Results 1 to 10 of 10
    Established Member Two Rings JRunior's Avatar
    Aug 03 2012
    New Jersey
    First time running VCDS, 1 fault found, should I be worried?
    Mileage: 18840km/11706miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    1 Fault Found:
    15789 - Engine Speed Sensor (G28)
    P0321 00 [100] - Implausible Signal
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 14739 km
    Date: 2012.08.01
    Time: 23:39:17
    Readiness: 0000 0000
    2012 S4 Monsoon Gray | 6MT | Prestige | Sports Differential | Titanium package | Black Silk Nappa Leather | Stainless Steel Mesh Inlays
    Veteran Member Four Rings helix139's Avatar
    Apr 21 2010
    Florida
    Nah. Clear it and see if it comes back
    2011 S4 Premium Plus 6MT, Sepang Blue Pearl, Black Silk Nappa, Sport Diff, B&O, B8.5 MMI 3G+ Nav, Ti Pkg
    APR Stage 2+ Stock/93/100/Valet, Eurocode Alu Kreuz, Eurocode USS Sways + End Links, Eurocode Meisterwerk SSK, Roc Euro Intake, Apikol Rear Diff Mount, Fast Intentions Exhaust, Escort 9500xi, Laser Interceptor, P3 Vent Gauge, VCDS
    Mar 02 2010
    2017 F-150 Raptor
    Winchester, VA
    The computer logs anything and everything. You will always find something weird in there depending on how often you check it.
    Current: 2014 Cayman S | 2017 F-150 Raptor
    Past: 2013 RS5 | 2015 Rubicon on 37's, 4" lift. | 2001 S4 | 2013 Wrangler on 35's, 3" lift. | 2010 S4 | 2006 A4TQM | 2001 A4TQM
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    The fault only occured once. I wouldn't worry about it.
    Jul 07 2009
    Lebanon
    It occurred once and about a month ago. Clear it and re-scan after a couple of days or so.
    SOLD: 2010 A5
    Active Member Two Rings akKoRdN2U's Avatar
    Mar 26 2012
    Houston, TX
    I might keep an eye on it then take it to a dealer when you get time. I had a couple one off codes (ABS and AWD). The ABS was nothing but a sensor needed replacing on the sport diff.
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 23 2012
    2017 BMW X1
    Bay Area CA
    I don't even care.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Veteran Member Four Rings quattroloco's Avatar
    May 07 2012
    olympic penninsula/WA
    if the engine is off wont you always get a engine speed sensor error?
    B6 A4 AVANT swaped 2.7T 6MT S4 Drivetrain still illegal
    Dec 23 2011
    2004 BMW R1150RT
    MA
    Quote Originally Posted by quattroloco View Post
    I've always run scans with the ignition on but the engine off. I've never received engine speed errors.
    current: 2013 Focus ST; gone: 2010 B8 S4 P+, Ibis, Stronic
    Veteran Member Four Rings The_Auto_Tech's Avatar
    Nov 29 2010
    2001 Audi allroad 6MT
    Des Moines, IA
    It's funny to come from the B5 world to the B8 world and read. The check engine light or a fault code always scares the pants off the new Audi owners but in the B5 world, the check engine light just means that the car is probably still running. lol
    Joking aside, just clear it. These cars are very picky and throw faults if it detects things even just slightly out of "range." This is especially true when you talk about fuel trims. It used to be a variance of 10% but it's now closer to 5%. If you have a fault that's bad enough to cause any issue you'll get a light.
    2006 Ford F-250 Amarillo Edition - MOARYLW - Mine
    2001 Audi allroad 6MT - Wife's
    Previous - MKIII Jetta, MKIV Jetta x2, MKIV GTi, B5.5 Passat x3, B5 A4 x2, B5 S4 x2, and tons of Domestic/Japanese crap
    - Cody T.
