Results 1 to 20 of 20
    Senior Member Three Rings mageiger's Avatar
    Jul 05 2010
    PA
    Mid-Muffler Replacement
    So I found out today that I need a new mid muffler (I have a 3.2, btw). My local dealership quoted me ~$1,500 for the muffler replacement, so now I am debating on what to do. I am considering just eliminating the mid muffler entirely and just running two straight pipes to the rear mufflers/exhaust. The only thing that worries me is, being that the mid muffler is the most powerful, is that I will get too much drone while on the highway. I didn't know if anyone had done this before, or if anyone could chime in about the sound that will result if this is done. I have reviewed the muffler delete thread, but I am pretty sure that pertains to the rear mufflers, not the middle.
    Also, if replacing the muffler with straight pipes will be too loud, does anyone know if you are able to buy just an aftermarket muffler instead of the whole exhaust system (such as AWE or APR). That may save me from having to spend $1,500 for another stock muffler.
    Any help/suggestions is appreciated. Thanks in advance.
    Current: 2009 Ibis A4 3.2 Prestige
    Previous: 2006 A4 2.0T
    Established Member Two Rings TURBOB8's Avatar
    Apr 16 2012
    Redlands, CA
    Whatever you do, it's going to sound great. 3.2's rule
    Veteran Member Three Rings Limey's Avatar
    Nov 27 2010
    2004 srt4
    Edmonton,Alberta
    for $1500 you could almost buy and aftermarket exhaust, thats what i'd do or go to a muffler shop and swap out with aftermarket ones
    2009 A4/Brilliant Black/6MT//Usual Vag-Com mods//A5 5 spoke "y" rims with Michelin 255/35/19 super sports//bilstein pss10's//rs4 grill//rs4 grills//S-Line side blades//Ecode halogen to bi xenon conversion//LED bulb interior swap//AWE quad tip exhaust//Eurocode Short Throw Shifter/inlet pipe/sways/end links/alu kruz//S5 front brakes//APR carbonio intake//SPM Test & downpipe//APR stage 2 flash
    Jul 05 2010
    PA
    Quote Originally Posted by Limey View Post
    Ya, if the other options don't work I'll just be buying an AWE exhaust which would cost about the same as replacing the muffler. But I had a few other mods planned before I did the exhaust, so if I don't have to spend $1.5K now that would be ideal.
    Sep 28 2010
    NW NC / DE
    Pick up a 10"-12" magnaflow mid, run 2.5 SS to the tips. Delete the rears. ;)...
    Cost will be $100ish for the mid, $200 for the pipe, $120 for two 3.5" tips and $200 max for fab/install
    Nov 27 2010
    2004 srt4
    Edmonton,Alberta
    Damn that sounds sexy mops, nice looking car too
    Jul 05 2010
    PA
    Thanks for the info! Your setup sounds amazing.
    Veteran Member Four Rings jbradle7's Avatar
    Jan 09 2010
    GX460; MK7.5 GTI; WK2 Grand Cherokee; 73 Triumph TR5T
    St. Louis
    I knew the 3.2 with exhaust mods sounded nice but that is impressive. Love it!
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    just put a straight pipe there for $150, wont drone
    2010 A4 quattro, Tiptronic, Ibis White
    Jul 05 2010
    PA
    Quote Originally Posted by dracolnyte View Post
    There would be two separte straight pipes (I am assuming thats what you meant). Do you know if there would be any sound difference between an x-pipe and two straight pipes?
    The shop said it would be difficult and a little more costly to put an x-pipe in with the way the exhaust curves to the side after the mid muffler before connecting to the rear mufflers.
    Veteran Member Three Rings eyrah's Avatar
    Dec 17 2011
    Southern NJ
    Quote Originally Posted by mageiger View Post
    DEFINITELY get an x-pipe. those things make it mean, i dont think anyone has one on the 3.2 B8 as far as i know... be the first!
    - Pauly
    2009 Audi A4 Quattro BB/B
    AprTuned, Apr quad tip, CTS Testpipe, Eurocode HFIP, LED interior pkg, 15%/35% tint, Bi-xenon, VAG, AWE Custom valance, Customized Grill, RS6 Shift Knob, Aluminum Pedals, ST Coilovers, VMR 713
    Build Thread
    Veteran Member Four Rings OmaHahn's Avatar
    Apr 07 2011
    1st owner '64 1/2 Ford Mustang convertible D-Code (dads)
    Nebraska
    The complete Magnaflow exhaust system only costs $1,100! http://www.magnaflow.com/02product/s...ne=all&id=9884
    Hey Mops - thanks for your PM, but I can't recall if we discussed any drone noise inside the car. Your car sounds great and I'm very close to doing the same - but worried about how loud it really is for daily driving. Is it possible to add Magnaflow rears too and will that sound good? I know AWE offers with and without the rears.
    By-the-way, can someone clarify something... are there actually 3 mufflers on our cars? The mid and 2 rears? Looking at AWE's website it looks like they call the 2 rears "resonators," and not mufflers??? Thanks.
    2009 A4 3.2 V6 - sold
    2014 Ford SHO, 3.5 twin turbo with mods, 490WHP/545WTQ - sold
    2021 Dodge Durango SRT
    1964 1/2 Ford Mustang convertible, D-Code (original owner, Dad's ride I'm storing)
    Sep 14 2006
    http://www.jegs.com/i/JEGS-Performan...ductId=1130498
    Here's an x-pipe with aftermarket mufflers...I think magnaflow
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by OmaHahn View Post
    Hey Mops - thanks for your PM, but I can't recall if we discussed any drone nosie inside the car. Your car sounds great and I'm very close to doing the same - but worried about how loud it really is for daily driving. Is it possible to add Magnaflow rears too and will that sound good? I know AWE offers with and without the rears.
    The magnaflow systems drone pretty bad. They use very thin piping. With mine, drone is minimal, hardly worth mentioning. Its very quiet just cruising around but
    gets loud when you ask for it. I would start out running a mid, mid grade 2.5" SS and tips. If its too much then you can add some rear mufflers. I cannot stand drone nor loud/messy tones and I am 100% happy with my setup. Especially being its sounds better than the AWE imo and cost less than half.
    Jul 05 2010
    PA
    Ya I'm definitely trying to avoid any drone since I will be doing a decent amount of highway driving. Hopefully with either an x-pipe/straight pipes or an aftermarket mid muffler, the drone will be minimal due to the rear mufflers toning it down. I am going to try and get just the AWE muffler if I am able to purchase one separately. If I am unable to, my local shop recommended a brand called Xlerator for my mid muffler (which is supposedly made my Flowmaster, I think).
    Jul 12 2010
    Q5 3.0T
    oops sorry didnt read it was a 3.2, yeah X pipe is the way to go then
    Jul 05 2010
    PA
    Here are just a few pics for reference for anyone with a 3.2. I think I may be able to get my hands on a Magnaflow muffler (if I can't get an AWE one) so I would be replacing the mid muffler pictured below with the Maganflow or AWE and leave both of the rear mufflers/resonators.
    Veteran Member Four Rings JOS4AUDI's Avatar
    Jul 09 2008
    2008 RS4, 2012 S4, 2013 Allroad
    So Cal
    Ya mops car sounds amazing in person!! Mops has heard the exhaust on both my cars. The magnaflow sounds great on the Q its your best option i think for the money. Does AWE sell just mufflers?
    Current Audi's: 2008 RS4 Avus, 2012 S4, 2013 Allroad
    Past Audi's: 2013 A6, 2011 Q5 SLINE 3.2, 2006 S4 SPRINT BLUE, 2001 TT 225, 2006 B7 A4 SLINE, 2008 A4 CAB, 2011 A4 SPORT
    Sep 28 2010
    NW NC / DE
    Yes MF does make a nice clean sounding muffler. Not sure I would trust anything FM produces but I could be wrong. 3.2 Q sounds quite civil. Hell NO, AWE will not sell a muffler. Why would they. They charge $1500 ish for a full system. So for $1500 you get a mid, pipe and tips. The pipe runs them $150 tops, tips maybe $50. So the mid is worth $1300~. Custom
    Jul 09 2008
    So Cal
    That's what I thought thanks for clearing that up. I love custom only reason I bought exhaust for my S is I got a good deal in classifieds.
