Results 1 to 40 of 58
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    IE vs Pauter rods
    Seems as if the integrated engineering rods have been the most recent choice lately from what I can see.
    With a bit of research, i have found that the Pauter rods are a bit more "quality".
    $900 IE's: http://www.intengineering.com/integr...r-12v-30v.html
    $1300 Pauter: http://www.034motorsport.com/engine-...6-p-18630.html
    What justifies the extra $400 for the pauter?
    Oct 05 2005
    richmond va
    Made in usa !!!
    01.5 s4 built bottom with pauter rods , BW rs6 turbos , MTM manifolds , ER intercoolers , 044 fuel pump, EV14 injectors , 90mm maf , vast tune for now ,
    X1 intake , ported intake manifold , ASP 3inch down pipes and true duel cat back .
    Established Member Two Rings sean01S4's Avatar
    Oct 27 2008
    2001 audi s4
    | EPL | 034 | Precision | Aquamist | H & R | Bilstien | Awe | Jhm | Apikol | Bosch |
    Tell me why your mad........
    Established Member Two Rings RudeJude518's Avatar
    Oct 10 2010
    Albany, NY
    IE vs Pauter rods
    I'm interested in hearing the differences and which rods people think are better.
    Xbox Gamertag: Ya uraHERB soi
    Call of Duty when I can find time between work and taking care of the new baby.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    wow IE is charging $900 now for China rods!!
    Jul 18 2009
    D2 S8, E61 535xi, B5 S4
    Subdivisions, NW burbs
    Re: IE vs Pauter rods
    Rosten, rpm are a couple other choices to research.
    I'll take Pauter for $400 more please
    Feb 06 2012
    Lake Lanier, GA
    Quote Originally Posted by NOTORIOUS VR View Post
    Wait, what? Rebranded Chinese rods? Sounds like you have a source for cheaper.
    Jul 18 2009
    Quote Originally Posted by aysix View Post
    Or just pointing out they are Chinese? Or was that common knowledge? Not bashing, just curious. I mean is there a reported high failure rate with ie rods? If not then why not save the $400? I am interested too as this may be in my future as well. But if there is a clear better proven track record for other maybe more expensive options then I will spend the few hundred more.
    Apr 18 2007
    ny
    IE rods are made in china?
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    May 16 2008
    South Texas
    Quote Originally Posted by A62TURBO View Post
    From what I understand IE rod blanks are sourced from China and finished in the USA.
    May 13 2011
    2015 BMW F30
    IE rods can do the job just fine. Save the extra cash for something else.
    | Autospeed | JHM | Pure MS
    Nov 10 2011
    Ontario
    If you are going to take the time to put rods in why not put the best you can get :s.
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    well doesnt pauter help with less weight on the rotating assembly? im not sure.. that may be something to think about as well, especially if going lightweight pistons and what not..
    every little bit helps..
    RS6 hybrids and corn
    Feb 06 2012
    Lake Lanier, GA
    Quote Originally Posted by ravensB5S4 View Post
    Orly? Hm, wonder why I made this thread
    whats the best I can get?
    Senior Member Three Rings haggard69er's Avatar
    May 20 2007
    Alligators
    pittsburgh
    Pauter rods: lighter, Ibeam, can support 1000hp
    IE rods: heavier than pauter and stock rods, h-beam, can support around 700-800hp
    Veteran Member Four Rings rockcandy's Avatar
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    Quote Originally Posted by haggard69er View Post
    Data to support this?
    Veteran Member Three Rings arotished's Avatar
    Jul 04 2010
    Norway
    For me the choice were simple, pauter all the way!
    Or if you have deep pocket and feel alittle dirty, carrillo rods :)
    Veteran Member Four Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    My buddie just measured his and his IE's are lighter then stock
    A3 8P DSG 3.2 S-Line : Billstein PSS / OZ Superleggera / 034 Sway / 034 Spherical bushes
    Jul 04 2010
    Norway
    These are the weight I found when I was looking for rods 2 years ago.
    -Stock 2.7T rod/no rod bolt: 529 grams
    -Pauter standard 2.7L rod/no rod bolts: 530 grams (3.0L version is shorter so they are lighter)
    -VAST standard 2.7L H-beam rods/no rod bolts: 515 grams
    -VAST custom 3.0L stroker H-beam rod/no rod bolts: 479 grams
    -Rosten Connection Rods/no rod bolt: 542 grams
    -IE Connection Rods/no rod bolt: 555 grams
    -Custom carrillo rods/no bolts: 440 grams
    -RPM rods/no bolts - 523 grams
    Jul 04 2010
    Norway
    Quote Originally Posted by Audi_S4 View Post
    JHM weighed these rod (IE) vs. stock and they about 12 grams heavier per rod. This weight can be easily counteracted with our lighter JE Pistons
    Jul 10 2012
    buffalo
    does anyone make aluminum rods for the 2.7?
    May 16 2008
    South Texas
    Quote Originally Posted by somedude View Post
    You can probably get them made, but since aluminium rods have a defined life, they aren't good for street car unless you want to re rod the engine every so often.
    If you want the absolute lightest rod.. Go for Titanium.. But plan on spending $1000 a rod.
    May 20 2007
    Alligators
    pittsburgh
    The data is scattered all over the place. Pauters have been proven many times, as far as IE rods go, give them a call.
    Account Terminated Four Rings
    Feb 26 2011
    las vegas
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    Quote Originally Posted by S4 00 2.7 View Post
    Agreed. I have IE rods in my 770 car, not worried about them. At all.
    Senior Member Two Rings joeSfour's Avatar
    Nov 09 2011
    South Bay, CA
    Quote Originally Posted by Cacti View Post
    You should try them out...No way I am exposing my motor to these.
    Feb 06 2012
    Lake Lanier, GA
    Quote Originally Posted by joeSfour View Post
    Lmao, funny thing is the picture of those look like they have a hairline crack in them.
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    I was running 034 Rods in previous 650 whp engine without issues ( arp 2000 bolts )
    This time engine will revv a little higher, so I went IE rods with arp 625 bolts.
    Since the S4 community is almost totally filled with E opinions, go search what the IE rod does in the 1.8T
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    http://www.youtube.com/watch?v=1kG98vSWkT4
    WATERFEST 15 RUN 10.92 @ 133.55 mph
    Veteran Member Three Rings s4andtls's Avatar
    Jul 14 2009
    Ma.
    CUSTOM AGE 625 PLUS®: This newly formulated super-alloy demonstrates superior fatigue cycle life, tensile strength and toughness – with complete resistance to atmospheric corrosion and oxidation. ARP is the first to develop manufacturing and testing processes for fasteners with Custom Age 625+. Best of all it is less expensive and expected to soon replace MP-35 as the material of choice in the high strength, super-alloy field. Typical tensile strength is 260,000-280,000 psi.
    605.2 Brad tuning
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    That hair line crack you are talking about is where the rod cap mates with the rod. The rod cap is removable so the bearing can be placed and the rod can be affixed to the crank.
    No offense, but if you don't know that, stick with the IEs they are more than you will ever need.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Jul 28 2009
    Philadelphia PA
    Quote Originally Posted by itguy View Post
    These are legit, however they do need the wrist pin hole honed. They are a little snug for a turbo charged application. Heat = donzies.
    c8 a6 allroad
    Nov 10 2011
    Ontario
    Some ppl have also had issues with the H-beams on 3.0L strokers and custom pistons. Mmm love shaving piston skirts.
    Feb 06 2012
    Lake Lanier, GA
    Quote Originally Posted by rtl5009 View Post
    Why would you say that? That means I shouldn't get pauter rods because of what I said? Some of the local guys are saying to get the Pauter. I do know those caps come apart, just over looked it at that point...
    Gonna get the IE's simply because I know they work & when i have an excuse to pull the motor again...their gonna go in.
    Established Member Two Rings stew44's Avatar
    Dec 27 2008
    BC
    ^facepalm
    Feb 06 2012
    Lake Lanier, GA
    Quote Originally Posted by stew44 View Post
    ^facepalm
    if you have nothing to contribute to this thread, go elsewhere.
    Jan 11 2007
    Salt Lake City, Utah
    Quote Originally Posted by rockcandy View Post
    2nd
    Quote Originally Posted by GURUMAN View Post
    Big 2nd.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Mar 18 2010
    Ottawa
    Ya maybe he was a little internet rude but lately it seems par for the course. To me that is wrong, andI have seen it happen to all platforms that have come down in price. It's really too bad.
    The hairline crack is just that. The rod is cast as one piece to ensure the metal is of the same density of material, etc, etc. Then after machining the rod is opnened so you and I can insert bearings.
    Mar 18 2010
    Ottawa
    This has been true and I think the sinking of this platform as a whole.
    I know thread jacking. Sorry.
    Nov 10 2011
    Ontario
    Yeah damn these people and their opinions, they are sinking the B5 S4 platform and the whole fucking world :(
