So I am trying to confirm some more information on my engine mounts before I order them up.
1) Do I need electrical connectors on the left side one? Reason being, ETKA has 2 part numbers for the left side for my model year showing and I can't tell which mine would be.
2) If it does have the electric, do I need to keep those or do they serve no purpose?
Info from other threads...
Originally Posted by
Matt@EuropaParts
The 034's would require resistors, but if your car is a 2.0T, it shouldn't have the sensors in the first place. Only the V8 cars do as far as I know.
rs6
My 2.0T has sensors - didn't check the right side yet but the left does for sure.
PNW Avant
I believe the B5S4 mounts are fluid filled, B5 RS4 mounts are not fluid filled, and still pretty inexpensive.
Info from ETKA...
B7 A4 4cyl BPG engine code:
B7 RS4:
B5 S4:
B5 RS4:
From B5 to B7, they all seem to be some variation of 8D0 199 379 (B5) or 8E0 199 379 (B7) for left and right. The only numbers that change are the last letters in most cases but ones with electric option have different p/n's for left and right since the right is not offered with electric.
When I was doing the timing belt last weekend I tried to see if there was an electrical connector on the left side but couldn't be sure... Will it throw a code if I throw in a mount without a electrical connector?
Couldn't decide between posting a new thread or just adding to this one. This one had a good title, and other good info, so I chose to add on in hopes of not scattering all the information on the B7 engine mounts across 20 different threads...
