Results 1 to 16 of 16
    Senior Member Two Rings temanuele's Avatar
    Apr 05 2012
    AZ
    Need to build bottom end: would like others' opinions
    With the plan to go full E85, I feel that it is time to upgrade my connecting rods. I was hoping to get some insight from others on here who have done this before, as to the best course of action. The options I was thinking are:
    1) Just bite the bullet and pay a shop 2K+ to install rods
    2) Hold out for someone selling a built short block, and swap it with mine
    3) Cross my fingers and hope I don't throw a stock rod through the block
    It sounds like installing rods from the bottom just isn't feasible, but it seems like a lot of labor cost to pull the motor just to drop some rods in. So that then gets me thinking, well the motor is out so maybe I should do pistons...bore it out. on and on and on. Why can't I just be happy with a running car
    May 16 2008
    South Texas
    Quote Originally Posted by temanuele View Post
    I'ts possible to install rods without removing the engine but it would be much more of a pain in the ass to do so.
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Quote Originally Posted by Scotty@Advanced View Post
    how so?
    How do you remove the heads (exhaust manis create all the trouble) to get the pistons back in the hole?
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Jul 28 2009
    Philadelphia PA
    Do it yourself, building a motor isn't rocket science , people have been doing it for years, you need good tools (including some special ones), patience, a bentley manual, a place to do it and some one to go to when u get stuck (aka people on the forums who are truly knowledgeable ).
    c8 a6 allroad
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by rtl5009 View Post
    how so?
    He's saying remove head and oil pan, leave block connected to trans. People do it this way on 1.8Ts a lot (especially VW)
    OP, buy a built short block and toss it in your car. DO NOT, I repeat DO NOT take your car down and think you'll have it done in "a few weeks" because it never will be. Get E85 running well at lower boost on the car, build a block on the side, and when it's all set toss it in
    - Clint
    Jul 28 2009
    Philadelphia PA
    I guess you could undo the downpipes, undo the head bolts and lift it out as a whole head/main/turbo combo. you would have to fanangle the turbo coolant/oil feeds too. and the coolant hard pipe for the heads.....
    way not worth it........
    c8 a6 allroad
    Apr 05 2012
    AZ
    Did you install the parts yourself for your built motor?
    Jul 28 2009
    Philadelphia PA
    Yes, the whole shebang.
    c8 a6 allroad
    Veteran Member Four Rings Rdp616's Avatar
    Mar 23 2009
    Hibiscus S4
    SW, Pennsylvania
    I've always wondered why there is some consensus when it comes to building a motor that it's insanely difficult..Getting it out is much harder lol. Of course, the bottom end is the easiest (IMO anyway). I have yet to rebuild a cylinder head on a car. I've done a couple Quad/dirtbike cylinder heads. But that frankly is child's play. Once you have the block on an engine stand, and the proper tools. It's actually pretty easy. And the feeling of gratification afterwards is pretty awesome too. Knowing that thing pulling you down the highway was built by YOU.
    Single Turbo Hibiscus coming soon
    Apr 05 2012
    AZ
    Quote Originally Posted by Rdp616 View Post
    Thanks for giving me some confidence
    May 13 2011
    2015 BMW F30
    Hey Thomas. I agree, buy a spare motor and build it yourself.
    | Autospeed | JHM | Pure MS
    Oct 06 2011
    Audi S4 /Wifes 2011 cruz..bleh
    Southwest Michigan
    Find a used motor for sale local and build it over the winter then swap your finished motor in when its done.
    I have a Scirocco I am parting out because I was just taking it apart to do a few things. I hit a few snags, then ran out of money, then had to move. The car has sat for seven years at this point and mice got into the wiring and everywhere else.
    Long term projects suck.
    Senior Member Three Rings haggard69er's Avatar
    May 20 2007
    Alligators
    pittsburgh
    build it yourself. like many have already said, there is a lot of info on how to do it. jibberjive has a sticky on the main page of the forum dealing with engine specs, tolerances and so fourth. look up goohead, he has a engine build thread on car domain, read through gearheads build thread. there are so many, you just have to search.
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    I'm building a block over the crappy season...if you need direction rtl5009 knows his shit.
    Sep 11 2009
    NE
    There is no way you could build the engine with it sitting inside the engine bay without going bananas and eventually pulling it out anyway.
    And as others said.... don't expect you'll be done in any reasonable timeframe. Getting a spare long block is a must. Building engine is like upcoming battle, the plans don't survive first bolt coming out!
    Stuff will take far longer than you think. You will question yourself, search for info for hours, order missing/damaged parts, swear that you filed ring 0.001" too much or scratched it and need new set, etc, etc. Fun times. But in the end... satisfaction and confidence ensues.
    May 20 2007
    Alligators
    pittsburgh
    Quote Originally Posted by aysix View Post
    ^big 2nd
