How would a disconnected diverter valve affect engine performance?
I just did a boost leak test on my car, and I noticed that the line from the N249 to the diverter valve was popped off, probably has been for weeks. The car is currently undrivable (ECM being reprogrammed), so I can't take it out for a spin to find out if re-attaching it has fixed anything. But I was curious to know how a diverter valve that isn't hooked up to vacuum would affect engine performance.
I did the boost leak test because boost has been limited to about 5psi on my 2001 A4 avant TQM. Should be 10-11psi. I was trying to determine if it's caused by a boost leak, a clogged cat (been getting a lot of P0420's lately) or some other issue... like perhaps a disconnected line to the diverter valve?
