Earlier today I had this error pop up in yellow. It stayed up there for the 10 minute drive then after turning the car off and restarting it, it has not returned. I did a search and only saw this happen to some early 2010 models which turned out to be software related. I've got 7800mi on my 2011. After plugging in the VAGCOM I recieved these fault codes for the ABS and AWD system. I'm not sure what the ABS code is saying other than an issue with the DTC memory. The AWD seems like it's pointing to bad sensors. I'm a fairly hard driver by nature but I haven't got too many miles on the car and its been sitting in the garage since Friday and the error popped up as soon as I pulled out. Anyone have any insight into this? I'll be calling the dealership in the am to see when they can get me in.
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Revision: -------- Serial number: --------------
Coding: 290D1A
Shop #: WSC 06324 000 00000
VCID: 820132611D662008B71
1 Fault Found:
01324 - Control Module for All Wheel Drive (J492)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 140
Mileage: 12578 km
Time Indication: 0
Date: 2012.09.09
Time: 18:19:13
Freeze Frame:
Hex Value: 0x2200
Hex Value: 0x4006
Hex Value: 0x1228
Hex Value: 0x50AE
Hex Value: 0x00FF
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 A HW: 8K0 907 163 A
Component: 4 Wheel Drive H10 0025
Serial number: 000404110001056
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 2E5936D1717EF468839
1 Fault Found:
0273 - Oil Pressure and Temperature Sensor
C1004 F0 [008] - Oil Pressure Implausible
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 139
Mileage: 12578 km
Date: 2012.09.09
Time: 18:19:13
