At a time like this the word luck doesn't really come to mind , however I figure somehow it's a good thing I found it and it didn't drop inside the head. Problem is I now can't get it back in
Having mucked around with this now for a while, I'm starting to think I might just be stuffed. I have the timing belt in place and don't have the required tools (or knowledge) to remove it, so a couple of questions with that in mind.
1. Can I remove the inlet cam (bank 2, US drivers side) and also the chain tensioner to replace the tiny oil screen under the tensioner, leaving the exhaust cam in place?
2. If yes, how? I have removed all the cam caps on the inlet cam (US drivers side) and the cam comes loose but I don't seem to be able to get it out because the cam chain tensioner can only raise a small amount until it gets jammed under the rear half of the timing belt cover. This blocks the cam cog and cam from coming up high enough to lift out the cam. Well that's what happened when I tried?
Any constructive help/tips will be really, really sweet, 'cos I'm kinda sweating on this one.
Cheers. M
