Originally Posted by
Castor Troy
yes, this would increase the volume of fuel delivered. in tank pump would act like a lift pump, flowing high volume and low pressure, and the second pump would be high pressure.
Only if the low pressure pump flowed enough volume at the supply pressure to keep up with the high pressure pump. If they are grossly mismatched then the low pressure pump will become a restriction and the supply pressure of the 2nd stage pump can drop, which is where surge tanks come into play.
Instead of using the stock pump I'd look at a low pressure high volume pump.
rider384
Why would the pressure be compounding? The stock pump wouldn't still be pushing 60psi (or at least I assume) since the inline would be supplying the pressure to the rail. All the in tank pump would be doing is providing a low-pressure supply of fuel for the inline. At least that's my thought.
Does a dead inline pump cause too much of a restriction on the stock pump to run out of boost? I'm thinking of having the inline on a boost-triggered circuit.
The pressure won't be compounding, the fuel rail will only ever see the pressure that the FPR it is set at, unless the pumps can outflow the FPR then you would have fuel pressure spikes at low injector duty cycles. If the secondary pump had an internal FPR that was referencing supply pressure then you would see a compounding of fuel pressures as eejimm says.
Fuel pumps are positive displacement devices, so a non working pump would create a large restriction, unless it has a relieve valve in it which most only have a pressure limiting valve.
