Results 1 to 28 of 28
    Veteran Member Three Rings slowrideBC's Avatar
    Jun 10 2012
    2000 s4
    EPC light means new throttle body?
    I have a 2000 s4, twice while driving my car looses all power and the EPC light comes on in the tach. A quick pull over and restart seems to get me going again.
    I also am getting this code when the error happens:
    17743 - Engine Torque Monitor 2: Control Limit Exceeded
    P1335 - 35-10 - - - Intermittent
    After some googling it seems that the throttle body is shot? Anyone have this happen? Anyone have one for sale?
    Thanks
    ps. tial 605s rock!
    2000 S4 - silver- RS4 OEM widebody racecar
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    everytime my EPC light has come on and the car hiccups, its been a throttle body. remove the tb and then move the blade open and shut; all of mine hung up so raatarrdedly tight i dont even know how the car ran.. lol.. improper torque with the APR bipipe was the only thing that i would say contributed to this failure, with my ARD pipes and a samco ive yet to have an issue..
    if you dont have an APR bipipe then i suggest cleaning the throttle body, if it moves freely with no hangups that may be the only issue..
    RS6 hybrids and corn
    Jun 10 2012
    2000 s4
    thanks for the quick response. I believe I have the stock bipipes. Ill check the throttle body...
    Can I use brake clean to ungunk the throttle body or do I have to use a gentle cleaner like a MAF/electronics cleaner.
    Sep 28 2009
    ky
    no, its completely mechanical-- even where the plug in is, its extremely rudimentary for what you would think of an electronic throttle body would/should look like internally. i wouldnt saturate it, of course, but just getting it good enough to where you can use an old toothbrush or a towelette should be fine..
    Jun 10 2012
    2000 s4
    awesome...gonna take a look in a bit thanks for the help
    Senior Member Three Rings Dayne's Avatar
    Aug 13 2012
    Bunch of crap
    Colorado
    I have a 00' s4 and my EPC light comes on at start up but goes away a second later and I never see it again.
    The Red Laser!
    Veteran Member Four Rings morris400's Avatar
    Dec 18 2008
    2016 VW GTI, 1994 Audi S4
    Alberta, Canada
    i had a epc light come on for almost 6 months, when i switched to a new ecu it went away.
    IF YOU WONT STAND BEHIND OUR TROOPS....TRY STANDING IN FRONT OF THEM!
    2016 VW Jetta 1.4T Daily Driver
    1994 Audi S4 20V Turbo, K24 7400 EFI EXPRESS
    2001 Audi S4 - Gone! Dropped valve cyl 4
    Jun 10 2012
    2000 s4
    i have two ecus, it does it on both...I am also getting a misfire. I have been told its possibly my coilpack causing the EPC light. EPC only comes on when Im on it at high RPM. My throttle body looks good. I am getting a used one for $50 from a local member...I think it may be time for 2.0 FSI coil upgrade?
    Aug 30 2007
    nyc
    It could be one of three things......
    1)tb
    2) ecu
    3) wiring between ecu and tb
    4) tb harness plug
    c5 A6 tip
    this n that
    Registered User Three Rings GWerks's Avatar
    Sep 11 2010
    Grand Rapids, MI
    Calibrate it
    Established Member Two Rings estoniancartel's Avatar
    Aug 10 2009
    2001 S4 Avant 6 MT
    Boulder, CO
    Quote Originally Posted by GWerks View Post
    Calibrate it
    X2. Mine was dying and failed the calibration, although I also had throttle valve controller malfunction and throttle body fault in basic settings dtcs, which you don't.
    2001 S4 Avant 6MT OEM RS6 on E85
    2008 A4 Titanium Avant 6MT
    2015 Allroad APR Stage 1
    2024 RS3
    Jun 10 2012
    2000 s4
    hmmm are you guys saying I can try to calibrate my throttle body in vag com? and if it fails calibration its obviously dead,,,
    Veteran Member Four Rings Smitty2A4's Avatar
    May 30 2007
    Stage 3 B5 S4 6 Speed l B6 A4 3.0 6 Speed (RIP)
    Boston, MA
    Quote Originally Posted by slowrideBC View Post
    Yes you should be able to calibrate it via VAG-COM and just to add I have had issues with the EPC light coming on and the car loosing all power a few times. One time it was due to a boost leak with my drivers side lower intercooler hose, it eventually popped off completely and the car cut out, I replaced my silicone hose with a longer one and it has been fine since. The second time it happened was somewhat recently and it was after getting the car re-tuned. This time it turned out to be my MAF, basically my MAF isn't 79mm straight through it is slightly smaller then opens up to 79mm, so once he adjusted the tune to my MAF I have not had an issue.
    Looking for a good shop north of Boston, call Eurosport Performance
    Oct 13 2010
    colorado
    Not sure what to look at my EPC light is currently on but some times it goes out for a couple days then comes back.
    Symptoms- car runs fine taking it easy and just normal driving.
    IF you try to accelerate hard rpm spikes but not change in acceleration then itll drop pick up speed, rpm spike (increase in Rpm no motion) drop down and pick up where it left off.
    17 Audi RS3(catalunya red): midpipes, hr lowering springs, 18x9.5 te37s, 034 front rotors
    01.5 Audi S4 2.7tt 6-Sp (Imola Yellow): Bagged, ko4s, recaro spg, AP rollbar, other bits
    Instagram: nerdiest_
    <<Flickr>>
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    You did your mods in the wrong order. VCDS cable comes before all the stuff in your sig, maybe even the car
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Oct 13 2010
    colorado
    Well i have access to a cable so i was thinking of trying a throttle Body alignment.
    <<Flickr>>
    Nov 16 2010
    WetSide, WA
    I think it pretty much does that every time you turn the key on.
    The codes are what you are going to want to look for.
    Oct 13 2010
    colorado
    Quote Originally Posted by zillarob View Post
    i was reading else where that it doesnt actually align its self when the key is in the on position....
    <<Flickr>>
    Jun 10 2012
    2000 s4
    i had a tune from some on nefmoto and it was the cause of my EPC light...
    got a eurodyne and never had the problem again...it was never my throttle body
    Oct 13 2010
    colorado
    My EPC light is temperamental, comes and goes as it pleases but the throttle response/clutch/rpm spike issue persists.^^^
    first time i ran codes, cleared them.
    15 Faults Found:
    18057 - Powertrain Data Bus
    P1649 - 35-00 - Missing Message from ABS Controller
    17530 - Oxygen (Lambda) Sensor Heating; B2 S2
    P1122 - 35-10 - Open Circuit - Intermittent
    18084 - EPC Warning Lamp (K132) Circuit
    P1676 - 35-00 - Electrical Malfunction
    17526 - Oxygen (Lambda) Sensor Heating; B1 S2
    P1118 - 35-10 - Open Circuit - Intermittent
    18098 - Malfunction Indication Light (K83)
    P1690 - 35-10 - Electrical Malfunction - Intermittent
    17861 - Exhaust Gas Temp Sensor 1 (G235)
    P1453 - 35-10 - Open or Short to Plus - Intermittent
    17865 - Exhaust Gas Temp Sensor 2 (G236)
    P1457 - 35-00 - Open or Short to Plus
    17521 - Oxygen (Lambda) Sensor; B1 S1
    P1113 - 35-10 - Internal Resistance too High - Intermittent
    16955 - Brake Switch (F)
    P0571 - 35-00 - Implausible Signal
    17870 - Exhaust Gas Temp Regulation for Bank 2
    P1462 - 35-10 - Implausible Signal - Intermittent
    17952 - Angle Sensor 1 for Throttle Actuator (G187)
    P1544 - 35-10 - Signal too Large - Intermittent
    16622 - Manifold Pressure / Boost Sensor (G31)
    P0238 - 35-10 - Signal too High - Intermittent
    17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
    P1172 - 35-10 - - Intermittent
    16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
    P0106 - 35-10 - Implausible Signal - Intermittent
    16500 - Engine Coolant Temp. Sensor (G62)
    P0116 - 35-10 - Implausible Signal - Intermittent
    Readiness: 0010 0000
    Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
    Part No: 8D0 820 043 Q
    Component: A4 KLIMAAUTOMAT D58
    Coding: 00160
    Shop #: WSC 63351
    VCID: 2E592BCDEA6C336E36F-258E
    2 Faults Found:
    00779 - Outside Air Temp Sensor (G17)
    30-10 - Open or Short to Plus - Intermittent
    00792 - A/C Pressure Switch (F129)
    31-00 - Open or Short to Ground
    Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
    Part No: 8D0 959 655 G
    Component: Airbag Front+Kopf 2002
    Coding: 00304
    Shop #: WSC 20211
    VCID: 3A71179D2624EFCE9A7-517A
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8L0 862 257 N
    Component: CV-Pump, Alarm, RC D16
    Coding: 16232
    Shop #: WSC 63351
    VCID: 4085657540F8B51ED43-4ECE
    2 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00101
    Shop #: WSC 63351
    VCID: E0C505F56038551E743-4B36
    1 Fault Found:
    01383 - Alarm triggered by Anti-Theft Sensor; Front Right
    35-00 - -
    these came back after 2miles
    Car has no rear 02s, no cats, i know epc and abs are on i have those disconnected will i get a new abs module.
    Address 01: Engine Labels: 078-907-551-AZA.lbl
    Part No: 8D0 907 551 H
    Component: 2.7l V6/5VT G 0003
    Coding: 06711
    Shop #: WSC 02629
    VCID: 2F6736C9ED663A663D9-5140
    7 Faults Found:
    P1453 - 35-00 - Open or Short to Plus
    Readiness: 0010 0100
    Coding: 00160
    Shop #: WSC 63351
    1 Fault Found:
    Coding: 00304
    Shop #: WSC 20211
    No fault code found.
    Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
    Part No: 8D0 920 981 BX
    Component: B5-KOMBIINSTR. VDO D17
    Coding: 02262
    Shop #: WSC 05140
    VCID: 830F2A79916EEE06091-5122
    Coding: 16232
    Shop #: WSC 63351
    VCID: 4085657540F8B51ED43-4EEA
    Coding: 00101
    Shop #: WSC 63351
    VCID: E0C505F56038551E743-4B4E
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00012
    Shop #: WSC 63351
    VCID: E5CB14E17F1A3036875-51B6
    Address 56: Radio Labels: 8D0-035-1xx-56.lbl
    Part No: 8D0 035 195 A
    Component: Radio D00
    Coding: 00201
    Shop #: WSC 00003
    VCID: 244DC9E5B4A0893ED0B-4B1C
    End ---------------------------------------------------------------------
    <<Flickr>>
    Nov 16 2010
    WetSide, WA
    Holy moley! You have a soldered chip ecu?
    Oct 13 2010
    colorado
    I believe its a flash? but i bought the revo tune second hand so may not even be a revo. (has a revo st2 written on it and a sticker)
    <<Flickr>>
    Nov 16 2010
    WetSide, WA
    I think revo is a flash so should be good there.
    Id say fix the obvious stuff (or a new flash with code outs) and work your way up.
    Oct 13 2010
    colorado
    I figure its either clutch slipping Or something throttle or tune related.
    <<Flickr>>
    Nov 16 2010
    WetSide, WA
    Whatever it is you got some work to do.
    That thing cant be running very well, some of those codes are ones the ecu dont like.
    Oct 13 2010
    colorado
    Car idles great runs great when not WOT.
    Ran terrible for a day when the icm died besides that it's been just fine
    <<Flickr>>
    Nov 16 2010
    WetSide, WA
    Not sure if revo has changed things, but the egts will put you in limp and maybe dump fuel.
    The same for the B1 S1 o2, but that is at least intermittent.
    The brake switch can do funny stuff, like cut out the throttle.
    Oct 13 2010
    colorado
    hmm. Thanks for all the info, My spring break starts on friday so ill have all week to mess around with the car and try and fix some of those codes.
    <<Flickr>>
