Results 1 to 22 of 22
    Sep 17 2012
    Houston, Texas
    S-Tronic gearbox question
    Anybody know if the S-Tronic dual-clutch box is one of those "adaptive" automatics similar to what Mercedes uses, or does it respond the same way all the time when in auto mode? Not referring to the various Drive Select settings but just the behaviour of the standard box if you leave everything alone or you don't have the Drive Select option. Also, when you pull the shift lever down again into Sport mode does that basically just speed up shift times and hold each gear longer? I am not a fan of the adaptive/intelligent automatics, I'd rather have it behave predictably all the time. Thanks for any info.
    Dec 02 2011
    Baltimore, MD
    It is adaptive.
    2012 S4 - Monsoon Gray Ti S-tronic - AWE Exhaust, resonated
    Established Member Two Rings zamm3k's Avatar
    Aug 06 2012
    Doral, FL
    Quote Originally Posted by Monsoon View Post
    I don't think you'll have issues with it's "adaptiveness". D is for cruising around and S is for spirited driving. It behaves really well at both gears. And then manual is for full control ( except for the god damn auto-shift at redline /end rant)
    Sep 17 2012
    Houston, Texas
    Quote Originally Posted by zamm3k View Post
    Thanks, good to know. Hey, maybe a dumb question but why does everyone complain about shifting at redline in manual mode? Seems like that's where you'd want it to shift since the torque and hp curves both fall off at 5500 rpm. What's the issues with that?
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    In Manual mode, some will NOT shift at redline, they will short shift. Also, some people (for some reason) want them to bang off the rev limiter, and not shift it for them, since they think manual mode means it shouldn't protect itself if they want to overrev the engine
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Sep 19 2009
    MA
    Quote Originally Posted by NWS4Guy View Post
    is this a function as design thing or a flaw?
    Established Member Two Rings korben's Avatar
    Jun 28 2012
    PA
    Re: S-Tronic gearbox question
    It's annoying that it shifts for you because sometimes you upshift right before, or after, it automatically does and it shifts up 2 gears. Has nothing to do with over revving, that's exactly what a rev limiter is for. The nannies will prevent a downshift in the DSG if it will cause an over rev.
    2013 Ibis White S4 | DSG | Sport Diff | Nav | B&O | Carbon Inlays | Adv Key | Nappa | 19" Peelers
    Aug 06 2012
    Doral, FL
    It's hard to over rev an ,essentially, automatic transmission. But a soft rev can be put in place as to not over rev your engine, in order to make the car more predictable and controllable. I'm sure you've had the occasional double upshift occur to you. As much as you can get used to it, it's still annoying. BMW's 3 series automatic tranny has this if you purchase it with the sport transmission option.
    In the end, it has nothing to do with bouncing off the rev limiter or drifting my car. Its about keeping control of my car as much as possible without electronics interfering.
    Sep 17 2012
    Houston, Texas
    So, even if it's in manual mode it will still upshift for you if it senses overrev? To me that's not really manual mode but it kinda makes sense. In my current car in manual mode it will just bounce off the limiter all day until you finally shift it yourself. Not really sure which is better and I mainly drive in auto/sport mode anyway which is probably what I will do with the S4.
    Dec 02 2011
    Baltimore, MD
    Correct, it will upshift for you. It's really not quite full manual mode.
    Sep 29 2009
    It's like this. The ECU and TCU can shift for you, better than you can. If you have it in M mode and shift yourself, that means you just shortshifted and left RPM's and power on the table, if it shifts for you, then you shift and end up in a higher than anticipated gear it means you were too slow on the shift.
    If you want to drive fast and well around a track, focus on your braking, your lines, and you entry and exit. Let the DSG shift for you on upshifts, and only override on downshifts to get you into the lower gear and power band, then you can flip it back into "S" (or "D" if you have in in Dynamic with ADS or Sport Diff) to let it take over for the upshifts again. If you want total control, you need a true manual, you make a sacrifice with a DSG - some control for blistering rev matched gear changes.
    Aug 10 2012
    B8.5 S4 - Caddi SRX
    Bothell/WA
    Wish our cars had the S button like the new RS5 has, which does not shift gears automatically at redline in manual mode with it turned on :)
    Jun 18 2012
    Quote Originally Posted by sakill3r View Post
    I wonder if getting an ECU tune would change the behavior to work like the S button, no forced up shifts...
    Jun 28 2012
    PA
    I'm sure it could be done, but the only way I'm reflashing the DSG is if it comes with a warranty, don't need a 12k headache just to remove an annoyance.
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    There has been at least one company that said they can re-flash the TCM, but fed us some long story about how it's too complicated for their dealership network to get the stuff to do it...they led us on for over a year.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Aug 06 2012
    Doral, FL
    I'm just going to give a short example of what I'm trying to say. Imagine you track the car, and during a turn A or turn B, you need your whole rev band to go through the turn. Now imagine in the middle of one of those turns you hit the rev limiter and ur tranny shifts for you, leaving you at a lower gear and loss of torque/power through a curve.
    If anything, the S Tronic should have less compromises than the manual (its supposed to be the best of both worlds). Regardless, this wasn't a deal breaker for me. I just feel like it doesn't have to be a necessary compromise. I'm sure if Audi wanted to make it bounce of the rev limiter they could do so safely. Most cars that do that have an override where if you are beating the crap out of the engine it'll cut fuel or automatically shift after so many bounces of the rev limiter.
    With all that said. I still love my S Tronic.
    Sep 17 2012
    Houston, Texas
    Thanks for the feedback. I have no intention of tracking the car and it sounds like their shift programming and dual-clutch speed will work quite well for semi-agressive street driving. Seems like most folks are pretty happy with their S-Tronic so I am still psyched about getting it. Car is scheduled for dealer delivery end of October. This Halloween could be really fun.
    Apr 24 2009
    Frisco, TX
    ^ Exactly. I just had an RS5 out on the track last weekend and it was not short shifting. Very useful because I don't want the car to shift for me in the middle of a turn.
    Aug 06 2012
    Doral, FL
    Oh don't get me wrong. You SHOULD BE psyched about getting S Tronic. Lovely transmission, and really worth it in all honesty. The pros far outweigh the cons.
    Jun 28 2012
    PA
    Definitely agree. For as much as people, myself included, complain about certain aspects of it, it really is a great trans.
    Deactivated Four Rings Kay15's Avatar
    Jun 12 2009
    Audi A6
    Norway
    S-Tronic Tune would make it a godly tranny on these cars!
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 23 2012
    2017 BMW X1
    Bay Area CA
    Quote Originally Posted by Kavan View Post
    That would be awesome although I drive in D like traditional automatic 90% of the time.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
