    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Cost of replacing output shaft seal on driveline to rear wheels --Avant?
    It looks like I am leaking just a bit of auto-trans fluid from the bottom of the car- Our mechanic says it needs a seal replaced. He claims it is the seal where the driveline heads back from the trans to the rear wheels on the Avant.
    Anyone ever seen this? How much for seal and approx repair time for labor?
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    Daniel J
    @gtg_drives
    Jun 15 2011
    Exiled.......
    Is this what I need? Your referenced thread talks about gear oil, the seal I am showing here talks about automatic transmission fluid. Where's the disconnect here?
    The leak is in the middle area of the car for what its worth?
    http://www.ecstuning.com/Audi-B6_A4-...eal/ES1899462/
    Is there a different seal I need to be looking for?
    Jun 30 2008
    Erie, Pennsylvania
    The ECS description is slightly misleading. It is absolutely gear oil (not ATF) that would be leaking from the rear output shaft seal that you linked. That is the correct seal for an A4 quattro automatic. Very common failure.
    Jun 15 2011
    Exiled.......
    XLNT---thanks. It doesnt sound too tough to do-replace the seal that is.
