Results 1 to 18 of 18
    Established Member Two Rings CHAUHANspeed's Avatar
    Jul 23 2012
    Bartlett, IL
    Coolant temperature sensor replacement
    I got a check engine light this weekend with a code of p2181 - and I also noticed my gauge hasn't been very accurate recently..I diagnosed the issue of having a bad CTS.
    However, after reading numerous threads on how to replace the CTS on the B7 A4, I am confused a little. There are mixed answers in bunch of threads and I figured I should clear this up.
    My question is, do I drain the coolant before I pull the sensor out or should I just pull the sensor and install new one?
    http://www.audizine.com/forum/showth...=1#post7368820
    http://www.audizine.com/forum/showth...ical-Questions
    sorry in advance if I missed a thread that explained this in my search of Audizine.
    2006 Audi A4 Silver | since 8/28/12 | Coming Soon: Turbo Upgrade, Eurodyne tune
    AKA: megaman81
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    You can probably pop it out and back in without draining, but how big a mess it will be? Not sure. I drained the coolant for my thermostat replacement, and some still came out when we pulled the sensor.
    2021 Audi S4, P34 Intake
    Jun 27 2011
    I would drain the coolant. If it hasn't been changed in a few years it probably needs a refresher anyway. G12 isn't that expensive anyway.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 14 2011
    12 Taco, 13 Ex, 16 Civic EX, 15 JKUR
    I'd drain the fluid, but there will still be coolant up there that will make a mess when you pop it out. Just the joys of working on the cooling system.
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
    Veteran Member Four Rings bman005's Avatar
    Sep 06 2011
    2015 Silverado, 2012 A4 Avant. Former; 90 Corrado, 97 Golf, 05.5 A4, 2010 Tiguan
    Harrisburg, Pa
    I'd replace the thermostat since that's whats most likely wrong with your car. The sensor rarely fails in any other way than an open circuit which gives you a sensor resistance fault. Check freeze frame data if you have it. If the coolant temp isn't -40C or something extremely cold like that you need a thermostat.
    New Build, 2010 Tiguan. Details to com
    Jul 23 2012
    Bartlett, IL
    After doing more research, i am also leaning towards the thermostat! This job seems time consuming!
    AKA: megaman81
    Jun 27 2011
    Quote Originally Posted by megaman81 View Post
    Not really. Longest part for me was waiting for the coolant to drain.
    -CP
    2017 Q7 3.0t
    Sep 06 2011
    Harrisburg, Pa
    I'm gonna agree with Charles on this one. I did mine over my lunch break
    Veteran Member Three Rings J.Owen's Avatar
    Aug 12 2010
    I run -361* of Camber.
    Bucks County, PA
    Also, I have to check on the B7 since I haven't done the CTS yet, but usually you can unscrew the reservoir cap, squeeze upper rad hose and replace reservoir cap while still squeezing rad hose, remove and replace CTS. Squeezing the hose will create enough of a vacuum in the system that you can replace the sensor without losing any coolant.
    Expenses in F1 have gone down since the 1960s because teams don't need an extra pit crew to help the driver carry around his balls when he is not in the car.
    Jul 23 2012
    Bartlett, IL
    Quote Originally Posted by J.Owen View Post
    Thats a cool trick if it works! what thermostats do you guys usually recommend?
    AKA: megaman81
    Oct 14 2011
    ? I don't think you have a choice.....it's an assembly. I don't think I understand the question.
    Oct 14 2011
    Quote Originally Posted by bman005 View Post
    You guys are good. I fought with everything doing the thermostat. I think I could do it in under 2 hours next time. It takes me 20 minutes to get it jacked up, get the belly pan off, and start draining the coolant. I'd be luck to have the old one out in less than an hour.
    Either way, it's not a difficult job.
    Veteran Member Four Rings IKE20VA4's Avatar
    Apr 08 2005
    Portland, OR
    I just did this today, so I can clarify a few things.
    1) You're going to have about 16-20 oz of coolant gush out when you pull the old coolant temp sensor.
    2) When I pulled mine, the o-ring was left in the hole, so I wasn't able to jam the new one in right away. Had to fish out the old o-ring and then the new one went in fine.
    3) At first the CTS was hard to find but once you find it, access is pretty easy.
    Veteran Member Three Rings CystmX's Avatar
    Feb 04 2010
    Andrews AFB, MD
    Quote Originally Posted by IKE20VA4 View Post
    It gushed out even though you drained it first?
    Apr 08 2005
    Portland, OR
    I didn't drain it. So I don't know. I think I read that some will still come out even if you drain but don't quote me on that.
    Senior Member Three Rings pDubs's Avatar
    Jan 12 2012
    2005 Kawasaki ZX6R, 1973 Honda CB350F
    Fairfax, VA
    I got the p2181 this week also. After some research I'm thinking it's the thermostat. Gonna have to knock that out next weekend. My temperature gauge isn't really going above 1/4, normally around 1/2. Is it bad if I drive the car until I can change the thermostat?
    Jun 26 2008
    Chicago, IL
    Another common issue that people should look out for. Bump for a spring cleaning maintenance check! Thermostat check!
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Thanks..... Title is misleading a little. Fluctuating temp gauge is usually thermostat. I would not drive the car for a long period of time as your engine may try to over compensate the wrong readings from the tstat and you could over heat very quickly demolishing your head and building oil sludge (oil consumption can get very bad).
