Hi all,
I got a check engine light which I scanned and got 18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 - Implausible Signal.
I scan the transmission got the following error-
17125 - Torque Converter Clutch Circuit Performance or Stuck Off.
P0741 - 003 - Mechanical Failure
I clear both codes to see if it came back. It didn't come back right away but after an hour of driving code came back.
Car has about 124k miles and I have not changed the fulid/filter. Does this mean the torque converter is bad/going bad or something else?
Should I replace the fluid and filter to see if it will fix this issue?
thanks
