Results 1 to 21 of 21
    Oct 04 2010
    Kearneysville West Virginia
    Still getting code p0321
    Anyone know what else might be up with my car as i have swapped the Crank Position Sensor/Engine speed sensor already and this code popped up again and the car still wont start. Any help would be much appreciated.
    Veteran Member Four Rings thenj3's Avatar
    Dec 25 2009
    North Jersey
    does the car crank and just not fire? or does it just do nothing
    2001 2.0l ct-5858 parting out- ringer racing, full race, comp turbo, maestro
    BUY MY STUFF: http://www.audizine.com/classifieds/...partout&cat=20
    http://www.audizine.com/classifieds/...-skirts&cat=54
    Oct 04 2010
    Car cranks just fine but no fire and if i pull a plug and put it close to the head i dont see spark.
    Dec 25 2009
    North Jersey
    what flywheel are you running? do you happen to have a picture of it?
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    When found in a 2004 VW Golf, Jetta, or New Beetle with 1.9l TDI-PD (BEW), check for TSB 2010461 (01-07-45 formerly 97-05-03) or 201463 (01-07-44 formerly 97-05-04) calling for a flash update to the ECU and a secondary ground installation.
    So what does your ground look like?
    Possible causes of OBD code P0321
    - Loose wires/connectors - Faulty Crank Position Sensors - Arcing secondary ignition components (coil, wires and plugs) - Low battery charge - Powertrain Control Module (PCM) The Error code is generally activated on detection of the following conditions: The P0321 code is triggered when the signal is out of range.
    Possible Solutions
    - Resecure loose wire or connectors - If battery charge is low, recharge or replaced battery - Replaced crank position sensor - Replaced starter motor
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Oct 04 2010
    Stock fw and which ground on the car
    Dec 23 2009
    Boulder, CO
    Start with the one on the valve cover but check the engine ground.
    Does your car have an immobilizer? because someone with a similar sounding problem resolved it by unplugging his battery for 3 hours and plugging back in, leaving key on for 15 minutes to reset. My 01 allroad has an immobilizer, but I'm not sure what year your car is
    Oct 04 2010
    Mine is a 01 car is getting spark and fuel pump is kicking on
    Oct 04 2010
    How likely is it to blow two CPS/speed sensors? still getting code p0321 but both sensors were used and sat outside.
    Jun 30 2008
    Erie, Pennsylvania
    I don't think it's likely to "blow" an engine speed sensor. They pretty much just stop working - no dramatic explosions.
    If you are getting spark, the sensor is working. Are the plugs all wet? Maybe it's just flooded out now.
    Oct 04 2010
    Deffinetly doubt that as i have tried to start it for the past 4 days and the pistons looked dry when i checked for spark this am. Not really sure where to go from here as i have checked all my grounds. Spark plugs are new. Everything was working when i rebuilt the motor except the rod i snapped in half.
    Jun 30 2008
    Erie, Pennsylvania
    So you have spark, but no fuel delivery then? You need to figure out what you are missing here.
    Oct 04 2010
    Correct i have spark and i have fuel pressure in the line however the car is not starting. Hmmm mabey ill go home and try to swap over my stock injectors for shits and giggles.
    Jun 30 2008
    Erie, Pennsylvania
    Maybe your injectors aren't spraying. Are the plugs wet after cranking it a bit? If not, see if you have 12V supply to the injectors during cranking (black/blue wire). That wire is powered via fuse #32.
    Oct 04 2010
    All fuses are good im wondering if i might have swapped my fuel lines but that still doesnt explain code p0321. The plugs were not wet so ill check that also thanks again everyone for your help.
    Oct 04 2010
    $20 goes to the person who comes up with the solution that makes my car start.
    Dec 23 2009
    Boulder, CO
    Quote Originally Posted by Scottydo View Post
    I thought you had no spark?
    Oct 04 2010
    Fixed that issue tested all four and got spark
    Jun 30 2008
    Erie, Pennsylvania
    Sounds like you need to get some fuel to go into your engine somehow. Check for injector pulse (LED type test light across one of the injector connectors). Check fuel pressure at the rail, etc.
    Dec 23 2009
    Boulder, CO
    Does 01 have an immobizer?
    Jun 30 2008
    Erie, Pennsylvania
    No, zero North American B5's had immobilizers from the factory. Some aftermarket programming (tunes) include a "security lock out" which consists of a code to unlock it, but it is not programmed for a RF chip in the key as the word "immobilizer" usually implies.
