Results 1 to 10 of 10
    Veteran Member Three Rings tuner culture's Avatar
    Jul 19 2007
    1.8T Q 1+, Honda Odessy
    Florida
    Battery died - now gas gauge and gas cluster reading zero?
    got out from work today and car battery was dead, battery only 5 months old. Jumped the car but the gas gauge show emptyand gas reading in the center cluster show 0 miles and the gas tank icon shows in the cluster.
    Any clue whats going on. I was thinking of unhooking the battery to see if it resets the gas settings in the morning, but not sure.
    I just filled up yesterday full tank, so plenty of gas. I drove the car 8 miles and checked my parking spot at work and no signs of gas leak.
    any help would be apprecaited
    2003 A4 1.8Tq
    19" RPM | Bridgestone Potenza RE960AS
    APR stage 1+ | Forge 007 | Kerscher | AWE | Race tec | RS4 pedals | S4 Grille |
    Veteran Member Four Rings Myst420's Avatar
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    Try disconnecting the battery for a few minutes and then re-connect it. I've had my gas gauge go screwy on me in the past and that took care of it.
    02 A4 Quattro 1.8T
    Votex kit, Neuspeed race springs and Koni struts, 18" AT Italia Flash Sport wheels, painted lowers.
    Nuespeed: Chip, Exhaust, Short Shifter, Rear Sway-Bar, Dual Side-Mount Intercoolers, Forge Splitter.
    Jun 27 2011
    Check that all te fuses are intact. Could have blown a fuse.
    Sounds like there could be a short in the system though given the battery drain.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Rest in Peace Four Rings EURO_DOLL's Avatar
    Jul 22 2011
    Long Island, NY
    The same thing happened to me when I first brought home my last B6 a couple years ago. But the PO informed me that the battery was old and that it was going to need replacing soon. I didn't realize "soon" was 3 days later. Thing died in a snow storm! Someone helped me jump it and then I put in a brand new battery. After the install, I had this issue for a couple of days and it eventually reset itself.
    I don't remember the exact number of miles or exact length of time that it took to fix itself, but it did take care of itself. GL
    BOOBS& BOOST
    Current: Bagged 04 B6 A4 1.8T | Bagged 2017 MK7 Golf R
    Past: 03 B6 A4 3.0 Quattro
    Bagged 02 B6 A4 1.8T FWD
    14 MK6 Jetta
    Static 94 Corrado SLC
    15 Golf TDI
    Instagram: @boobsandboost
    Veteran Member Four Rings A4OrlandoB6's Avatar
    Aug 03 2008
    Philadelphia, PA
    Pull the instrument cluster fuse and put it back it. good to go.
    -Kyle
    2005 Audi A4 Avant USP / 1.8T / Brilliant Red
    2004 Audi A4 1.8T - big turbo and some stuff - gone
    2003 Audi A4 1.8TQM - gone
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Quote Originally Posted by EURO_DOLL View Post
    ^^^This^^^
    My experience as well.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Jun 08 2007
    Orlando, Fl
    Fuses are not the problem. Pull the battery cables off and reattach. Give it a couple of cycles of on/off driving and it will reset itself. I've had this happen a couple of times.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Senior Member Three Rings Albertk's Avatar
    Dec 08 2010
    Audi A4 3.0, Specialized Lanster
    Hanover, New Hampshire
    Quote Originally Posted by Myst420 View Post
    This. Fixed it for me when I had the same problem
    Established Member Two Rings black2.7t's Avatar
    Mar 07 2012
    2003 Audi A4 1.8T - traded 2005 Cobalt SS - DD
    knoxville
    yeah happened to me, dropped the car off at dealership for coil pack recall and had a full tank of gas got it back and it said it was empty lol you could imagine what was running through my head -.- (they told me they didnt disconnect anyhing that would cause that) just drive the car for alitle it will correct itself
    03 A4 1.8T, silver/black, 5speed, Stage 1+ APR, gutted cat, APR Injectors, 6puck ACT unsprung clutch disc, light weight clutch masters flywheel, 034 street density tranny mount.
    Senior Member Two Rings alimo20's Avatar
    Jan 25 2011
    Philly
    i just recently had this happen to me. although it was for no reason at all. my gas was near empty so i filled it up. gauge read empty after the fill up, so i just drove it around until it was near empty (estimating around 300mi/tank) and it fixed itself. must get stuck randomly.
