Results 1 to 17 of 17
    Established Member Two Rings Blown67's Avatar
    Aug 17 2012
    Manteca, Ca
    freeway brake boosting???
    I have a 2000 b5s4 6 speed. is there a proper or improper way of brake boosting my car. Its a stage3 ko4's btw. just dont want to damage something.
    2000- B5S4 silver 6mt-asp stage3-KO4 Turbos-OEM RS4 Inlets-ASP Stage3 Fueling w/60lb Dekas-ASP 4 program ECU(Stock, Valet, 91 Oct, 93 Oct)-Slipping Stage4 clutch Clutchmasters -ssac 3" dp, 3.5" single pipe 2-Borla xr-1's exhaust-New 034Street Density Motor Mounts-New 034Street Density Trans Mounts-Apikol Rear Diff Mount- ER SMIC's, Vogtland coilovers (225K miles)
    56' Oval bug project for my Daughter
    67' Mustang Fastback project for me
    In search of a cool project for my son.
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    you have k04s. no need really.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Veteran Member Four Rings Rdp616's Avatar
    Mar 23 2009
    Hibiscus S4
    SW, Pennsylvania
    I tried doing it just messing around and it wouldn't let me. As soon as i apply the brake it cut's the throttle. Perhaps it's the stock tune .
    Single Turbo Hibiscus coming soon
    Veteran Member Three Rings z00lander's Avatar
    Apr 10 2010
    VW Atlas family mover
    everett, wa
    Brake boosting requires a tune
    Veteran Member Three Rings BoostinonYOU's Avatar
    Apr 03 2006
    02 s4, 08 Thundra, 08 gsxr 1000
    Moorpark, Ca
    Step 1 take foot off of accelerator.
    Step 2 apply pressure to brake pedal.
    Step 3 apply pressure to gas pedal :/
    APR Stage 1 13.0009 @ 105 FULL INTERIOR | 100 OCT RACE GAS
    APR Stage 2+ 12.87. @ 109.10 1.89 60FT. FULL INTERIOR FULL EXHAUST | 93/110 mix
    http://www.youtube.com/watch?v=pCPXI5hMOUI
    I have a faster 1/4 time but no slip, didn't bring my helmet and promptly got kicked off the track w/o time slip :(
    APR | JHM | OZ RACING |
    Senior Member Three Rings Sl0w_S4's Avatar
    Mar 18 2012
    BPT
    My stage 2 car does it but really no need for it with a ko4 car
    2000 S4
    Dillenger Tuned - RS4 K04 Housings with K24 compressor and RS6 turbine from SRM-JHM FMIC-034 Soild Mounts - 034 TBB
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    yessir, youll get throttle cut without a tune that allows brake boosting. Its a safety feature.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Veteran Member Three Rings jesters22's Avatar
    Oct 14 2009
    new jersey
    i was always under assumption that u get throttle cut from the abs sensors kicking on. if u turn traction control off you can brake boost.
    but brake boostin is gay
    PARTING OUT A SILVER 2001.5 S4 PM ME FOR PARTS
    http://forums.vwvortex.com/showthrea...2#post83363922
    Sep 11 2009
    NE
    YOU CAN BRAKE BOOST WITHOUT A TUNE.
    End of story. See post #5.
    Proper tune will also allow you to apply brake pedal while having gas pedal applied without throttle cut but again, for brake boosting just follow #5 on stock and tunes without brake boosting feature.
    Aug 17 2012
    Manteca, Ca
    ok thanks, again still learning more and more about these cars. I was having same issues as others where it would cut the throttle off acting like i slammed on the brakes. Thanks again and yes the k04's wake up fairly easy without brake boosting. just thought i give it a try.
    Veteran Member Three Rings omgwtfbbq!'s Avatar
    Jul 08 2009
    Daytona Beach, Fl
    Is your throttle cutting instantly or after 5-10 seconds? Mine has a delay before it cuts, but yeah on the highway there isn't any lag on my F4Hs.
    01 Sedan /// Brilliant Black ///F4H Frankenturbos w/ tubular manifolds /// J-Fonz stage 3- /// Borla 3" /// Darintake
    I hate: FMICs, flat colors, A-pillar gauge pods, vented hoods, drilled brake rotors, SSAC products, Rotas, you
    Aug 24 2014
    Newport Beach, CA
    Resurrecting an old thread, but I tried brake boosting and as soon as I let of the brake and mashed the gas the car hit the normal 16psi before it instantly dropped to 5psi and wouldn't boost past that. Had to unplug the battery and reset the ECU before it started boosting properly again. No need on a K03 car but I also had my foot on the gas when I applied the brake.
    2024 M3 Comp xDrive
    Jul 08 2009
    Daytona Beach, Fl
    Run VCDS and check for codes.
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    These cars can produce oodles of power and even with 770s, I just choose the right gear. No need for brake boost.
    Aug 24 2014
    Newport Beach, CA
    Agreed, just did it out of curiosity. Anything at 3k or above for K03 cars is pretty much instant spool. I unhooked the battery for a few minutes, car is back to normal.
    2024 M3 Comp xDrive
    Aug 06 2008
    Canadia
    brake boost, factory coding on toyotas.
    the B5 S4 is like the mafia... there is only one way out!
    Apr 02 2014
    Peachtree City Ga
    I brake boost on STG 2 SMS tune and works very well. Follow post # 5. As for those of you that think its pointless with k03s. results vs various cars suggest over and over that brake boosting helps a lot!
    As for gearing when brake boosting.
    20roll-2nd
    30roll-2nd
    40roll-3rd
    50roll-3rd
    60roll-4th
