Results 1 to 24 of 24
    Established Member Two Rings blasterman's Avatar
    Jun 01 2007
    L.A./Palmdale
    Q5 Wheel Fitment
    I'm looking at upgrading my wheels to a 20x10 et 20. Does anyone know if it will fit properly?
    Feb 13 2004
    Silicon Valley, CA
    Max just put 20s on his wife's Q5, not sure exact specs
    http://www.audizine.com/forum/showth...98772-STSIS-Q5
    and brioanjnr too
    http://www.audizine.com/forum/showth...tar-F14-wheels
    Kevin - Moderator, Audizine
    Veteran Member Three Rings D_Frost's Avatar
    Oct 03 2011
    WA
    Seeing as the following OEM wheel specs are for the Q5:
    The center bore is 66.6; bolt pattern 5x112
    18x8 ET39 standard wheel (8R0 601 025 C)
    19x8 ET39 standard Prestige pkg wheels (8R0 601 025 J)
    20x8.5 ET33 optional Prestige pkg wheels 5-spoke (8R0 601 025 D)
    20x8.5 ET33 optional Prestige pkg wheels 10-spoke chrome (8R0 601 025 K)
    20x8.5 ET33 2009 S-line wheel (8R0 601 025 Q)
    20x8.5 ET33 2010+ S-line wheel (8R0 601 025 N)
    You're looking at quite a bit of poke on the 20x10 ET20, unless you are looking to add wheel arches :)
    Based off those numbers, you should be able to figure out which wheel you got and measure how much further you want to "move" the surface of the wheel by changing width and offset by using a wheel offset calculator from the web.
    Established Member Two Rings bagel's Avatar
    May 03 2007
    Q5TEALTH / A4 3.0TDI MTM / '85 VW Fridge
    BDC Garage
    its an easy calculation;
    OEM 20" wheels: 20x8.5 ET33
    20x10 wheels are 1.5" / 38mm wider than 20x8.5 OEM wheels. (thats 19mm outwards and 19mm inwards if they were the same offset)
    ET20 = 13mm outwards compared to ET33 on the OEM's.
    that means the wheels will stick out 32mm (13 + 19) or about 1.25" more than 20" OEM wheels. So the question is, how close are the OEM's to the fender? I don't own a Q5 so I dont know
    Also, fitment will depend on what tires you are planning on running.
    Apr 15 2012
    AriZona
    Will my wheels from my S4 (19x8.5, et 43) work on my Q5?
    Jun 01 2007
    L.A./Palmdale
    Thanks for your help guys.
    Don't know if anyone else has ran into this but, I found this site that will do a side-by-side comparison on wheel sizes.
    http://www.rimsntires.com/specs.jsp
    Pandi - going by your wheel spec and using the web link above, it looks like they would fit.
    Q5 - 235/55/19 x 8.0 ET 39
    S4 - 245/40/19 x 9.5 ET 43
    The S4 wheel is 9 mm (0.4'') closer to suspension/brakes components. You should still have enough clearance, if the tire size is correct for the S4.
    Veteran Member Three Rings Maximum's Avatar
    May 27 2012
    My lounge
    Galt
    The 20x10 stick out slightly but it looks good...well at least we like it!
    2012 S4 Prestige, Monsoon Grey, STaSIS exhaust/springs, APR Stage II+, RS grill, RS shifter knob, Roc-Euro intake, Ziza LEDs, CREE W16W Reverse LEDs. RS6 flat bottom wheel, MMI 3G+, P3 Cars guage, Passport mirror radar, LI, 034 trans mount & end links
    2012 Q5 2.0T Blaze Orange Matte Metallic, STaSIS Tune, exhaust & 20x10 rims, RS grill, 2013 lights, LED interior, ACCUAIR B8 Sports suspension
    2003 A4 Avant 1.8T silver
    Jun 01 2007
    L.A./Palmdale
    Maximum - any rubbing when turning?
    May 27 2012
    My lounge
    Galt
    No rubbing
    May 03 2007
    BDC Garage
    You are running 10x20 all around Maximum? what ET?
    May 27 2012
    My lounge
    Galt
    Q5 Wheel Fitment
    Quote Originally Posted by bagel View Post
    ET 25 on the wheels? Sorry for the delayed response!
    Established Member Two Rings Euro Whips's Avatar
    Mar 10 2012
    2015 Audi Q5, 2014 Jeep JK Wrangler Sahara Unlimited
    Orange County, CA
    Go 22's!!! IMO 20's look small (20's are the stock wheel with the S-Line Pkg)
    Vossen has a sick 5 spoke with deep concave that looks awesome. Go to the Wheel Warehouse website and then to the Audi Gallery for a look at a Q5 with them on.
    Veteran Member Four Rings adbender's Avatar
    Jun 13 2009
    2021 911 Turbo and 2023 Q5 Technik
    Quote Originally Posted by pandi View Post
    Same bolt pattern. Will be tucked in another 10mm than stock. Great winter option or add spacers.
    That's my plan
    2024 S5 Sportback Technik
    2023 Q5 2.0 Technik
    2018 Q5 2.0 Premium Plus (Totalled)
    2015 RS5|Stage 2 (Sadly Sold)
    2013 Q5 2.0T|Premium Plus (Sold)
    2010 S4|6MT|APR Stage 2+Everything (Loved but Sold)
    2005 A4 UltraSport (My First)
    May 03 2007
    BDC Garage
    Quote Originally Posted by Maximum View Post
    cool, thanks.
    glad to hear 10's fit fine as thats what I'm looking to run when I get my Q!
    May 27 2012
    My lounge
    Galt
    Q5 Wheel Fitment
    I like em a lot! The ride is still very comfortable....more so than my S4 IMO
    Veteran Member Four Rings redneck truck's Avatar
    Apr 22 2010
    2001 TTQ TDI Roadster 6MT, 2001 A6 4.2 6MT, 2005 Jetta Wagon TDI 5MT, 2006 CBR1000RR
    Plano, TX
    Howdy! New to this area of the forum, and sorry for reviving an old thread, but do any of you know if the 8R0 601 025 J 19x8 ET39 wheels (image below) are cast, die-cast, or forged, and who manufactures them?
    Oct 03 2011
    WA
    Can't say for certain, but majority of all OEM wheels are low pressure cast, which is a grade up from gravity casting, but not as lightweight as forged.
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Quote Originally Posted by redneck truck View Post
    Echo to D-Frost on the low pressure casting. I can't imagine they're forged. Best guess at the manufacturer is Ronal, although I couldn't confirm that. I suppose Fuchs is also a possibility, with Superior Industries being at the back of the pack. Good questions - I wish I could offer for-certain answers.
    EDIT
    Ok, assuming their list is current, we can exclude Superior.
    http://www.supind.com/about/CarList.aspx
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    It has the original wheels for Q5
    Products in the Czech Republic, Hungary and I think in Poland
    Original wheels have a serial number on the inside side
    Senior Member Two Rings SpeedyFred's Avatar
    May 07 2013
    Belgium W-VL
    I am currently looking for a nice set of wheels. The safest choice would be the famous split 7 spokes (rs4 reps). They are slightly wider then the stock wheels and have some more poke. 20x9 et29. But they are too common. So i'm still searching...
    I came accros various wheelbrands that would have been nice, however. Since i live in Belgium i cannot find any dealers. Now i finally found something. ACE Convex 20x10 et40 or 20x10,5 et33. Witch would be the better fit? I'm looking for a flush fitment
    these are convex 20x10,5 et33 btw.
    Registered User Four Rings mike@vossen's Avatar
    Jan 23 2013
    Miami | Atlanta | Kingston
    Quote Originally Posted by Euro Whips View Post
    Thanks. They will be slightly aggresive without fender flares. You can find out fitments at [email protected]
    https://www.vossenwheels.com/CarGall...VSCV3-743.aspx
    https://www.vossenwheels.com/CarGall...VSCV3-934.aspx
    Feb 12 2011
    Jersey
    Will a 20x9 et 48 fit the 2012 q5 or should I run spacers to bump it out?
    Feb 15 2007
    I'm running 20x9 ET20 Ace Alloys on my Q5 3.0T:
    The good thing about aggressive offsets is that they can be ground down. So an ET20 can be ground down to ET30, etc I'm thinking of doing this on the fronts to ET25
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
    Junior Member Two Rings
    Aug 17 2017
    Two 99 A4 1.8t manual conversion in progress
    Dayton NV
    Quote Originally Posted by D_Frost View Post
    So Q5 wheel specs are the same as Mercedes center bore of 66? Typically I see Audi wheels with a 57 center bore. Or are these aftermarket wheel specs?
    Anyhow I scored a set of AT Italia 21" rims that were on an early Q5 and wondering what other model cars they will fit. I'll have to check what stamp is on them for ET they seem really wide at least 12"
