Results 1 to 11 of 11
    Veteran Member Four Rings bong2611's Avatar
    2000 A6 AVANT, 2004 MBZ ML350
    Newark, Ca.
    engine died while on the freeway....code P0322
    Here is the code
    P0322 16706 Ignition/Distributor Engine Speed Input Circuit No Signal
    Once the code was cleared. The car started right up.
    Anyone know how I can make sure this doesn't happen again?
    TIA!
    Jun 27 2010
    2002 Audi allroad 2.7T - GIAC Stage1
    Palm Desert, CA
    Crankshaft Position Sensor, next to driver's side transmission bellhousing is going kaput. Clearing codes after so many times, will do no further good...it needs to be replaced. Good thing the Bosch part is fairly inexpensive and you can get to it from under the car, once the belly pan and transmission shield is removed.
    Failure of this part is due to it not being able to send a pulsed signal back to the ECU. The ECU then determines when to fire the spark plugs based on the input of the how many times the sensor's magnet detects the reference stud passing it.
    Veteran Member Four Rings awdjunkies's Avatar
    Dec 18 2005
    sedan, avant, truck/suv
    nevada
    Quote Originally Posted by Zachariah View Post
    Here: http://genuineaudiparts.com/parts/20...icleid=1399271
    Or http://www.ecstuning.com/Audi-C5_A6-...Sensor/ES1874/
    or http://www.europaparts.com/catalogse.../?q=06A906433C
    Or go Fleabay : Or http://www.ebay.com/itm/NEW-Cranksha...22ea0d&vxp=mtr
    Veteran Member Three Rings Calimus's Avatar
    Oct 26 2010
    88' Scirocco, 89' Cabriolet, 16' A3 E-Tron, 05' FJR1300
    NW Georgia
    Yup, done this before. It's about a 30min job. Most of the time is spent unthreading and rethreading that damn retention bolt. It's a fine thread and there are lots of them. Other then that, it's a simple job.
    William
    12' 3.0T A6 Prestige - The white whale
    02' 2.7t A6 - Gone but not forgotten
    Jun 27 2010
    Palm Desert, CA
    Also, I suggest unplugging the Engine Speed Sensor. It's located directly forward of the driver side CV axle, at the axle heat shield. This will allow more room to get in and work that single bolt loose. After that - pull everything up and out through the area underneath your coolant overflow tank.
    Newark, Ca.
    do you guys think this can be done in a car port using the stock jack?
    Oct 26 2010
    NW Georgia
    Do not ever get under the car with the stock jack....ever. They are called widow makers for a reason. Buy some jackstands and a proper jack, but at the very least, some jack stands. Get those under the car and then go under it.
    William
    Dec 18 2015
    Irving/TX
    FYI.. I found the same part listed with Napa and other manufacturers with different part numbers but same item. Also the prices vary depending on which part number you provide as well.. When I called Napa they kept trying to give me a $150 part so I started drilling them with each part number and finally they found one that was a reasonable price.. Oh wait is there a different part number if your car is automatic or manual?
    VW#06A906433C
    Bosch#261210147 and 261210148, 078906433F
    HELLA# 6PU009146-251
    Dec 18 2015
    Irving/TX
    Any one know if you can use the same part for both automatic and manual?
    Jun 04 2014
    Grand Island, ny
    I re used the one in my car auto to manual swap. Had no issues. Just double check the length of where it mounts to the bellhousing to the tip of the pickup.
    Dec 18 2015
    Irving/TX
    Thanks for the input.. Anyone else?
