I have a b6 s4 and do not know what has happened. I hope you guys could maybe take a second and give me your input and advice.....
My car has been smoking very badly ever since I put my milltek down pipes and exhaust on the car 2 weeks ago, it's white grayish smoke so it's Defiantly oil!! The car drove great and fine before it went in for the exhaust job, once I got the car back I immediately noticed power loss!! The next day my oil light comes on and 5 minutes after my check engine light. I ran the code and it says o2 sensor "signals swapped" so I'm guessing whoever put the exhaust back on the car didn't put the o2 sensors back in correct. Car goes into the shop and they fix my o2 sensor and take a look at my car to find out what it causing lack of power and extreme smoking , turns out someone had swapped out and stollen my brand new oem spark plugs and replaced them with some crappy 50 cent ones from pep boys, these spark plugs were filled with oil and they told me this is my problem for " loss of power and my smoking issue" so I picked it up from the shop 2 days ago and they say its a 100% increase in power and the car was good to go. So I'm driving the car home and about 30min into the ride I can see my car smoking once again, I pulled over and the car starts to smoke a good amount while at idle. I take it to a different shop where he tells me I need to do a compression check... The results are 140 on all 8 cylinders.. So he is telling me 100% it's my piston rings?? And I need a new engine or rebuilt this one?? Does this sound correct??
What would you say my options are now?? What else could this be??
Thank you so much for any and all help guys..
Mike
