Results 1 to 8 of 8
    Veteran Member Three Rings B8Phil's Avatar
    Mar 13 2010
    Lorton, VA
    Eurocode High Flow Intercooler Pipe and Inlet Hose, my personal review...
    So most reviews I've seen of the Eurocode's HFIP and inlet hose are usually from members that have already installed other performance mods. Those reviews tend to speculate that there are "probably" some performance benefits due to reduced turbulence in the induction/cooling systems, but nobody has been willing to dyno a before and after... And for good reason, these mods don't substantially change the performance characteristics of the engine. That being said, I've slowly been acquiring bolt ons, and figured I'd throw in my two cents to give a different perspective on the two aforementioned parts, since they were the first ones to my door.
    Inlet Hose: First off, IF there was any sound increase, it was only minimal, and hardly noticeable. Anybody thinking about this mod simply for an enhanced/more aggressive turbo or air intake sound, don't even consider it... That being said, the hose itself is made well. Nothing dramatically outstanding, but it looks like it can do what it's meant to do. Honestly, looking at the OEM vs Eurocode's, I still think the OEM build quality is better. It actually made me second guess the purchase, but what the hell, it was on sale for $49, so in the name of "breathability", I figured there are no real drawbacks since the interior of the hose is smooth, where as there are 2 or 3 large ridges on the interior of the OEM hose. But this made me think about WHY Audi actually put them there in the first place. They could have simply used a one piece, smooth tube, but opted to install the one they did for a reason... From what I can see, there is a good deal of travel on the air intake box, and during normal operating temperatures and driving conditions, the ridges in the tube provide a bit of additional flexibility to make sure the inlet hose doesn't slip off if the intake box is jarred around. Keep in mind, this is only my assumption, so if anybody has any other ideas, please be my guest... But I digress, after a bit of wrangling with the stock hose, I pulled it out, installed the new one, clamped both ends and started the car. I felt nothing different on ignition. Let the car warm up and took it for a spin. Did I feel anything? MAYBE there was some additional smoothness when shifting between gears, but nothing at all dramatic. I would say overall, if I didn't know it was there, I wouldn't notice it AT ALL. So like others here have mentioned before, this would not be a candidate for a "first mod".
    HIgh Flow Intercooler Pipe: My initial thoughts on this piece after unboxing it, it's made well, and VERY light. Keep in mind that you won't be gaining any tremendous weight savings, but the pipe is light nonetheless. I found the Eurocode install sheet which was actually a write up by another audiziner, reviewed it and did a cursory review of all the spaces I would need to get into. After jacking up the car on the widow maker, I pulled the wheel off, un-torxed/unclipped the fender liner and rolled it back. I figured this would be a relatively quick and trouble free install, so I didn't bother getting out the jack stands (though I should've... Especially since I almost had my foot taken off when one of those bastards broke on me while I was working on the brakes on my Forester about a decade ago). At any rate, I took note of the angles for the three 10mm nuts/washers, and didn't have any way to get to that tricky lone nut closer to the front end. I did, however, notice that the sound box can simply be pushed out of the clips, toward the front of the car, and out of the way. This gave me enough clearance to loosen all the bolts and subsequently get the pipe out. Everything else on the install sheet is pretty much dead on, so I'll spare you the play by play... So after getting the pipe installed, and everything back together, I started the car and let it warm up. After getting up to temp, I hit the throttle to listen for the whoosh... It was a BIT more noticeable, but nothing dramatic. So I took her for a drive to see if there was any noticeable performance benefit. At the time, it was rush hour in the city, so it was perfect driving conditions to find out if the car was spooling quicker and getting up to speed in each gear. I paid close attention to my typical shift points as this mod wasn't necessarily meant to improve my WOT runs... Long story short, yes, it certainly improves turbo spooling due to 1) elimination of sound box (which was smaller than I thought it'd be) and, 2) elimination of hoses leading to sound box. Was this dramatic enough to warrant the cost, even for $100??? Debatable... I'll need more miles on it before I can say one way or the other, but I'm not unhappy with it. In fact, in comparison, it's surprising that Audi would have even considered the addition of the sound box in lieu of a straight through pipe for the minor trade off. The additional hoses, clamps, sound box only increases production cost and decrease turbo response... If anyone can think of a benefit of delaying the spool time, I'd like to hear it. Overall, with this mod, I was pleased, and would say that this could be added at anytime to address the slower turbo spool.
    APR Stage II SPM street downpipe Remus dual exhaust S4 shocks & rear sway Eibach Pro-Kit 19x9 OEM S5 Peelers 245/35R19 Nexen N7000 Eurocode HFIP Eurocode inlet hose aFe Pro Dry S
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    thanks for the review. it's not a 'sound' box so much as an expansion chamber.
    http://www.ehow.com/info_12156112_ai...onator-do.html
    Sep 30 2009
    b
    I agree with you on the inlet hose, did little to nothing, maybe made 3rd gear feel a little more solid?
    But the HFIP changed second gear for me entirely, in my 6mt I would shift to second, and it would be super clunking in low rpm's and felt sluggish. After the fact, it spooled considerably faster and the transition from first to second was completely different. A small change that did a lot for me IMO. It definitely put a smile on my face, while the other bolt-ons I've done have left me wondering why I bothered to spend the money.
    I would also allow time for your ecu to adjust. Initially thoughts on the aFe were equivalent to the lack luster experience on the first day, but a little while after actually being able to drive it, the throttle response is definitely throatier.
    Mar 13 2010
    Lorton, VA
    Thank for the info! Interesting read, but it claims that it makes the engine more "powerful"?.. That seems contrary to what is felt in the car, but looking at the resonator's position along the OEM IC pipe, I can see that the statement might be true if it is placed closer to the cylinder head. I guess the question is, will this pipe make the B8 engine less efficient, or wear prematurely as compared to the OEM pipe. Is there a material trade off here, or is the concept not fully applicable to our engine?
    Sep 30 2009
    b
    Quote Originally Posted by B8Phil View Post
    The way it makes sense to me, I could be totally wrong, the stored air in the chamber - could and possibly makes the car reach higher hp at peak, deleting it, makes power more consistent and evenly distributed along the rpm's.
    Mar 13 2010
    Lorton, VA
    Good thing to remember... Ill definitely post a follow up after a couple of weeks and a throttle body reset. I should have the aFe waiting at my door Wednesday. Not exactly sold on the high flow vs OEM paper. Didn't want a oiled filter, but also don't want engine components running harder just to suck in LESS air... Airflow and filtration is always going to be a trade off, but my rationalization is that the Pro Dry S will offer a good balance.
    Veteran Member Three Rings sickspeed's Avatar
    Sep 12 2005
    2001 S8 and 2011 Q7 TDI and 2010 Toyota Land Cruiser
    MD
    keep us posted. i have these same parts going on on monday.
    2001 S8 or 2011 Q7 TDI Modded.
    Previous Audis: Red 1987 4000 CS, Dolphin 2002 A4 3.0 6MT Sedan, Atlas 2003 A4 3.0 6MT Wagon, Dolphin 2006 A4 2.0T 6MT Wagon, Meteor 2009 A4 2.0T Wagon S-Line .[/I]
    In, Out and Around...
    the trufit hose is more of a final stage addition than a first mod... adding it to a car that is stageII+ will get a bit more out of the hose than a stock car however on both cars it is a marginal difference. it's just the final piece in the puzzle for stageII+. unfortunately there arent any worthwhile stageIII options so until then these minor adjustments and incremental gains are the only way to go for me.
