Results 1 to 11 of 11
    Veteran Member Four Rings 4ringAR's Avatar
    Sep 18 2006
    Colorado
    Mythbusting: Yellow Fog Lights
    I was on the "Yellow Fog Light" train for a while, believing they help you see in the fog/snow/rain. But, as it turns out, there is no science to support the claims.
    Here's the two most common myths:
    1: Yellow is the most visible color to the human eye.
    2: Yellow has a relatively long wavelength and therefore is less refracted by the moisture in the air.
    Lets start mythbusting:
    Nope. While it(the 575nm range) is one of the more visible colors, it is actually green, at 555nm.
    Here's the response spectra of the cone's in your eyes, normalized.
    And here's the normalized relative brightness over all visible light. As you can see its greenish yellow, right around 555nm.
    From the Plankian Locus(below) we can see that 555nm correlates to about 5500Kelvin of color temperature.
    As it turns out, thats damn close to the temperature of the sun(5800K). It is no coincidence that the human eye is most sensitive to light from the sun.
    So, for best visibility, choose an HID bulb in the 5500K range.
    This is based in truth, 575 is one of the longer wavelengths in the visible range(but not as long as red) and Lord Rayleigh discovered "Rayleigh Scattering" which essentially says that light is reflected/diffused by the molecules in the air, which is why the sky is blue(a mixture of diffused light, more blue and violet, the shorter wavelengths). Similarly, this is also why when you turn your brights on in the fog or snow it practically blinds you, the light is hitting "molecules" and reflecting the light around. So, longer wavelengths become less scattered, this is true, but it is essentially negligible when dealing with "molecules" the size of rain, snow, and fog.
    As much as I wanted it to be true that yellow fog lights improve vision....science says it is not.
    But atleast they look cool
    Feel free to chime in if you have more knowledge in the subject. Ive been exposed to radiation/light in my heat transfer course, but Im mostly self taught in the subject, so maybe my facts arent totally straight.
    2001 Audi ur-allroad, Frankenturbo'd, 6-Speed Convert: BUILD THREAD
    "Forget Tibet, free the left lane."
    Veteran Member Four Rings awdjunkies's Avatar
    Dec 18 2005
    sedan, avant, truck/suv
    nevada
    Nooo!! Say it isn't so. I love my Yellow fogs!!!
    Veteran Member Three Rings Dcass08's Avatar
    Jul 21 2011
    Rochester NH
    I got mine because they just look good on the car. I actually almost never use them.
    Jul 17 2012
    2003 toycamse w/150kmiles
    Bowie/Maryland
    While scientifically speaking your theory is partially true, it is not the whole truth, blue is actually harder to focus on than yellow because of where our eyes focus it when focusing all light, because we have more receptors in the green/yellow spectrum as you noted, our eyes can make a sharper image with light in that range. Think about it in terms of dpi for a camera, you have twice the dpi in the yellow/green spectrum as you do in the blue. This is why blue light causes glare, or an inability of our eyes to focus. See the following website for reference. Keep your fogs yellow if you want. Honestly one more reason I think the yellow fogs work is because aside from the fact that the fogs are lower on the car and focused down toward the road, the yellow light is different than the diffused blue ambient light already in the fog (at least during partial sunlight) and gives you some definition between where your fogs are pointing helping you focus better and judge distances.
    http://www.danielsternlighting.com/t...ght_color.html
    Senior Member Three Rings audinepa's Avatar
    Jul 29 2010
    2009 Audi A4 B8, 2007 GMC Envoy XL
    NEPA
    Thanks for the research, power of suggestion is sometimes stronger than what science can prove or disprove to the human mind.
    APR stage II, 034 Motorsports HFC, AWE dual quad tip (diamond black) exhaust, plasti dip grille, splitter and rims , all weather floor and trunk mats, vw oil dipstick, mirror covers sprayed alum/matte, red acrylic painted calipers, Vortex tuning spacers 15MM front, 20MM rear spacers, Rieger style roof and trunk lip spoiler, tinted windows 35% sides and back, 20% strip top front.
    Senior Member Two Rings TLO03's Avatar
    Jul 05 2011
    ct
    Yellow is euro
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    yellow = ew
    Veteran Member Four Rings tchuck's Avatar
    Apr 11 2010
    '04 A4 1.8T Avant tip
    Portland, OR
    Re: Mythbusting: Yellow Fog Lights
    Great thread, thanks.
    SfmDRuT2
    ŠTimtronic
    Apr 01 2012
    Parker, CO
    I always believe in facts and first principle analysis, being an engineer and coming from a research background. Having said that, I can tell you from years of 4-wheeling in the mountains in the winter that yellow fog/driving lights don't reflect back as much as white ones in heavy snow/blizzard conditions. This is from years of actual driving in these conditions, including in snow-cats on mountains and ski areas. The proper amber lights can make an otherwise impossible situation driveable. It probably depends a great deal on the beam pattern as much as the color, but it is an observable effect. Doesn't mean there's anything wrong with your analysis; it's quite good IMHO. But there may be other effects going on here that are not being accounted for.
    I do not have as much experience with this in rain, since out here in the southwestern US nightime driving in rain doesn't happen all that often. Maybe some folks with experience from Michigan or the Northwest or back east or Europe can chime in here.
    Jim
    2001 Audi A6 C5 2.7t 6 speed 220K miles
    1989 Maserati 16V turbo TC
    1989 Maserati Turbo II TC
    1997 Infiniti J30 WG30DE quad overhead cam
    1986 F250 1-ton IH 6.9l TurboDiesel
    Veteran Member Three Rings jmgraham78's Avatar
    Jan 19 2010
    2004 Acura TL, 2000 A6 2.7T MT, 2001 Allroad
    so green fog lights?
    2000 A6 2.7MT - currently gutted, a few parts left, PM me if you need anything.
    Sep 18 2006
    Colorado
    Quote Originally Posted by TLO03 View Post
    Yellow is euro
    French, to be precise ;)
    Quote Originally Posted by eejimm View Post
    Jim
    Also being an engineer, I like to base things on quantitative data from controlled experiments, not just personal experiences without controlled variables.
    As you noted, a LOT of it has to do with the beam pattern if the light is reflecting back at your eyes, but did you consider that most yellow/amber lights are made with selective-yellow filters, which somewhat reduces the light intensity, meaning there is less light to be reflected back? It would be interesting to measure the intensity reduction of bulbs with yellow coatings, amber lenses, lower temperature bulbs, against a control.
    Quote Originally Posted by davvinchi View Post
    But noted the most receptors are at about 550nm, so if the temperature of the light peaks at around 550nm, THAT is the most sensitive to our eyes.
