Results 1 to 40 of 43
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    Where the hell is switched 12v ??? Help pls !
    So I have been spending the last couple hours installing my Lidatek LE30 laser diffuser and other than the damned cars fancy electrical system all was going just fine. I have tapped into fuse #12 in the brown harness which is the wiper and light sensor but the damned thing doesnt turn off. A a matter of fact the entire fuse panel seems live all the time ??? I have closed everything, locked the car and walked 40 or so feet away and the thing stays live all the time
    Someone please save my from insanity and tell me where to grab 12v switched power off the fuse panel or let me in on the secret why the entire fuse block seems live all the time
    Thanks
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    Senior Member Three Rings ob_1jr's Avatar
    May 05 2012
    Clinton, UT
    the 2013 doesnt have a cigarette lighter does it?
    2017 SQ5 Premium + | weathertech floor mats | 20% tint
    Sold:2012 S4 Premium + | 6MT | comfort key | supercharged badges | weathertech floor mats | 15% tint | Gunmetal VMR 710 18x9.5 w/ bridgestone potenza RE970AS from PYSpeed| Roc-Euro intake | Alu Kreuz | Eurocode Meisterwerk ASTS | 034Motorsport Transmission Mount Insert | Spulen Rear Differential Mount | ECS GEOMET Slotted and Drilled rotors | Hawk Ceramic pads
    Veteran Member Four Rings phillips2024's Avatar
    Mar 03 2011
    Southern NH
    get a Mini Add-A-Line and tap into empty fuse position #2.
    2017 Audi S8+ | 2021 Audi RSQ8 | 2021 Cadillac Escalade Sport Platinum | 2007 Porsche Turbo
    2021 Sea Ray 350 SLX | 2020 Polaris Ranger Crew XP1000 | 2022 Polaris Indy VR1 850/650
    Established Member Two Rings Maltitol's Avatar
    Jun 27 2012
    Rockville, MD
    Quote Originally Posted by ob_1jr View Post
    Yes, it does. Its above just above the shifter.
    Sep 01 2004
    Vancouver Canada
    Well I am calling it a day until I figure out what's going on here. I don't have a mini add a line so tapping another source is the only choice and it should work fine, for some reason the power stays live 15-20 minutes after the car is closed and armed ?
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    The only fuses i know that are all switched 12v are the entire "red" row in the trunk fuse box on the right of the trunk. That's what I used for remote turn on for my amp...probably not the best run in your situation but would work.
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Sep 01 2004
    Vancouver Canada
    Well at least I now have confirmation that the car does indeed have switched 12v ! I had wondered if it was running on a switch to ground setup or something. I must be missing something ???
    Nov 19 2011
    Rhode Island
    Quote Originally Posted by QuattroRocket View Post
    I just read your signature and you have a 2013...the red row in the trunk fuse panel i know is 12v switched for the B8 not 100% for the B8.5. You can go to your local auto store or even walmart and by a tap-a-fuse which will plug in with a wire lead, or splice one of the wires coming off.
    Sep 01 2004
    Vancouver Canada
    I was trying to tap into the back of the panel but you are right a tap a fuse would be easier although it would accomplish the same thing. The real problem is most of the 3 fuse panels remain live, seemingly all the time ! I cant find anything that turns off when the car turns off (good old fashioned 12v test light hit live 12v on every block) ??? Car on, off, closed, locked. hood open, closed ... nothing seems to have it turn off ???
    Aug 27 2008
    Houston Area
    Wouldn't think the S5 is that much different. I taped my dashcam into the top "vertical" fuse on the front block on the drivers side. It is switched with the ignition.
    Didn't look for others - this one worked. Of course this only has the hot wire installed - put the ground on the dash mounting bolt above (in the pic) with an extra nut.
    2013 6MT S5 - Monsoon/Black
    Prem+ | Sport diff | Adaptive dampers | Nav | B&O
    Res AWE exhaust | USP intake | USS Sways | OEM 19" speedline | AluKreuz | 034 Trans mount | Interior LED | VCDS tweaks | F1 tint | Xpel PPF
    Previous : 2009 6MT A4 | Quartz/Black | Prem+ 2001 5MT A4 | Silver/Black | Premium pkg
    Sep 01 2004
    Vancouver Canada
    Quote Originally Posted by B8_Jim View Post
    Ok thanks, auto parts store is closed and I am hitting the road tomorrow am so I guess the laser diffuser will have to wait until my return, probably safer that way anyways !
    Thanks for the pic, helped a bunch to see what you were meaning, tapping the wire off the back of the panel is a PITA.
    Nov 19 2011
    Rhode Island
    the pic above is different from where i was referring to. I also couldn't find a switched 12v in that fuse panel. Here are a few shots of the trunk fuse box and red row of fuses i'm talking about.
    Established Member Two Rings Green Neenja's Avatar
    Jul 10 2012
    Texas
    For future reference and in case someone else is looking for a switched 12v source, I tapped in to fuse #3 located in the panel on the left side of the dash today on a 2013 S4.
    2013 Audi S4 | Prestige | Misano Red Pearl | Magma Nappa Leather | Stainless Steel Inlays | S-Tronic | Sports Differential | MMI Navigation Plus | Bang & Olufsen | Adaptive Suspension | Adaptive Head Lights | Adaptive Cruise | Driver Assist | Parking Assist | AWE Supercharger Pulley | GIAC Stage 2 Tune, DSG Flash | Eurocode Alu Kreuz, ÜSS Stabilizer Bars, End Links | VMR V710's | Opti-Coat | Xpel Ultimate | Hüper Optik | P3Cars Vent Gauge | Hoen Xenonmatch | Valentine 1 | -
    Jun 26 2013
    Calgary, Alberta
    *** Bump ***
    QuattroRocket - You didn't post a resolution? Did you ever figure this out?
    As per the OPs first post, I am going crazy trying to figure this out.
    The switched "Red Row" that dizzlesizzle is referring to in the A4/S4 b8 is MIA in the b8.5s. There is no red row of fuses. I've tested every fuse in the trunk fuse panels (that I am comfortable removing) and all of them stay on after turning off the car.
    For my purpose, I am looking for a 12V switched line for a Remote Turn On lead for an aftermarket amplifier. The amplifier is in the trunk along with the speakers, so I would really like to avoid bringing any lines back from the front of the car. I am using (or at least hoping that I can) a TAPA fuse.
    Thanks in advance!
    Veteran Member Four Rings achilleas101's Avatar
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    do you have a multimeter? if not, i highly recommend getting one, doesn't need to be anything fancy, although i prefer digital. I got a $20 one from Advance Auto parts, and it's been immensely helpful. you can test out each fuse while it's on there without driving yourself crazy. Especially if you're doing electrical work, that's a must have tool.
    if you were talking front of the car fuse panel on the driver's side, i could more directly answer your question (the entire left bank is switched), but i haven't touched the rear panel so i can't.
    Gone but not forgotten:
    2013 S4 Imola Yellow | Black leather/Silver Alcantara | 6MT | B&O | Sport Diff | Silver 19x8.5 Avant Garde m550 | XPel Ultimate full hood/fenders | Eurocode SS
    2003 A4 3.0 6MT;
    1998 Acura Integra GSR 5spd
    Gone and most likely in a junk yard somewhere: 1990 Toyota Tercel
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by abcha0s View Post
    *** Bump ***
    Thanks in advance!
    I had to use the location in the front fuse panel and run it back to the amp.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Jun 26 2013
    Calgary, Alberta
    *** Bump ***
    Thanks in advance!
    To help future A4 b8.5 owners.
    1. There does not appear to be any switched 12V fuses in the passenger side trunk.
    2. I found an empty switched 12V in the driver side front - slot 13 in the first bank labeled Air Bag.
    3. I had avoided the front fuse panel because I did not know how to run the wire to the trunk without removing the trim. It actually turned out to be much easier than I had anticipated. I was able to run the wire along the top of the car and out through the trim in the trunk without having to remove anything. I simply pulled back the rubber and gently fitted the wire behind the trim. No problem and the path took me all the way from inside the fuse panel and into the trunk.
    Edit: I see that I actually used the same fuse as B8_Jim (Above). B8_Jim was nice enough to post a picture.
    Aug 15 2014
    Does anyone know of a good switched power source from the passenger side fuse panel?
    For Sale: Mini Part Out
    Nov 19 2011
    Rhode Island
    Quote Originally Posted by Shimmy View Post
    What are u trying to get power for? i am not sure of the 12v switched power in passenger fuse panel, but I tapped into the homelink system for my radar detector which is 12v switched power.
    Aug 15 2014
    Quote Originally Posted by dizzlesizzle View Post
    Installing a BU camera and the "brain" for it requires 12v
    Apr 16 2010
    BC
    Where is the right luggage compartment fuse box? I can't find it in the trunk.
    Veteran Member Three Rings Wagoon's Avatar
    Jan 31 2010
    Stock parts
    Orlando
    Anyone found one in the trunk yet, I spent a few hours yesterday searching for one in my 2013 and the best I found was Switched 6v going to the Factory B&O amp.
    I wish this could've been as easy as my 2010 which had a whole bank.
    wagoons || corey
    thewagoons.com
    2016 allroad quattro // rsfauxroad // 3p // stg2 e85
    airlift.akebono.apr.bbs.cr..ecs.eurocode.forge.inn o.st
    the wagoons - build thread - instagram
    Jan 28 2013
    Quote Originally Posted by Layd Dly View Post
    As far as I know there isn't one on the 2013's. At least I've read that isn't. Additionally, I couldn't find one on my 2013. I had to go to the front.
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    Be careful if you add a fuse or tap into any wires and warranty claim denials. I had added a fuse on my 11 S4 and when they were having problems connecting to my car to reset the service reminder they tried to blame it on my tapping into the rear view mirror fuse.
    Some of these SA's feel that only they can touch a car otherwise if anything goes wrong it is your fault. As a result I deal with another SA who is a little more relaxed and doesn't have a rod up his butt to measure the amount of grease in his hair.
    Aug 16 2014
    Denver
    Quote Originally Posted by Lamprey View Post
    I'm here to confirm there is not one in the rear passenger side fuse banks for the 2014's either. Just in case anyone else is stubborn like I am and feels compelled to test every fuse, hopefully this saves you the time. @abcha0s, thanks for the tip on how to guide the wire from the front. I did so as well and it was quite easy as you explained.
    Mar 28 2009
    Minneapolis, MN
    I wasted a couple hours last night on this same endeavor ... until I searched google and found this thread. I was trying to wire a rear dashcam to a switched fuse, but of course, couldn't find one in the rear fuse block. I ended up tapping into the wiring for the rear cig lighter/accessory plug and grounding on the chassis. Works like a charm. The camera now powers up with the car and turns off about a minute after the ignition is shut off.
    Jan 31 2010
    Stock parts
    Orlando
    I did actually find one eventually but never followed up here after the fact. There is a switched 12v in the rear passenger side, under one of the relays. Not sure i took pictures, but would not be hard to get one if anyone needs it still.
    wagoons || corey
    thewagoons.com
    Oct 14 2012
    Empty...for now...
    SE PA
    Yes, please do. I currently have my aftermarket subwoofer amp and line-out converter connected to the switched +12v in the front driver side fuse panel in the cabin, but I would have preferred to connect it locally in the trunk.
    @dropshadow: That's interesting that the power remains on for a bit after the ignition is switched off. That's exactly how I want my subwoofer amp to behave (so that the full sound continues to play after I turn the car off), but as it is currently the amp shuts off immediately with the ignition using the switched +12V from the front driver side fuse panel. I suppose they wired the cig lighter circuit this way as a 'convenience' feature for anyone who needs to light a cigarette within a minute of shutting off the car...?
    EDIT: How/where did you route your wiring from the rear cigarette lighter into the trunk?
    SOLD 2015 Daytona Gray S4
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by SteveYem View Post
    Sent from my iPhone8s using Tapatalk
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Veteran Member Three Rings eightamrock's Avatar
    Jan 21 2016
    I did the same thing this weekend.
    One question, does anyone know what this relay is connected to? Im worried about taking it in for service at the dealership and them voiding warranty on something crazy because I tapped the 12v remote here.
    Also, does anyone ever fuse their remote wire? I was thinking about putting a 1 amp fuse on this, more so because its on a relay and not a fuse.... thoughts?
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by eightamrock View Post
    i've been running this setup since September .. the car has been in for service once.. no one said anything.. and its easy enough you can remove it if you want.. never had a problem none fuse either
    Present:
    Jan 21 2016
    Quote Originally Posted by doug97gxe View Post
    Thanks for the note. Ill just pop it out if I get paranoid about it. Still curious what this relay does though... can't seem to find it anywhere online. Admittedly, I have not checked the manual yet.
    May 11 2021
    Missouri
    I have a 2009 Audi S5, been having this same issue, can't find a switched for the turn on lead. The only one I have found is ONLY switched when the car is running, which is the red fuse block in the passenger side of the trunk, it will not provide 12v power when the key is in the ignition. Can you explain in more detail how you tapped into this relay? Did you just bend a wire around one of the pins and put the relay back in? Which pin is the one to use? Do you think it would work the same on my 09 S5? Did you have to take the negative lead off of the batter or can you just pop the relay out and pop it back in?
    Jul 16 2018
    Atlanta
    There's plenty of term 15 access (well, unless it's a B8.5 it seems). The black fuse carrier on both ends of the dash are term 15. As for the red fuse carrier in the right rear, it'll vary.
    Through MY09, slots 1-4 are term 87 (engine on) for the 12v sockets, slots 5-12 are term 15.
    For MY10-MY12, slots 1-6 are term 87 and 7-12 are term 15.
    For MY13+ (B8.5), it appears red is not even used, and all of fuse panel F is term 30. Term 15 devices, like the lane change assist radars, are powered from the dash fuse panels. Seems like a lot of extra wiring so to not have to populate panel F red.
    While these are for the 8K (A4); I don't see why the 8T (A5) would be significantly different.
    May 11 2021
    Missouri
    Quote Originally Posted by Smac770 View Post
    I'm not sure what you mean by "Term 15"? In my 09 S5 using a multi-meter, I cannot find any 12v switched power either in the front boxes or in the rear boxes that are on when the key is in the ignition. The only ones that provide switched power are the slots in the red fuse box in the back right but the engine has to be running. It is so frustrating.
    Jul 16 2018
    Atlanta
    term 30 = always on 12v
    term 31 = ground
    term 87 = relay switched 12v, engine on (87 is just the output pin on a Bosch relay, but in this context, it generally means engine on output)
    term 15 = relay switched 12v, ignition on
    Go to the fuse panel C (left end of dash). With the key off / engine off, measure the voltage across the test pads of one of the fuses in the black column 1 and the brown column 2. You should measure 0V on the black column fuse and 12V on the brown column fuse. Then turn on ignition, lights on the dash should come on, radio should come on. Now you should measure 12V on the black column fuse. If you don't, turn the engine on. Does now the black column fuse show 12V? If that's the case, maybe you have an issue with the term 15 relay.
    You're saying you observe the same switching behavior for the the fuse 1 in the fuse panel F (back right) red fuse 1 as for red fuse 12? It would be best if any actual 8T owner ever bothered to get the workshop manuals and wiring diagram documents for an 8T from erwin.audiusa.com. But I still find it highly unlikely the 8T is wired that different from an 8K.
    May 11 2021
    Missouri
    term 31 = ground
    I'll test again tonight after work but I have tested all of the fuse boxes out with a multimeter and can find NONE that are not constant 12V except the red fuse box passenger side trunk. That one only has 12V when engine is running. I'll check again with key out, key in, etc., tonight. Thanks.
    May 11 2021
    Missouri
    term 31 = ground
    I have 3 fuse strips front drivers side, a black, brown and red. Red is all constant 12v, both black and brown ONLY have power when car is on, no power when car is off or when key is in the ignition.
    Jul 16 2018
    Atlanta
    What do you mean "car on", you mean engine running?
    Ignition on, term 15, means the DRL and radio and climate system and such are on (or can be turned on/off), engine can be running or not.
    You have to press the key, foot not on brake, to turn on ignition, term 15, without also starting the engine. In case we're missing each other in semantics.
    Take the HomeLink buttons, they are on fuse 3 in the black column on the driver's end of the dash, on term 15. So they stop working after you turn the engine off. If you get in the car, they will not work. If you then turn on ignition (but not the engine), they will now work.
    Also, the brown actually has a mix of terms present. 1-3 are term 87, engine on. 4 is term 15, ignition on, 5-12 are term 30, always on. But that's on my 8K. Using the red rather than brown as a term 30 counter example to the term 15 black is better.
    Feb 16 2019
    miami, fl
    there is another situation of ignition off but (bleedover?) power on, when you turn the car off but don't open the door. the ecu is not on(can't pull codes) so ignition is off but radio and some things are still on, but the relay people grab off of in the trunk does shut off in that case but op might want power that continues to be on in that circumstance. i THINK the cig lighter is still on then as well so that could be a solution for a remote source.
