me one hour.)
    Apr 24 2011
    Cape Cod, MA
    So the camera needs to "see" the calibration board to work?
    yes, with out it the system will never accept a calibration.
    a few people have made ones from cardboard boxes and other material... look for VAS 6350... it looks like this:
    i learned this by accident when i was adjusting settings on my Q7 after lowering it.
    i am not sure if it is part of the procedure for the b8 a4 but when the Q7 gets an alignment they recalibrate the camera as well.
    here are the instructions if you get your hands on the tool or make one:
    http://audi.workshop-manuals.com/a5/index.php?id=1636
    Senior Member Three Rings Nison_Li's Avatar
    Mar 05 2011
    '15 Q5 3.0T S-Line
    Baltimore, MD, USA
    it happened to me before, and the dealer wasnt able to calibrate it as i changed the coding of the parking module. and the dealer wants an extra hour of labor to recode the whole car back to factory and then calibrate it.
    2015 Q5 3.0T S-line Premium Plus
    Done: LED interior bulbs, S7 Steering wheel, RS5 Pedals, warning tri angle, VCDS mods.
    Planned: Tune, Alu Kreuz, Sway bars, under seat drawers
    Mar 26 2013
    switzerland
    Lightbulb
    for those interested doing himself the calibration board. I created a pdf scaled to print on a large plotter.
    Download file here:
    http://www2.zippyshare.com/v/86679736/file.html
    or
    http://www.filedropper.com/calibrationboard
    Veteran Member Three Rings TheHeiko's Avatar
    May 24 2012
    ^ Awesome! Thanks for sharing that.
    Veteran Member Three Rings kehvein's Avatar
    Feb 09 2011
    08 Audi A5 S-Line, Acura TL Type-S
    LA/CA/WEST
    Quote Originally Posted by gab696 View Post
    Download file here:
    or
    +1... Stumbled onto this and ran to the nearest fedex store for printing. best 12 bucks I ever spent.
    08 A5 S-Line 3.2L | Custom Black Top | Euro Facelift Tail lights | MMI2G --> MMI 3G+ Upgrade | VAGCOM Mods | LED Interior tunerdomes.com | APR Cold Air Intake System | Audi Drive Select Installed | APS --> APS+ w/Graphics | Audi Side Assist Retrofit | PHILIPS X-treme Vision 4800K
    If anyone in SoCal needs VAGCOM Mods/Help... Hit me up.
    Veteran Member Three Rings mr_milo's Avatar
    Oct 18 2013
    SF Bay Area, CA
    Great info! Thanks all.
    2014 A4 P+ 2.0TQMS
    2011 BMW 328i Convertible 6 Spd Manual - SOLD
    1999.5 A4 1.8TQMS - SOLD
    1986 4000CS Quattro 5 Spd Manual - SOLD
    Save the Manuals!
    Mar 26 2013
    switzerland
    Quote Originally Posted by kehvein View Post
    Personnaly i've never been able to calibrate my backup camera with the DIY calibration board. And you ?
    Feb 09 2011
    LA/CA/WEST
    Really? I took your custom made pdf and went to fedex. Told them to put it on architect type paper and as shown in the photos about 60 inchs from the center of the back tire and changed value of one and away it went.
    No issues. Total calibration time took about 4 mins.
    Feb 09 2011
    LA/CA/WEST
    Oh and I was gonna mention aswell since I was tinkering and that's what reset the calibration the previous setting were still there. So I just changed the run value to run and just converted the distance already there from mm to inchs (which was right under 60) and let it run. Hope this helps
    Jun 11 2014
    Stamford
    Got the calibration to work on my 2013 A4 (B8.5) as follows:
    1) the distance from the center of the rear wheel to the edge of the calibration board, as well as the height of the calibration board must be spot on.
    2) the axle width must match your car - this was the key to get the calibration to work!
    My steps:
    1) Place the calibration sheet printed from gab696's pdf above (big thanks!) 51.5" behind your car. The measurement is from the center of your rear wheel to the leading edge of the calibration sheet.
    2) Run VCDS and choose
    [6C - Back-Up Camera]
    [Security Access - 16]
Enter 22351, to enable the adaptation.
    3) [Adaptation - 10]
Channel 005
[Read]
save a value of 500 as the paper for me was on the ground
    [Test]
[Save]
    Channel 004
[Read]
save a value of 15872 for the A4 with the calibration sheet 51.5" behind rear wheel
    ( 20000 - 2820 - 1308 = 15872mm ) --> (base measure - axle width - distance from rear wheel)
    [Test]
    [Save]
    Channel 001
    [Read]
save a new value of 1 (this tells your car to calibrate)
    [Test]
[Save]
    [Done, Go Back]
    4) Now double check the calibration status.
    [Meas. Blocks - 08]
Select Block 130
[Go!]
    [Done, Go Back]
[Close Controller, Go Back - 06]
    5) Scan for codes. If calibration is unsuccessful then the measure you took above are incorrect. Realign the target paper behind your car and try again.
    Senior Member Two Rings asal's Avatar
    May 09 2011
    inside the beltway, VA
    wow this is pretty cool; great info. I never new the backup cameras even needed calibration, but I suppose it makes sense that those "guide lines" would need to be calibrated if one lowered the car. Is that the only situation where it makes sense to recalibrate? I'm not suspecting that small alignment changes would really make that much difference.
    B8 Avant S-line
    ...former A3 TDI, mkiv owner
    Feb 09 2011
    LA/CA/WEST
    Ironically I think it's actual for the perspective of the camera also. My TL has a very fishbowl reverse appearance while my A5 looks more true to perspective with minimal distortion. And yeah really cool.
    Jun 11 2014
    Stamford
    I had to do the calibration as I tried to get the camera to shutoff as soon as I shifted out of reverse. Messed something up when I changed the code in [6c] from 1001008 to 1003008 (aarg I should have read the post better) as my guidelines are missing. Changing back did not resolve the issue and I threw 2 codes, this calibration being one of them.
    I now have the camera working well however my guidelines are missing and I have this second code:
    03110 - Active Steering Control Module (J792)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 99
    Mileage: 48442 km
    Time Indication: 0
    Date: 2014.06.15
    Time: 10:36:06
    Freeze Frame:
    Term 15 On
    Reverse OFF
    Count: 3
    Any help resolving would be appreciated!
    So now I have just the above code, backup camera and acoustic sensors working but guidelines missing. Not the end of the world but want to get it resolved.
    Feb 09 2011
    LA/CA/WEST
    Do you have active steering installed in your car? Did you tick that you have it ?
    Jun 11 2014
    Stamford
    Yes i do and i have selected it. There is also a [44] steering with a drop down that i looked at. My setting is none however i tried both the active sterering 1.0 and 2.0 options without success.
    Away from car bit will tty again this weekend.
    Jun 11 2014
    Stamford
    So I have checked this again and selected [44 - Steering Assist], Coding, Byte 1, Dropdown to [01 - Park Steering Assist Installed/Active] but no joy. Also the 03110 - Active Steering Control Module (J792), 004 - No Signal/Communication is still showing. I'm thinking of taking it into the dealer for a look.
    Any ideas before I do??
    Quote Originally Posted by daudia4 View Post
    Veteran Member Four Rings UmIsThisThingOn's Avatar
    Jun 03 2009
    1954 Volkswagen Beetle
    Raleigh, NC
    Sorry to be a bit off topic, but this is the most informative post I've seen about the rear camera.
    Anyone have any idea how to fix the rear acoustic beep? Mine stopped all of a sudden and I don't want to go to the Dealer.
    Tschüß!
    Ðave
    ____________________________________________
    '10 Brilliant Black A4 Sline • Hüper Optik • 034 HiFlo Turbo Hose • EC HFC • Milltek • Alu Kreuz/ÜSS • Hankook V12's • ST-40 BBK
    Apr 20 2013
    If anyone wants to print off the calibration template in 11x17 sheets, here ya go:
    http://www12.zippyshare.com/v/99545388/file.html
    Sep 07 2015
    Ann Arbor, MI USA
    I know this is an old thread - thanks for all the information and the PDF of the calibration template. I retrofitted my 2010 A6 with the OEM rear camera and got it all working. I was able to print it at Staples on their black and white "engineering printer" for $10. Worked perfectly with these directions. Thanks!
    Established Member Two Rings Grisho's Avatar
    Mar 09 2016
    Hey guys, this is awesome information, thanks! I have clicked on all the link for the calibration board/template however all of them do not work/want to install things before I can download. Could someone post the file (ideally pdf) that can be downloaded without a problem/install new software? Thanks in advance!
    Oct 22 2014
    Atlanta, GA
    Download file here:
    or
    Thank you for sharing!
    My steps:
Channel 005
[Read]
    [Test]
[Save]
    Channel 004
[Read]
    [Test]
    [Save]
    Channel 001
    [Read]
    [Test]
[Save]
    [Done, Go Back]
    [Meas. Blocks - 08]
Select Block 130
[Go!]
    [Done, Go Back]
    Worked great for my 2012 A7. I let VCDS pick the channel and helped create the values also. Didn't work the first time because I hadn't fully trimmed the plotter paper. Once I did that, it worked like a charm. Which got my adaptive cruise working since, for whatever reason, it relies on the rear camera being properly calibrated.
    Jan 05 2019
    Timisoara
    Hello, there is a video for the ones which wants to calibrate the camera via VAS5054a.
    This video: https://youtu.be/emOEY7kwCl8 - min. > 57:45
    Veteran Member Three Rings kevin#34's Avatar
    Aug 11 2019
    Rome, Italy
    I just retrofitted the backup camera on my TTS but I need to calibrate it...
    any chance to retrieve the calibration board file? both links not working anymore...
    Download file here:
    or
    Feb 15 2016
    Cambridge,Ontario
    no longer available.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by kevin#34 View Post
    pm me your email if the link does not work for you .
    edit .. no longer available.
    1976 Yamaha XS 360
    Aug 11 2019
    Rome, Italy
    it works, just downloaded it!
    many thanks!
    I have the chance to use a plotter, do I have to set a specific size, before printing it?
    Feb 15 2016
    Cambridge,Ontario
    many thanks!
    No idea. I think it would be up to the plotter.
    Sent from my SM-G973W using Audizine mobile app
    1976 Yamaha XS 360
    Aug 11 2019
    Rome, Italy
    ok, many thanks again
    Aug 11 2019
    Rome, Italy
    these are the dimensions of the calibration board, should somebody need....
    Dec 07 2020
    Lithuania
    Hi, anyone an help, just install back up camera in my Audi A6 c7 turn it on in green menu, and camera still not turning in MMI parking sensors working but also didn’t show nothing.
    Thx
    Mar 14 2021
    Australia
    Is anyone able to please share the rear video camera printable pdf, VAS-6350 if possible?
    189mm + 57mm, 034 HPFP, CTS Turbo HX + Test Pipes, 034 Stage 2+ on E40.
    Jul 16 2018
    Atlanta
    Here's the PDF that the person in this thread had made:
    https://www.dropbox.com/scl/fi/kbw5u...=31vt3c5t&dl=0
    Mar 14 2021
    Australia
    Quote Originally Posted by Smac770 View Post
    Thanks so much. I was able to download it perfectly.
